Fly fly Dg808 4mtr
A couple of years ago I bought the Dg808 kit but never got around to assembling it.Looking at the wings,I’ve tried to locate appropriate high torque servos to fit in the cutouts but to no avail.Has anyone built this model and what servos have been used? I presume I’m going to have to enlarge the cutouts for even a high torque servo such as a hitec hs85.All comments appreciated.
I don't know that model, but what value of "high torque" are you looking for and what size are the servo cutouts?
My 3.7m glider I use for GPS Triangle racing has these in it https://www.hyperflight.co.uk/products.asp?code=MKS-DS6100&name=mks-ds6100-servo-3-3kg-cm-0-11s-9-5g-10mm
And my 4.7m GPS Triangle racer at 6.7Kg weight uses these https://www.hyperflight.co.uk/products.asp?code=KST-X10-710&name=kst-x10-710-v8-servo-7-5kg-cm-0-09s-23-0g-10mm
Lots more choices on the Hyperflight website if you have some measurememnts.
Dick
Given Martin's comments, something like this might be suitable - small and not too expensive.
https://www.flightech.co.uk/product/x08h-plus-premium-f5j-servo/
In very tight installations I have servos of this size with the lugs cut off, wrapped in tape and epoxied to the wing skin (cut tape and unwrap to remove!). With the space you have I don't think you need to go to those extremes 😀
Dick
The Kingmax servos look the biz!but I must admit I’ve never heard of them before. I usually use hitec metal geared servos in most of my models,mostly pss. I have a fly fly Condor that I’ve had to reinforce the tail end with carbon fibre. Objected to my landings on a couple of occasions.Many thanks for all your thoughts,very enlightening.
Hi Matty,I’m just going to have a look through my servo box as I have some hitec hs125s wing servos that I’ve had knocking about for some time.Got them for a Pat Teakle a asw17 that I no longer have and they were recommended for that model at the time.Trying to keep the cost down to pensioners rates lol.
I’m not a huge fan of 125s as the geartrains were always a little fragile, but they will be more than man enough for the job torque wise. If you have them already, might as well give em a go.
PS - This is the RCGroups monster thread, I’ve linked to a search for “servos” that should hopefully help.
https://www.rcgroups.com/forums/search.php?searchid=94711995&query=Servos
Edited by MattyB
Hi Matty. Just gone through all my servos,hitec,corona,futaba, some others,even parkzone and none will fit so it looks like I’ll have to enlarge the holes and make new cover plates!A bit of a pain on a new kit but hay ho if that’s what I have to do I’m going to reinforce most of the fuselage with carbon fibre.many thanks for everybody’s input.Has anyone actually built and flown one of these?how do they fly?
The Hitec 85 and 125 that you mentioned earlier are actually quite large servos for this application, and I would have thought something a bit smaller would be more than adequate - something like this https://www.4-max.co.uk/servo-emax-ES09MA.html
It seems smaller than your existing cutouts, metal geared, and a very good price. As others have said, you don't need really high power servos for this model.
Having said that, there is a build of this model on RC Groups where he also resorted to enlarging the wing cutouts to fit servos. He is less than complementary about the model in general, but that may be just him.
https://www.rcgroups.com/forums/showthread.php?2198527-DG-808S-FlyFly-4metre-Composite-Balsa-Glider-Rating-5-10
Dick
Not personally, I've sen plenty of FlyFly models down the years though. Once suitably reinforced they fly well, so I don't doubt this one will too. Certainly spend some time reading that RCGroups thread @Dickw and I linked above though; there is lots of first hand experience in that thread.
Edited by MattyB
Just been looking at emax servos.I’ve used them before on a couple of models,OV 10 Bronco for one and found them excellent.I found that the link is very helpful as it goes on to a step by step building guide. The Guy did have to enlarge the wing cutouts to accommodate servos.Thank you so much for the advice.
