Can anyone I'd this joint please?
Edgeflyer
This is a ball joint with a grub screw to lock it to a 3mm rod. I need to buy similar but can't work out what it's called or who sells them. The one I need has the normal ball joint at the other end set at right angles to the locking ball joints axis. The 2 joints are usually in 2 parts joined by a threaded rod. Any help would be appreciated!
