Andy Shailer Posted May 7, 2024 Share Posted May 7, 2024 Hi all, Im using a R617FS channel receiver and using all 7 channels, the usual 1-4 then 5 retracts, 6 retracts, 7 battery, Im using a DLE 20, this being my first petrol its on an Kyosho .90 Spitfire, I can't get to the choke to do it manually, no matter how I try, so I'm looking at using a servo, but have no spare channel, is there a way to link it to a used channel some how, my radio futaba T10CG, any help much appreciated. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted May 7, 2024 Share Posted May 7, 2024 when you say channel 7 for battery, do you mean the Rx battery, if so just Y lead a servo for the choke operation off that. But could you note just put in a manual actuation, cable or pushrod, typically on a petrol engine you put the chole on flick/spin it till it fires with the choke on (and it then stops), choke off, restart allow a min or so to warm up, then fly. Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted May 8, 2024 Share Posted May 8, 2024 As said Y lead on channel 7, I see that 5 and 6 are retracts, are you running them from the rx battery, if so is the battery powerful enough, are they small or large retracts ?. Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted May 8, 2024 Share Posted May 8, 2024 Do the retracts need separate channels ? Quote Link to comment Share on other sites More sharing options...
Andy Shailer Posted May 8, 2024 Author Share Posted May 8, 2024 Sorry flaps are on channel 6, not 5 & 6 sorry, old age creeping in! soon as get home tonight will try Y lead on channel 7 thank you for your advice, fingers crossed. Quote Link to comment Share on other sites More sharing options...
Andy Shailer Posted May 8, 2024 Author Share Posted May 8, 2024 Hi All, thank you so much Lads, yep got the choke servo working from a Y lead, on switch channel. Many Thanks Andy Quote Link to comment Share on other sites More sharing options...
