Mr Ficky Posted May 7 Share Posted May 7 Hi folks, I'm thinking of building a Carl Goldberg Extra, downloaded from outer zone, and converting it to electric. Looking at the plans, I see that most of the build is plywood. Has anyone got any experience building this from a plan, and perhaps not using ply but traditional balsa grades? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted May 8 Share Posted May 8 I built one some time ago, the advantage of the ply construction is that it's self gigging. If you assemble the fuselage and hold it together with rubber bands, once complete, you go round all the joints with cyno and it's done. Quote Link to comment Share on other sites More sharing options...
Diamond Geezer Posted 12 hours ago Share Posted 12 hours ago I have not built one but I have one and yes the majority of it is ply, I bought one from a guy who had never finished it am just about to fit the engine but I have no plans for it maybe you could help me to get the motor shaft central to the cowl the engine mount is 2p0 mm off centre is that right. Quote Link to comment Share on other sites More sharing options...
Adrian Smith 1 Posted 12 hours ago Share Posted 12 hours ago I have the CG Extra 300 plan in front of me and yes there 2 degrees of right thrust , no down thrust. Also the main wings and tail plane are at 0 degrees to the datum line. Hope that helps. Quote Link to comment Share on other sites More sharing options...
Diamond Geezer Posted 11 hours ago Share Posted 11 hours ago Hi Thanks for the reply but what I mean is would that put the engine mount 20mm off centre Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted 10 hours ago Share Posted 10 hours ago The way to work out the offset of the engine mount is to measure the distance from the mounting surface to the back of the spinner. Using simple trig you can work out what 2 degrees amounts to in terms of offset. 20mm sounds like too much to me. Quote Link to comment Share on other sites More sharing options...
Diamond Geezer Posted 8 hours ago Share Posted 8 hours ago Hi Andy how do you do that then Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted 4 hours ago Share Posted 4 hours ago DG Let's say the distance from the firewall to the back of the spinner is 150mm for example and you need 2° side thrust. tan 2° = offset/150 Therefore tan2° x 150 = offset tan2° = .035 offset = 0.035 x 150 = 5.2mm 2 Quote Link to comment Share on other sites More sharing options...
