Erfolg Posted January 12, 2009 Share Posted January 12, 2009 I found that I had a issue with my 35meg receiver that I was trying to use on an indoor/park flyer. I recently bought a small lightweight Rx over the Internet, and got quite a shock to find it was a small crystal type. It took about 3 months to source the crystal i wanted.I therefor e order a Corona synthesised Rx, which i intended to use with Futaba Gold or FP-7FG/K. At first all seemed well, it tuned onto the same frequency as the Tx. But a little later it stopped recognising it was switched on, doing a lot tune playing and flashing its diode as if searching for a Tx signal.I then tuned it into my Futaba 6EXAP, with which it linked, and has to date stayed linked after re-energising the Rx.Is this problem an age thing with old Futaba Tx's or is it a design issue with certain transmitters or manufactures?Has any one else had similar problems, or none? Am I the only person to be so affected?Erfolg Quote Link to comment Share on other sites More sharing options...
Former Member Posted January 12, 2009 Share Posted January 12, 2009 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Erfolg Posted January 12, 2009 Author Share Posted January 12, 2009 PhilIt comes from an age when those features were not available, unless your wallet was as large as Gordons. It must be about 20 years old i would guess, as expensive as a Rolex watch, as many features as a £15 transmitter today.Erfolg Quote Link to comment Share on other sites More sharing options...
001 Posted January 12, 2009 Share Posted January 12, 2009 You will see from another thread, that I had a Corona synthesised receiver, the aerial wire is very thin and not well connected, might be as well to check that and not put any strain on it. Quote Link to comment Share on other sites More sharing options...
Former Member Posted January 13, 2009 Share Posted January 13, 2009 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted January 16, 2009 Share Posted January 16, 2009 No Fleet Tx's when set to PPM will work with other Rx's and vice versa Fleet Rx's will work with other Tx's. But Fleet used different Channel allocations so you'll have to swap the servo plugs around. Check your Tx batteries before you try out your Tx's though, they will be a bit old now and I know my PCM set Tx battery died after i hadn't used if for 6-9 months. Quote Link to comment Share on other sites More sharing options...
David Perry Posted January 18, 2009 Share Posted January 18, 2009 I have used fleet PPm with all makes of Rx with no issues at all. Like all PCM though, they are brand specific. D Quote Link to comment Share on other sites More sharing options...
Former Member Posted January 19, 2009 Share Posted January 19, 2009 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
