Multiplex Mentor
stephen-each to there own-but when you put a mix into one model like you have...it won't work the same with another completely different model..i would go steady on the stick's with a model with aileron's mixed into rudder(unless it was a cub or similar) on the ground..in the air a lot of high wing planes especially the cub's and the like benifit from the mix of rudder and aileron's...i would attempt the take off using your rudder only on the ground...........again each to there own-the above is my opinion only...i know when it's early day's anything that get's the plane safely off the ground into the air is a help for your confidence and Wallet................
 ken anderson...member of the S.g....fanclub...
