Jon Posted March 18, 2009 Share Posted March 18, 2009 I have made a timber thingamabob that sits under the wings and sandwiches a nice bit of round foam (pipe lagging) between it and the wing covering at the point of the C of G. I'd would include a photo for you but it would be a bit too embarrassing! Its not the best idea I'm sure and with a few mods here and there I have been able to use it for my last 4 planes. I'm trying to balance a Mini Extra 260 (AUW 19oz) which has quite an tight tolerance, just + or - a couple of mill. Whats your recommendations for the best C of G Thingamabob that works on most planes... I promise not to giggle at you photos Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted March 18, 2009 Share Posted March 18, 2009 Edited By Martin Harris on 18/03/2009 14:21:58 Quote Link to comment Share on other sites More sharing options...
Alex Leigh Posted March 18, 2009 Share Posted March 18, 2009 I used the patented "Lloydometer". Bit of stout wood with two pencils glued in and the tops of the leads sanded off. Cheap, easy, accurate. Pick 2 Quote Link to comment Share on other sites More sharing options...
Jon Posted March 18, 2009 Author Share Posted March 18, 2009 Do you use your thumbs then Martin? Do you find the pencil lead sticks into the covering Alex? Quote Link to comment Share on other sites More sharing options...
Alex Leigh Posted March 18, 2009 Share Posted March 18, 2009 Sanded them flat-ish! It was only for the WT which is foam. Not tried it on anything with covering over wood. Quote Link to comment Share on other sites More sharing options...
Stefan Hafner Posted March 18, 2009 Share Posted March 18, 2009 I'm with martin on this, thumbs work fine for me. I tend to start off wit the CoG slightly forwards then move it back as i get used to the plane, better to be safe, call me a chicken if u like Quote Link to comment Share on other sites More sharing options...
Kelly Posted March 18, 2009 Share Posted March 18, 2009 Cheap and cheerful Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted March 20, 2009 Share Posted March 20, 2009 Edited By Doug Ireland on 20/03/2009 23:59:03 Quote Link to comment Share on other sites More sharing options...
Ernie Posted March 21, 2009 Share Posted March 21, 2009 Hi Guys, Take two bottles of wine (they should be the same) drink the contents, cut the corks to give a sharpish edge, put them back in the bottle with the edge exposed, and bingo, an instant balancing tool ernie Quote Link to comment Share on other sites More sharing options...
