Diamond Geezer Posted March 23, 2009 Share Posted March 23, 2009 Hi Guys Got a problem with an sc 25 from a show [second hand] it will only run if the slow running needle is 4 turns out,if I screw it in just a small amount it don't want to know but with this out so far, the main needle don't do anything, couple of chaps at the field had a look at it with no luck, now I don't know where I am with it any ideas I've changed the plug tried different fuel,the amount of fuel coming out of the exhast its obvious its miles to rich but it will only run on this setting ,but I can't set it up because the main needle is not doing anytrhing any ideas? Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted March 23, 2009 Share Posted March 23, 2009 hello diamond-the answer sounds like what you've said bought it 2nd hand from a show--the needle shouldn't need to be 4 turns open--borrow or buy a carb may be the only fix=£££........ ken anderson............ Quote Link to comment Share on other sites More sharing options...
Diamond Geezer Posted March 23, 2009 Author Share Posted March 23, 2009 thx ken Quote Link to comment Share on other sites More sharing options...
Andy Green Posted March 23, 2009 Share Posted March 23, 2009 If you feel confident, you could strip clean the carb. Just Engines will have a carb to fit. Andy Quote Link to comment Share on other sites More sharing options...
moorer Posted March 23, 2009 Share Posted March 23, 2009 as andy suggests i should make sure the carb and needles are all clean and clear and there are no air leaks.i bought an early sc25 some 10 years ago brand new at a show and that wouldnt run properly either,turned out the liner was in the wrong way round!!! ran a treat after for 6 flights then it went out of tune.ive always bought OS ever since. Quote Link to comment Share on other sites More sharing options...
Former Member Posted March 24, 2009 Share Posted March 24, 2009 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted March 24, 2009 Share Posted March 24, 2009 i used to watch people arrive at our field and then spend the session trying to get their engine in tune to have a flight-they either couldn't or thought they had-took off and then went dead stick and kapowed the model---mds were the worst followed by early sc's-i made the decision early on to buy os-set them up and that's it................. ken anderson............. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted March 24, 2009 Share Posted March 24, 2009 Well actually I reckon the SC ( certainly these days ) are superb little engines, and represent cracking VFM compared to the overpriced OS. Not saying theres owt wrong with OS - there isn't - they are nice pieces of kit, however one is paying a percentage for the badge. Even an old IC die hard and modelling guru Peter Miller likes the SCs and he cant be wrong! I only have 2 x engines these days - SC 4 stroke - and both are sweet as a nut. Edited By Timbo - Moderator on 24/03/2009 07:30:11 Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted March 24, 2009 Share Posted March 24, 2009 sorry timbo-your a sparkie/windchaser now-os rule forever............................ ken(oily)andersonic............ Quote Link to comment Share on other sites More sharing options...
Bert Posted March 24, 2009 Share Posted March 24, 2009 DG Find someone in your club who really knows about engines to get it set up for you. I fly electric now, apart from my FF diesels, but when I used to fly IC I got fed up with all the people who can't get anything other than an OS to run properly. I had four of the early MDS engines and a couple of the ASPs when they came out and they all ran ok for me in spite of all the people who told me at the time that they were useless. Bert Quote Link to comment Share on other sites More sharing options...
Peter 'Ivanna Crashalot' Savage Posted March 26, 2009 Share Posted March 26, 2009 might be something stuck in the carb, eg a bit of dirt or maybe a bit of copper pipe from the tubes in the tank Quote Link to comment Share on other sites More sharing options...
