Dan C Posted April 29, 2009 Share Posted April 29, 2009 This always confuses me for some reason I use a JR transmitter but most my models are a mix of futaba and hitec receivers. When buying new crystals i know i got to have a jr one in the tx but what about the rx's Do they have to be the same make as the tx or the same make as the rx? For example: JR tx crystal and jr rx crystal in a futaba rx or JR tx crystal but use a futaba crystal in a futaba rx Cheers for your help Dan Quote Link to comment Share on other sites More sharing options...
BB Posted April 29, 2009 Share Posted April 29, 2009 Mixing is always dicy. The BMFA recomendation is to always use the same 'pair' of crystals, regardless of equipment used. So I guess that even though you may be using differing Tx & Rx. The crystals should be of a same make. Your example 'A' is right. Although the recommendation is to always use same Tx & Rx sets with accompanying crystals 'pairs'. If in doubt, a thorough range check as good practise should suffice. BB Edited By Basildon Biggles on 29/04/2009 18:29:28 Edited By Basildon Biggles on 29/04/2009 18:33:05 Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted April 29, 2009 Share Posted April 29, 2009 Can't really agree here. While most crystals used in 35MHz are interchangeable there may well be different IFs used by one or two makers which are directly related to the crystal frequencies required - therefore the best option is to use the receiver manufacturer's crystal - but in practice, they will most likely be made a limited number of suppliers and rebadged by the radio manufacturers anyway...Edited By Martin Harris on 29/04/2009 22:13:07 Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted April 29, 2009 Share Posted April 29, 2009 Thought I'd better check what the BMFA advice was and it is: (q) It is essential that you use the correct specification crystals in any transmitter or receiver you are using. Not all crystals are the same and you should NEVER use one manufacturer’s crystal in another’s Tx or Rx. The only exceptions are many of the aftermarket receivers and their manufacturers actually specify which crystals are compatible. (r) When buying crystals, always take care to specify in which individual piece of equipment they are to be used. Original manufacturer’s crystals are always the best choice. My interpretation of this is pretty much as per my thoughts in the previous post - use the manufacturer's crystal in their receiver where possible unless specifically stated in an aftermarket one's instructions although I must admit to being happy to mix and match with a proper range check. Quote Link to comment Share on other sites More sharing options...
Former Member Posted April 29, 2009 Share Posted April 29, 2009 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
