Terence Lynock Posted May 20, 2009 Share Posted May 20, 2009 As you get older your eyes may well go downhill a little so seeing small marks during the construction of an airframe is hard work, if you have problems seeing small marks when building airframes stick a dab of fluorescent highlighter over the mark and it stands out like a sore thumb, I prefer yellow but others may prefer pink or green. Highlighters are useful for a few jobs during building so keep one handy, regards, Terry Quote Link to comment Share on other sites More sharing options...
Klippy Posted May 20, 2009 Share Posted May 20, 2009 Hi Terry, yet another great idea, perhaps Timbo should put them all together in one place? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted May 20, 2009 Share Posted May 20, 2009 Errr.... they are already Tony - hence the thread title "Hints and Tips " Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted May 20, 2009 Share Posted May 20, 2009 Weve had several good Ideas today Quote Link to comment Share on other sites More sharing options...
Terence Lynock Posted May 20, 2009 Author Share Posted May 20, 2009 I think the ideas and quick tips will come in steadily as we get them, I was struggling to see fine alignment marks unless I used a bright light then when the tube in my desk light went I tried this idea which worked fine and this is how things happen, regards, Terry Quote Link to comment Share on other sites More sharing options...
Former Member Posted May 20, 2009 Share Posted May 20, 2009 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Phil Claridge Posted May 21, 2009 Share Posted May 21, 2009 use a snake inner with a plastic clevis, to guide servo leads through wings, if you cut off the clevis pin the servo plug fits nicely in the clevis. using the snake allows you to twist and turn the plug to get through the ribs keep your fuel in picnic cool boxes, standard size will hold two gallons, this keeps them safe from sharp objectsm protects from frost in a cold shed and away from sunlight. also contains any leaks, plus you can stack them if you have a lot of fuel(rich ******) i use them when i buy fuel at the shows Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted May 21, 2009 Share Posted May 21, 2009 I keep my fuel out in a shed in an old fridge. same idea but saves paying them to taker the old fridge away. Quote Link to comment Share on other sites More sharing options...
