SC 4 stroke
John Lewnes
Hi, Just purchased an SC 30 4 stroke and it will only run backwards. I have been using an electric starter (rotating the correct way) but it refuses to run correctly.It starts easily enough and runs and idles beautifuly, but the wrong way!. Anyone got a bright idea?. Thanks, John
sounds as though the valve timing may be out.  I've had a couple of engines off fleabay, supposedly 'as new', but when I examined them, the cylinder liners had been removed and replaced out of position, blocking the exhausts.
No idea how you check the timing though, sorry!
