gordon price Posted March 21, 2011 Share Posted March 21, 2011 Craig It looks very good and it flies well, only hope mine does as well as yours, now to pick your brains, I have had a mixed message as to what I should power it with, I was looking at a Flightpower Evo-pro Lite at 18.5v 5200Ah 5 cell with matching speed controller, but my local shop thinks more like two batteries and two controllers, what did you settle for as it is working well. Gordon Quote Link to comment Share on other sites More sharing options...
Craig Carr Posted March 21, 2011 Author Share Posted March 21, 2011 Hello Gordon, As I recall the all up weight of the model is in the region of 10 pounds. I stuck to the 100watt per pound rule of thumb which for the type of model is a bit much for scale but I figure you can always throttle back (which I didnt do in the video ) Therefore to achieve my set up I used 4 x250watt Turnigy outrunner motors. You will need to use a speed controller per motor though when driving brushless motors (so four of). Again I used Turnigy ESCS Extend the wiring between the motor and speed controllers not the battery to ESC (you could probably site them underneath the middle of the wing. Used two 4000mah LIPO batteries 3S........ One battery drives the two inboard motors, the other drives the two outboard motors (so in theory if any variance or one battery should pack up you dont lose symmeticral thrust). Also fitted a seperate RX battery. (You will need to remove the red wires on the servo cables from each ESC to RX though). I think when Tony designed the model it was in the dark old days of brushed motors as I seem to remember speed 600 motors being shown on the plan. Personally I would avoid brushed motors for a model such as this. For the motors I used I needed to make a new motor mount/firewall that is slightly bigger than the one supplied in the kit . So the nacelle had to be modified accordingly to fit around it. You never know though the motor you settle on may be ok but check first before making the nacelle Hope this helps CraigEdited By Craig Carr on 21/03/2011 17:06:14 Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted March 21, 2011 Share Posted March 21, 2011 Posted by Craig Carr on 21/03/2011 09:04:25: HI Dan, No problem............. Its all geared up ready for the 2011 season I Could-but i wont comment.....should really leave it to the 'owner/flyer' to expand on the previous 2009/10 seasons displays... ken anderson ne...1. Quote Link to comment Share on other sites More sharing options...
r6dan Posted March 21, 2011 Share Posted March 21, 2011 Posted by ken anderson. on 21/03/2011 17:11:19: Posted by Craig Carr on 21/03/2011 09:04:25: HI Dan, No problem............. Its all geared up ready for the 2011 season I Could-but i wont comment.....should really leave it to the 'owner/flyer' to expand on the previous 2009/10 seasons displays... ken anderson ne...1. Cone on then Craig spill the beans..... Quote Link to comment Share on other sites More sharing options...
Craig Carr Posted March 21, 2011 Author Share Posted March 21, 2011 Its Just how Ken's mind works Dan..... Quote Link to comment Share on other sites More sharing options...
r6dan Posted March 21, 2011 Share Posted March 21, 2011 Oh dear Ken....... Quote Link to comment Share on other sites More sharing options...
gordon price Posted March 22, 2011 Share Posted March 22, 2011 Craig Ops When my son got me the plane he also purchased 4 Graupner speed 600 motors 8.4v which I have fitted to the nacelles so I shall try these first before I rebuild them with new Brushless motors Quote Link to comment Share on other sites More sharing options...
Craig Carr Posted March 22, 2011 Author Share Posted March 22, 2011 Hi Gordon, I thought it was those motors. Dont get me wrong it will fiy on them but I had a B17 that weighed 10pound and used speed 600 brushed motors. It used to burn out the brushes on the motors and in general they are far less efficent... performance is a bit marginal, less duration etc etc... If you wish to get exactly the same set up as mine give Dave Andrew of concept models a ring... he supplied the motors, speed controllers and props etc for my A400m. He is a good lad - we all use "up north"......does mail order. If you mention my name and A400 he will know exactly what you need Click here for concept models Craig Edited By Craig Carr on 22/03/2011 11:42:11 Quote Link to comment Share on other sites More sharing options...
gordon price Posted March 22, 2011 Share Posted March 22, 2011 Craig Thanks very much for your help, It looks like I will have to follow your path and get brushless motors, back to the drawing board and build 4 new nacelles, good job they were only in rough build. Quote Link to comment Share on other sites More sharing options...
gordon price Posted May 8, 2011 Share Posted May 8, 2011 Well So far so good, had a little trouble with the working ramp,but ok now. Quote Link to comment Share on other sites More sharing options...
winchweight Posted May 8, 2011 Share Posted May 8, 2011 Give us some pictures and details Gordon! I have one waiting to build. Quote Link to comment Share on other sites More sharing options...
gordon price Posted May 10, 2011 Share Posted May 10, 2011 Shaun Had trouble getting the ramp to move from ground level to closed so I managed to find a Retrak servo with the centre screw on a long slot for the pivot arm, that way it would find its own lengh , I tried to upload 2 foto`s to show you but for some reason they wont work, will have to try again Quote Link to comment Share on other sites More sharing options...
winchweight Posted May 10, 2011 Share Posted May 10, 2011 Thanks Gordon. Looking forward to the pics. Does your have retracts too? Quote Link to comment Share on other sites More sharing options...
Craig Carr Posted May 12, 2011 Author Share Posted May 12, 2011 Well done Gordon.Looking forward to seeing some pics when you get them to work.Craig Quote Link to comment Share on other sites More sharing options...
gordon price Posted May 12, 2011 Share Posted May 12, 2011 Shaun I have only put retract on the nose wheel, Ihave more photo`s but the system will not let me add more, do you have to be a paidup member to put on more photo`s, Quote Link to comment Share on other sites More sharing options...
winchweight Posted May 12, 2011 Share Posted May 12, 2011 Ah shame. Are you planning on main wheels retracts? Quote Link to comment Share on other sites More sharing options...
gordon price Posted May 16, 2011 Share Posted May 16, 2011 Shaun Idid work on main wheel retracts and got them working well but when I left it standing overnight it started to sink,I found that the leavers you fit on the axles was slipping,I tried putting a flat on the axle to hold the grub screw but that still did not work,they say that you should solder them together but you can`t do that because it will melt the plastic, the only way is to make the leavers out of brass and braze them together before fitting, you will have to sort this out after the two sides have been fitted together but before the longerons are fitted. gordon. still having problems with the photo`s Quote Link to comment Share on other sites More sharing options...
Craig Carr Posted May 16, 2011 Author Share Posted May 16, 2011 Hello Gordon,It can be done.... The plastic arm comes off to leave the metal collette... you can then silver solder it into position. Once cool then slide the plastic part back over....But you need to do this before you bend the other side of the undercarriage wire or you won't be able to get the plastic bit around the bend. Obviously youve already done this so too late unless you make another set,good luck, managed to have a look at the job so far by looking at your album, it's certainly coming on a treat.CraigEdited By Craig Carr on 16/05/2011 16:42:36 Quote Link to comment Share on other sites More sharing options...
gordon price Posted May 19, 2011 Share Posted May 19, 2011 Shaun At last I have the photo`s of the ramp open and closed which I have being trying to show you, I had to retake them then upload from the camera, gordon. Quote Link to comment Share on other sites More sharing options...
winchweight Posted May 20, 2011 Share Posted May 20, 2011 Hi Gordon, please keep up the info. I am a bit embroiled in a family crisis but promise to catch up soon. Shaun Quote Link to comment Share on other sites More sharing options...
Vinmonkey Posted March 15, 2014 Share Posted March 15, 2014 Sorry to revive an old thread, anyone know the c of g for this model, club mate has just built one and is struggling to find t? Cheers. Vin Quote Link to comment Share on other sites More sharing options...
Craig Carr Posted March 15, 2014 Author Share Posted March 15, 2014 Hi Vin, Just dusted off the plan. Its 160mm from wing root leading edge. Craig Edited By Craig Carr on 15/03/2014 15:16:11 Quote Link to comment Share on other sites More sharing options...
Vinmonkey Posted March 15, 2014 Share Posted March 15, 2014 Cheers Craig, true gent. Quote Link to comment Share on other sites More sharing options...
Nik Harrison Posted June 22, 2018 Share Posted June 22, 2018 A little late in posting but this model really needs to be better known. It flies superbly using the motors/battery combo as proposed by 4max, although I did use a quad ESC as it was more convenient and cheaper. The Tony Nijhuis site states a motor setup of 4x500W which is way OTT. I measured mine at around 800W total. Check out my build in the Album section - A400 Altas. Here is a link to a para drop video I did. https://youtu.be/gCcOIthh0zE I cannot praise this model highly enough - it is different and allows you to add a bit of your own input to the build. All a can say is "well done Tony". Edited By Nik Harrison on 22/06/2018 12:25:05 Quote Link to comment Share on other sites More sharing options...
William Macleod Posted September 10, 2019 Share Posted September 10, 2019 Hi Nik, How slowly does the model fly? All videos show it being flown like a pattern ship. thanks. Bill Quote Link to comment Share on other sites More sharing options...
