mike prior Posted July 19, 2009 Share Posted July 19, 2009 I have just got the new V-trainer with aileron wings! My first model.... indeed, some parts were missing...very disappointing start. I’m sure the nice man at flying wings will send the parts, but still messed up my weekend. I got the Spektrun DX6i with the kit, very nice ,but with the rudder/elevator mix I have the elevator on the left stick. I can’t find a way to change this over so that the rudder works on the left stick with throttle & the elevator on the right like my simulator. Can anyone please help Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted July 19, 2009 Share Posted July 19, 2009 Timbo is your man but I think your talking about the mode.Normally you have throttle ,rudder left stick,and aileron elevator right stickI think you have the wrong mode but the expert on spectrum is Timbo Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted July 19, 2009 Share Posted July 19, 2009 Yes I am afraid Stephen is correct. Whenever you buy a Spektrum Tx you MUST specify which mode you want. They only come in 2 flavours, mode 1 or mode 2.Im not sure what mode you described, but throttle and elevator on one stick as you suggested is impossible. Mode 1 puts rudder and elevator on left, aileron and throttle on the right.Mode 2 is throttle and rudder on left, aileron and elevator on right Quote Link to comment Share on other sites More sharing options...
Pete B Posted July 19, 2009 Share Posted July 19, 2009 If you look on the Spektrum packaging, Mike, the mode should be labelled somewhere on the outside.Which side is the self-centring stick, left or right? Pete Edited By Pete B on 19/07/2009 23:14:20 Quote Link to comment Share on other sites More sharing options...
mike prior Posted July 20, 2009 Author Share Posted July 20, 2009 Thanks guys. The self centering stick is on the right I think I may have either a faulty unit or I have done something daft in the mixing! Somehow I have elevator working in the horizontal plane & throttle in the vertical plane on the left stick. Then aileron horizontal & rudder vertical on the right stick! The V-trainer has 2 sevos working the ailerons connected to a Y connection & 2 servos one on each side of the plane body, operating the left & right V tail elevator/rudder mix. I have also noticed when adjusting the servo travel, that I cannot see any difference in movement in any of the controls Edited By mike prior on 20/07/2009 08:50:34 Edited By mike prior on 20/07/2009 08:54:10 Edited By mike prior on 20/07/2009 08:58:03Edited By mike prior on 20/07/2009 09:00:04 Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted July 20, 2009 Share Posted July 20, 2009 Then you have a mode 2 Tx. I doubt very much that the unit is faulty, are we talking just about how it behaves on the sim?If the wrong controls are happening in a model, maybe you simply have the servos plugged into the wrong channelsHave you set V tail mixing in the main setup menu? Edited By Timbo - Moderator on 20/07/2009 08:59:55 Quote Link to comment Share on other sites More sharing options...
mike prior Posted July 20, 2009 Author Share Posted July 20, 2009 yes, I have tried changing the connections in the RX. I did set the V tail mix as you say, Im very confused Quote Link to comment Share on other sites More sharing options...
mike prior Posted July 20, 2009 Author Share Posted July 20, 2009 I have the power/speed control pluged in the Throttle socket then ailerons in the Ail socket with the tail servos in the rudder & elevator sockets, I tried chnging only the elevator & rudder aroundEdited By mike prior on 20/07/2009 09:06:27 Quote Link to comment Share on other sites More sharing options...
mike prior Posted July 20, 2009 Author Share Posted July 20, 2009 Ok, now sorted it was infact servo reversing on the rudder that was needed. So now have tail mixing on the right stick with throttle up & down. Aileron left & right & Elevator up & down on the right stick....few! Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted July 20, 2009 Share Posted July 20, 2009 four controls.... all on the "right "stick eh mike Quote Link to comment Share on other sites More sharing options...
Stephen Grigg Posted July 20, 2009 Share Posted July 20, 2009 That should be a challenge Quote Link to comment Share on other sites More sharing options...
mike prior Posted July 20, 2009 Author Share Posted July 20, 2009 sorry typo mistake that should read tail mixing on the left stick with throttle up & down Aileron left & right & Elevator up & down on the right stick Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted July 20, 2009 Share Posted July 20, 2009 Yep...mode 2. Quote Link to comment Share on other sites More sharing options...
Phil 9 Posted July 26, 2009 Share Posted July 26, 2009 I have just got one (dx61). I need some more servos and it recomends JR ST47 Standard servos. but i cant fine any of this type can anyone recomend an alternative servo (will any make of servo work?) Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted July 26, 2009 Share Posted July 26, 2009 Any conventional 3 wire servo will work just fine with all Spekky tx s Quote Link to comment Share on other sites More sharing options...
Phil 9 Posted July 26, 2009 Share Posted July 26, 2009 thanks timbo Quote Link to comment Share on other sites More sharing options...
kc Posted July 27, 2009 Share Posted July 27, 2009 The point about mode 1 or mode 2 is that it should be the same as your instructor. You should join a club that flies your mode. As a general rule you never change modes once you have some experience with a particular mode.Also even when you have learnt to fly it is good to know that any club member could fly your plane if you have an emergency ( something in your eye / stung by wasp etc! ) so it's best to have the same mode as everyone else. Quote Link to comment Share on other sites More sharing options...
