Peter Wood Posted October 21, 2009 Share Posted October 21, 2009 I have the above Heli which seems a bit over responsive, when running on original Tx. If I set it up using the Futaba 9c. What ccpm Swash type do I use. Please. As I am told it can be softened quite a bit with a decent TX Peter Quote Link to comment Share on other sites More sharing options...
Jonathan Lewzey Posted October 21, 2009 Share Posted October 21, 2009 I don't think it will work with other 35 mhz tx's. if it doesn't your best option is to move the pushrods further towards the centre of the servo so there is less movement mechanically. Quote Link to comment Share on other sites More sharing options...
Peter Wood Posted October 21, 2009 Author Share Posted October 21, 2009 As it is flight tested, I think it means altering the relationship of the ccpm may unbalace everything and alter the response of the servo. Peter Quote Link to comment Share on other sites More sharing options...
Alan B Posted October 22, 2009 Share Posted October 22, 2009 I agree with Jonathan. I think I'm correct in saying that the heli uses a 4 in 1 receiver geared to be used with the supplied TX. Twisters are known to be a bit twitchy and can be a bit of a handfull to fly. Bigger ccpm helis with a separate 6+ channel RX would normally have a swash plate setting of 120 degrees i.e: the 3 servos connected to the swashplate Aileron,elevator & Pitch Al Edited By Alan B on 22/10/2009 09:51:17 Quote Link to comment Share on other sites More sharing options...
Peter Wood Posted October 22, 2009 Author Share Posted October 22, 2009 Thanks the 120 degree swash plate, done by futaba 9c has 2 servos at front and one behind, or 2 to the right and one to left(aileron), were as the twister has 2 to the rear. Can I use one of these settingsMy friend says the head speed is quite high, so I was hoping that using throttle and pitch curve adjustment, aand a little bit of expo, I might be able to tame the beast. There is definately a radio link between the 9c and the twister but the throttle does not work the motor even, with the control reversed. As you say the Twister's are known to be a handful to fly. I beleive selling it as an ideal beginners model is false advertising Peter Quote Link to comment Share on other sites More sharing options...
Alan B Posted October 22, 2009 Share Posted October 22, 2009 Hi peter If there is a connection as you say - you will probably have to calibrate the speed controller {may be intergrated - I do not know) to the throttle on your TX. I would suggest you loosen off the motor back off the gear drive while you are messing about. That way you can see if the motor is going in the right direction and the blades wont fire up. I am a spektrum man myself. You will have to determine which servo is which. It should tell you in the manual. When setting up the servos at 120 degrees (3 Servos) on the TX. On the Spektrum TX at 120 degrees - the 3 servos are normally firstly set at + or - 60% for the Aileron Elevator & pitch mix depending on the installation position of the servos to determine whether it is a + or - setting to get things going in the same direction. I presume this is similar on the Futaba set. You will just have to play around with it (Trial & Error I'm afraid!!) Good Luck - Im off to test Fly my new Phoenix Flasher 500 - bit more of a beast!! Al Quote Link to comment Share on other sites More sharing options...
