BB Posted December 16, 2009 Share Posted December 16, 2009 Can anyone help. Im looking for a bearings set - front and back for my OS .46 ax. Anyone know of a stockist or generic supplier ? In hope BB Rear Bearing: Open. SPECS: Outer Diameter: 1-3/32" (27.68mm) Inner Diameter: 5/8" (15.87mm) Thickness: 9/32" (7.14mm) Front Bearing: Shielded. SPECS: Outer Diameter: 0.875" (22.24mm) Inner Diameter: 0.375" (9.52mm) Thickness: 0.280" (7.13mm) BBEdited By Basildon Biggles on 16/12/2009 07:36:49 Quote Link to comment Share on other sites More sharing options...
Ernie Posted December 16, 2009 Share Posted December 16, 2009 Hi BB Have you tried Just Engines? ernie Quote Link to comment Share on other sites More sharing options...
Bruce Richards Posted December 16, 2009 Share Posted December 16, 2009 Modelfixings.co.uk. If you provide them with those dimensions and tell them it is an OS46 AX they will give you a 10% discount on the bearings because they do not have them listed yet. Quote Link to comment Share on other sites More sharing options...
Jimbo565 Posted December 16, 2009 Share Posted December 16, 2009 BB Have a look in your Yellow pages and find a local bearing supplier eg Bearing services,they can knock pounds off the model trade prices, Jim Quote Link to comment Share on other sites More sharing options...
Brian Parker Posted December 16, 2009 Share Posted December 16, 2009 A good source for bearings is Bolton Engineering Products they trade on ebay as steve3822. Also Arc Euro Trade Bearings stock a range in 'model sizes'. Both standard imperial bearings, (the 1-3/32 OD is perhaps not so common) Quote Link to comment Share on other sites More sharing options...
BB Posted December 16, 2009 Author Share Posted December 16, 2009 Much thanks gents I shall peruse a little later as Im working tonight so need some kip BB Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted December 16, 2009 Share Posted December 16, 2009 I think you'll find the rear bearing could be metric (although the front one may well be imperial) if the later AX is anything to go by so might be worth re-measuring. Any bearing stockist should be able to help - probably off the shelf... I would get a rubber shielded variety for the front (a few pence more) and prise out the inner facing seal before fitting although you might want to stick with the manufacturers spec. for "safety". I feel that having a seal at the front bearing makes for a more consistent fuel/air mixture...Edited By Martin Harris on 16/12/2009 12:59:34 Quote Link to comment Share on other sites More sharing options...
BB Posted December 19, 2009 Author Share Posted December 19, 2009 Bearings were ordered from 'Simply Bearings' on Wednesday, arrived Friday. Correct Martin the front is IMP the rear METRIC. The front bearing arrived shielded on both sides. I've just removed one of these shields so, it'l be open internally. I did think about a rubber sealed one for the front, but, thought I'd stick with what was already inplace - being a novice. Found it surprisingly easy to take the engine apart. BTW - engine had less than 20 hrs on it: And had ingested foriegn matter during the flight. Still, I was surprised at the extent of the scoring of the crank chamber at the small end and in the linning. Pics in photo album. BB Quote Link to comment Share on other sites More sharing options...
BB Posted December 20, 2009 Author Share Posted December 20, 2009 Have just re-assemble engine with new bearings. Feels very ok. Hopefully will run in next week or so. Beats buying a new one, though I did, just incase, an SC .46. If the OS ax is ok. the SC will have a home elsewhere. Quote Link to comment Share on other sites More sharing options...
BB Posted December 20, 2009 Author Share Posted December 20, 2009 Ok, my new OS .46ax went in from a height, due to main wing failure. I took it home and stripped it down as much as I was comfortable with. Got a new airframe and all was good, for about the next 10 hours (flight time). During my last flight the engine went 'sick'. Landed and found grinding when the prop was turned by hand. I didn't want to be without a flight during xmas so went home and ordered a new SC .46 as a replacement.Guys at the club said I'd need to pass the ax to a club member who could check and replace (if necessary) the bearings - between 40 - 50 quid !So, went on internet meantime and found a video showing how to extract/replace bearings. Sourced a Co called 'Simply bearings', and ordered a pair (front & back) including postage cost me £16.59p. Though if I'd chosen the cheaper options available I'd have paid less than £11-00p (incl P&P). Ordered last Wednesday, arrived this Friday. BTW - One well known national MS wanted to charge me £40-00p for the rear bearing alone !!!!! Put the new bearings in Last night. Run in today. Excellent. Feels like a brand new lump !!I am no engineer when it comes to engines - equipment required:1 x Modellers tap hammer1 x Oven, gas mark 2 (10 mins)1 x Tee towel1 x Small piece of plywood (apprx 1cm x 5cm x 15cm). To use as a workbench, tapping out the crank & bearings.1 x Suitable allen key1 x Cross head screwdriverIn other words don't be frightened of having a go. Hope this helps anyone thinking of buying a new engine, when its not really necessary.P.S. 4 strokes are just as easy. Just more parts. Oh and you'll need a feeler gauge (phieler) not sure how its spelt. Most low settings start at .040 (thou)BB Quote Link to comment Share on other sites More sharing options...
