The Dauntless build
Hi David, I guess its the fact that it looks like a junk yard, I've never seen a picture of a clean one, unless its rusty, paint chipped and patched it aint a Dauntless. Unlike a lot of other models, they more the Dauntless gets hanger rash, the better it looks LOL.
G
Hi Graham, you are a man after my own heart. Nothing gives me more pleasure in seeing a project take shape on the building board or actually in your hands. I have always been impressed by the accuracy of a dry fit of components produced by the lazer method.
Do you find that the burnt edges of the parts take away some of the integrity of the glued joint, or do you a light sanding before the final assembly.
I am very much like you, and I never hesitate in changing something on a plan or kit, to make it ,(in my opinion), work better.
Keep up the good work, but don't burn too much midnight oil.
Regards...Handyman.
Thanks guys for the nice thoughts and comments, some of the original laser cut kits some years back did leave a nasty charcoal residue that used to be a problem with CA, but these new lasers don't seem to have half as much.
I've added a couple of Cyparis stringers (excuse the mess), and its starting to look like a plane now.
http://www.rcmf.co.uk/gallery/albums/userpics/10010/dbfuza.jpg
Taking care to ensure the rear end is horizontal to the building board, so the tail (Stab) will sit correctly.
http://www.rcmf.co.uk/gallery/albums/userpics/10010/dbfuzb.jpg
Started sheeting the fuse today (probably my most fav job in building, getting that sheet round complex curves is fun, well I think so).
http://www.rcmf.co.uk/gallery/albums/userpics/10010/bdsheet1.jpg
I also need to 200% check and check again that the horizontal stab sits level plus 3deg pos incidence (more on that latter). So far so good, as I need to sheet the tail area of the fuse and attach the stab BEFORE removing the top half of the fuz off the building board.
http://www.rcmf.co.uk/gallery/albums/userpics/10010/bdsheet2.jpg
Finally happy with the tail seating, I've fixed it to the fuse
http://www.rcmf.co.uk/gallery/albums/userpics/10010/bdfusg.jpg
And today I've covered the elevators in Solartex, which will then be coated in a few coats of Poly-c (Well I did write the article on the stuff, so I better endorse my own findings), then rubbed down.
Just for extra confidence I've also added some extra cross members under the stab, now the fuse has been removed from the building board.
http://www.rcmf.co.uk/gallery/albums/userpics/10010/dbcvrb.jpg
Next I hope to start on the bottom of the fuse.
As I need to sheet the engine area, I've made the twin front guns today using 1/32" sheet balsa soaked in a 50/50 mix of water and amonia
http://www.rcmf.co.uk/gallery/albums/userpics/10010/bdgung.jpg
I get mine from Homebase amongst the cleaning chemicals.
The wonder of a 50/50 mix is amazing.
First step is to cut a length of dowel just under the diameter I needed.
http://www.rcmf.co.uk/gallery/albums/userpics/10010/bdguna.jpg
Now I took some 1/32" sheet balsa and SOAKED it both sides
http://www.rcmf.co.uk/gallery/albums/userpics/10010/bdgunb.jpg
Now slowly wrap the balsa sheet around the dowel, just dont force it, if it wont go, soak it some more.
http://www.rcmf.co.uk/gallery/albums/userpics/10010/bdgund.jpg
Now I wrapped some clear tape around both ends, the tape wont stick to the wood (not only is the wood wet, the amonia attacks the glue), but will stick to itself. Leave for at least an hour or so, until 100% dry. Now before removing the tape, use a sharp knife and trim the two edges till they meet perfectly as a nice round circle. Remove the tape, and whilst holding the tube, apply some CA to the join.
http://www.rcmf.co.uk/gallery/albums/userpics/10010/bdgune.jpg
Just a simple case of gluing the guns in place now, and latter I will give them a coat of epoxy before sheeting over them.
http://www.rcmf.co.uk/gallery/albums/userpics/10010/bdgunf.jpg
I also made up my pushrods as I need to install these before I sheet the bottom of the fuz. I got some CF pushrods (JP) and these nifty ally adapters from Model Images. These ally ferrules are threaded for M3, so nice and easy to join/link.
http://www.rcmf.co.uk/gallery/albums/userpics/10010/bdgunh.jpg
Made a silly mistake, but luckily caught it in time !!!
I had installed and screwed the rear wheel assembly in the wrong place, DOH (in my best ~Homer Simpson voice). As you can see by the red lines, I had to move the unit down, but luckily I could use two of the existing holes. Another bit of luck was being able to eventually remove the rear former so I could get at the thing..... Could have been nasty if I hadnt spotted it now, reminder to brain, think twice next time, before allowing hands to make mistakes...
http://www.rcmf.co.uk/gallery/albums/userpics/10010/bderra.jpg
Still the rest has gone ok, I installed the CF pushrods using 3mm threaded rods, and large 3mm ball links.
http://www.rcmf.co.uk/gallery/albums/userpics/10010/bderrb.jpg
The other end goes to two servos (one for each elevator), although I've used the standard nylon servo arms to get the rods to the right length etc, I'll probably change these for Ally ones latter.
http://www.rcmf.co.uk/gallery/albums/userpics/10010/bderrc.jpg
Nipped down to Mickey-d's for some fodder, and snaffled a hand full of straws, then used 5 of them push into each other to thread the servo wires down to the tail for the rudder servo. Also installed a large Snake for the tail wheel, got to get all this done before I can move on and sheet the rest of the fuse.
http://www.rcmf.co.uk/gallery/albums/userpics/10010/bdabb.jpg
GrahamD, As a fairly oldish timer at 77,I look back at the times long past when I enjoyed making and 'throwing' (hand launching) those Aero's of the past,when ROG came along wow! we felt like real pro's. now I follow your building of the Dauntless I am so excited for your continued excellence in the build and descriptions,Well done Graham.
