James40 Posted February 15, 2010 Share Posted February 15, 2010 Hi folks, Most of my time at work is spent flying between deserts so I get little time at home with good weather to get some flying in. With all my time being spent in areas with superb flying conditions it seems silly not to carry a model around with me. My criteria would be: It has to be portable, something I can put in a bag or a light weight box that will survive being transported around the globe. It has to be easy to fit together and to disasemble, just simple screws would be ideal. It has to be electric, I can't go lugging fuel around with me. And finally, it has to be a simple design so if I have a little accident, it's easy to rebuild and get going again. I saw an advert for a Multiplex pusher prop flying wing that claimed to be folding and fit into a purpose built bag. Thats the only one I've seen that has a transportable claim, but does anyone know of any other good models or kits ? Thanks Quote Link to comment Share on other sites More sharing options...
Romeo Whisky Posted February 15, 2010 Share Posted February 15, 2010 Not sure just how small it has got to be, but the Multiplex Mini-Mag looks like a proper aeroplane, and is fully aerobatic. I take it everywhere on holiday with me. Fitted mine with a 400 inrunner brushless 1800Kv with 7x5 prop and despite having quite an "air force" I probably fly it more than aything else because I can take and fly it anywhere. If you need smaller than that then there is the new MPX wing you mention, or one of the stronger indoor types (Kyoshoso or JP) that can be flown outdoors. Forgot to mention Mini-Mag wing is one piece and can be removed/fitted in a jiffy with just one nylon bolt. Edited By Romeo Whisky on 15/02/2010 16:13:38 Quote Link to comment Share on other sites More sharing options...
James40 Posted February 15, 2010 Author Share Posted February 15, 2010 Thanks RW, I was worried about the tail on a conventional style aircraft, I take it yours comes apart so as not to get damaged in transit ? Size isn't really an issue, we usually fly around with full sized chinooks or similar in the back but it has to be portable enough for me to carry around on top of all my kit. Quote Link to comment Share on other sites More sharing options...
Romeo Whisky Posted February 15, 2010 Share Posted February 15, 2010 No the tailfeathers are glued on with cyano. No problem in a vehicle but if you've got to carry it on top of your kit, maybe not so ideal. The Multiplex Merlin is VERY small and although it is sold as a free-flight glider, loads of folks have adapted them for electric powered RC flight. You could do a search on this forum and RCGroups to see what's been done with the Merlin. You can find the details of all Multiplex models at ... http://www.multiplex-rc.de/ The other possibility is a small EDF jet. I don't do EDF, but maybe someone else could suggest one.Edited By Romeo Whisky on 15/02/2010 18:02:52 Quote Link to comment Share on other sites More sharing options...
Phil 9 Posted February 15, 2010 Share Posted February 15, 2010 An MPX merlin might be good. MPX make a purpose made bag to carry it in. Not sure about the tail feather though. A slow stick might also be one to look at. another option might be to build your own to fit your needs (or customise a artf) A transportable model would be somthing I would be interested in also so I shall be watching this tread to see what turns up. Quote Link to comment Share on other sites More sharing options...
Solid Snake Posted February 15, 2010 Share Posted February 15, 2010 How about this? This for EDF or perhaps a small pusher.It depends on what kind of model you want. A Multiplex Fox conversion is worth considering aswell Quote Link to comment Share on other sites More sharing options...
Andy Gates Posted February 15, 2010 Share Posted February 15, 2010 If you fancy something you built yourself then there are a few plans around for machines which pack into a small case. Piwakawaka is a great machine, all 4 channels and highly aerobatic. It can also fly with floats. The other is a PiaB (Plank in a Box) which is an electric wing. Both are free plans in magazines Edited By Andy Gates on 15/02/2010 19:19:19 Quote Link to comment Share on other sites More sharing options...
Phil 9 Posted February 15, 2010 Share Posted February 15, 2010 James I hope you will let us all know what you decide uponEdited By Phil B on 15/02/2010 20:38:59 Quote Link to comment Share on other sites More sharing options...
IanN Posted February 15, 2010 Share Posted February 15, 2010 Hotchpotch. 36" span old Radio Modeller plan - was available via the X List so presumably can still be purchased through myhobbystore. An easy build. Both wings and tail are banded on, making it easily transportable. Great fun with PAW a 1.49. I'm guessing the powers that be wouldn't be terribly chuffed with you carrying a can of diesel fuel. The electric experts here (i.e. not me) will be able to recommend a suitable alternative set up.Edited By IanN on 15/02/2010 21:28:22 Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted February 15, 2010 Share Posted February 15, 2010 What about using the time to learn to fly a heli? (Assuming, perhaps incorrectly that you can't fly one already!) A 400/450 heli packs away well, smaller ones make even smaller packages. OK doesn't quite fit the "simple" criteria - but you could easily pack a small supply of spares - blades, gears etc. Just a thought - might be your most practical solution. BEB (who doesn't fly helis himself!) Quote Link to comment Share on other sites More sharing options...
James40 Posted February 15, 2010 Author Share Posted February 15, 2010 Some good ideas there, thanks guys. I will let you know what I decide Phil, but at the moment the flying wing style is my favorite purely for it's simple construction and ease of assembly. And the fact that it comes with a dedicated travel bag is a bonus. Quote Link to comment Share on other sites More sharing options...
Mowerman Posted February 16, 2010 Share Posted February 16, 2010 The Multiplex Xeno looks like it is made to your requirements. Folds in half for transport (carrying bag also available). The only drawback is that although the model is only £50 the power set is £127. Perhaps MPX dont really want to sell them or are taking the ####. Quote Link to comment Share on other sites More sharing options...
Phil 9 Posted February 16, 2010 Share Posted February 16, 2010 Xeno looks nice too . I am sure it would not be very hard to find a cheeper alternatve power set. I just bought an mpx brushless power set for my Easy Star. at over £100 pound it was overpriced IMO. there are better value motors out there.Edited By Phil B on 16/02/2010 10:44:13 Quote Link to comment Share on other sites More sharing options...
Former Member Posted February 16, 2010 Share Posted February 16, 2010 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Jonathan Lewzey Posted February 16, 2010 Share Posted February 16, 2010 there's a whole range of small, portable models at www.micronradiocontrol.com and www.robotbirds.com . plenty of different flying wings to choose from although if ts a portable wing you're after, you'll be hard pressed to beat the Xeno with a cheaper motor and ESC. Micron has the radical rc range of quick-build kits though which are small and a bit different. Quote Link to comment Share on other sites More sharing options...
Dave Bran Posted February 16, 2010 Share Posted February 16, 2010 I have travelled with a FlyingWings "Raven". I "built" it using only tape and a single extra, a thin ply plate taped across the belly side of the wing joint. End fences taped on too, so all you need is a roll of 1" reinforced tape. Power set is a 1000mAh 3S, EMax CF2812, APC 7x5, GWS 15A ESC, 2x Supertec Park HPXF....................add that up and you'll see it's not a lot, but performs WAY above its pricing. I happened to have the ESC, but would have bought a Hobby Wing one at under £13, have loads in use, all bullet proof reliable. The cells were under £7, too. Over a £120 for a power set for a small wing?.............you must be JOKING!!!!!! So you get a quite fast power plane with that really cheap motor (under £5!!), has good duration, a superb glide, and has been slope soared up several extinct volcanos in the Canaries with the motor and prop left on, even though I'd designed the wiring and taped on mount to remove it quickly, as the prop parks itself behind the wing and the weight was no penalty. Flew one day for ages in about a force three/four tops and never used the motor once. For Transport, the bare EPP is robust, and the parts pack flat into a suitcase easily. Quote Link to comment Share on other sites More sharing options...
Reno Racer Posted February 16, 2010 Share Posted February 16, 2010 An excellent little plane that is very aerobatic, hand launches and is equally great flat out (80mph) and slow with glider like landings is the Sig Wonder. A properly rugged traditional, but easy build kit it can be packed into a suitcase and uses either a OS 15 or electric set up. I'm currently building one. They have a massive follwoing in the states due to their fun/sport flying quailities. see review here:http://rcplanetips.blogspot.com/2008/11/sig-wonder-kit.html manufacturers website: http://www.sigmfg.com/IndexText/SIGRC66.html Available in the UK for £55 from Pegasus Models in Norfolk. Quote Link to comment Share on other sites More sharing options...
Reno Racer Posted February 16, 2010 Share Posted February 16, 2010 PS Forgot to add, i'm powering mine on a Turnigy C3542 400 watt motor (probably too much power) and a 30C 2200mah 3S lipo. Quote Link to comment Share on other sites More sharing options...
Andy Harris Posted February 16, 2010 Share Posted February 16, 2010 Suggestions: Precision Aerobatics - Electric Shock Flight Line Plans - Googlie Andy Quote Link to comment Share on other sites More sharing options...
Reno Racer Posted February 21, 2010 Share Posted February 21, 2010 Click here to see the Sig Wonder A really great kit, easy to build and a great flyer, from easy fkying sport to agressive racer, all at the touch of a TX switch. Only 18" long and 36" wingspan, easiliy transportable. It onlt takes a few days to build. Available from Pegasus Models in the UK for 55 quid. By the way, if you want a trad kit, the only place I can find in the UK with a large and diverse stock is Pegasus. Quote Link to comment Share on other sites More sharing options...
Reno Racer Posted March 3, 2010 Share Posted March 3, 2010 Another shot of mine, just finished covering, although not yet put the ailerons back on. Wing is removeable, about 37" span. 2 x std servos (Ail and elev), leccy converted for ease or travelling and can be flown super quick or slow; it has a great glide due to think semi wing. Quote Link to comment Share on other sites More sharing options...
Reno Racer Posted March 3, 2010 Share Posted March 3, 2010 Should have said thick wing rather than think!, ruddy laptop keys too small! Quote Link to comment Share on other sites More sharing options...
winchweight Posted March 3, 2010 Share Posted March 3, 2010 What did you go for in the end James? Quote Link to comment Share on other sites More sharing options...
