matt mason Posted July 29, 2010 Share Posted July 29, 2010 last month i bought an easy glider, which i have to say was immensly disappointing. the motor in he box is extremely under powered. ailerons are not as good as thought they would be. anyhow i have been looking at the mx blizzard and the st blaze and was thinking of giving one of these ago. anyone have any experience of either and is the st worth buying or are the installed servo's and motor too cheap? thankyouEdited By matt mason on 29/07/2010 10:04:34 Quote Link to comment Share on other sites More sharing options...
001 Posted July 29, 2010 Share Posted July 29, 2010 Matt, I have both the Easy Glider (electric) and the Blizzard (Slope only). I have no experience of the Blaze. It really depends what you want to do with them, the Easy Glider and Blizzard are like chalk & cheese. If you want more performance out of the Easy Glider you could change the power set, but then what you will have is a glider that will get up to height in a shorter time. It will never roll quickly because of the size of the wing and it was not designed for that. The Blizzard can be quite a handful (but it is extremely good as a nearly hotliner) and Multiplex own power set is very expensive. Quote Link to comment Share on other sites More sharing options...
matt mason Posted July 29, 2010 Author Share Posted July 29, 2010 yeah i have upgraded the easy glider to a brushless set up and 3s battery. you are right about he multiplex power set, price wise you could as easily buy another model. there must be a cheaper alternative..............! Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted July 29, 2010 Share Posted July 29, 2010 hello matt - check out the many 'blizzard' post via the search on the forum here----you'll come across my set up-----for me -i would go blizzardo any time.......you wont be dissapointed....a fun model in every sense...and good value as well.... ken anderson..ne 1.... Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted July 29, 2010 Share Posted July 29, 2010 no experience of the blaze but me thinks it a try and copy the b;izzard effort and with most copies its prob not as good blizzard is expensive but utter quality Quote Link to comment Share on other sites More sharing options...
Allan Bowker Posted July 29, 2010 Share Posted July 29, 2010 Richard is correct, the Easy Glider and the Blizzard are completely different aircraft to fly.One being a glider and the other being a hot liner! The Blaze looks identical to the Blizzard and I would imagine there is very little difference between them (depending upon power set). I have a Blizzard with the Multiplex tuning set installed and she is a very slick mover with unlimited vertical. Don't let her get too slow or she will bite you, stall and most probably crash. The blizzard is for the experienced pilot, she's taught me much.I made the mistake once of making a full power on dive which led to a speed stall, that the aircraft would not pull out of. Thankfully I got away with it at the very last second. Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted July 29, 2010 Share Posted July 29, 2010 blizzard is a warm liner at best and me thinks your servos struggled to pull the elevons at that speed never heard of a speed stall in level flight and my blizzard does full power dives no problem (and yes i have the tunning set up) the only problem i have is the wing flutter i now get in full power dives, i never used to get it but i think it comes with age and the foam starts to get a bit soft and flexes more than when new Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted July 29, 2010 Share Posted July 29, 2010 the forums that have tried it say its nowhere near as fast as the blizzard so thats a tepid liner then ! Quote Link to comment Share on other sites More sharing options...
Allan Bowker Posted July 29, 2010 Share Posted July 29, 2010 No, the speed stall was not in level flight, it was in a -90degree dive.I thought about the servo's not being up to the job too but they are MG and are well over specified for the job. I've often read people calling the Blizzard a 'warm liner' but have resisted confusing the category by referring to it as a 'hot liner'. I think it only serves to confuse. What's next 'luke warm' ? Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted July 29, 2010 Share Posted July 29, 2010 a clubmate has a Blaze, and for the price it is very impressive, All servos, esc and motor come installed and the finish of the foam is smooth so it looks better if nothing else. I've not seen a Blizzard, but the Blaze is very aerobatic, and I would have thought more than fast enough after an Easyglider. Quote Link to comment Share on other sites More sharing options...
matt mason Posted July 29, 2010 Author Share Posted July 29, 2010 firstly thankyou for the replies. i must say not a novice to this hobby. i bought the easy glider as i just wanted another powered glider. i fly an edge 540 most of the time and have a 3.5 metre L S 3 glider i would very much like to convert to electric motor. i don't have the knowledge to slope this thing and would most likely prang it. i do like the look of the blizzard its just that the recommended power systems are expensive.i agree its a hotliner from what videos i have seen of it on utube.i just don't want to buy the blaze to be sucked into another plane knock off, main reason why iasked. i had a mx2 for a while but no where near as impressive as the edge that i have now, which is also electric. anyway we can forget the easy glider as i put that into a very fast dive from a good altitude today and pulled up(well idid the plane didn't)BANG, CRUNCH AND MANY OTHER INTERESTING SOUNDS... enough said...!!!! CHEERS MATT Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted July 29, 2010 Share Posted July 29, 2010 hard lines about the easy glider------the blizzard i fly has a turnigy/250 watt outrunner in that cost me £20.00...the m/g servo's i'm using cost me £9.00 each...matt-get up sharp on fri/sat and wizz down to your LMS......and get a blizzard......check out the post's and build set up thread's and bingo.......one happy matt.... ken anderson...ne...1.. Quote Link to comment Share on other sites More sharing options...
001 Posted July 29, 2010 Share Posted July 29, 2010 Matt, As some people might know I am a big fan of the Blizzard. Please don't think that the foam is the same as the Easy Glider. It is much denser and has a smoother surface finish. It is aso very strong. I have bounced mine off the rocks at The Orme a few times. Fitting the fibreglass rods is a bit of a pain, but worth it in the end. Quote Link to comment Share on other sites More sharing options...
matt mason Posted July 29, 2010 Author Share Posted July 29, 2010 so what you saying then chaps?........ .....buy a blizzard then ...? i may just do that !!! i have a box of servosof different sizes and about three speed controllers. so all i need is a motor.. ill have to tell the missus another story about why i need another model....AND WHY SHE DOESN'T NEED MORE CLOTHES... .. or i can just flannel her with over exagerated complements again.. .IF SHE READS THIS I AM A DEAD MAN!!!! CHEERSEdited By matt mason on 29/07/2010 20:18:18 Quote Link to comment Share on other sites More sharing options...
manuel lombard Posted July 29, 2010 Share Posted July 29, 2010 ken have you ever considered sales? after reading your post, you have gotten me hyped up to buy a blizzard!! you sir are a LHS dream!! Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted July 29, 2010 Share Posted July 29, 2010 go on manuel--get one-you cant take it with you(the dosh)...........the blizzard is a load of Fun.........there are a few who have tried to copy it since it came out......but for quality etc...it cant be beat......... head salesman ken anderson(not)........ Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted July 30, 2010 Share Posted July 30, 2010 I have had my blizzard for some time now and thrashed the pants off it most consecutive loops out of it on the glide is 42 and its very locked in just don't slow it up too much, it does not retain the speed like a true hotliner, if fact it bleeds off very quickly but it is a great smooth aerobatic machine yes the kits costs a bit but you dont have to buy the multiplex setup (although it is great despite the price) as for the build, when you come to do the fiberglass rods (the thin re-inforcing ones) can i suggest an easier method measure and cut rod to length, trial fit tack one end down with thin cyno, press down tack middle and then end with thin cyno and when happy the rod is flush down then fill rest of recess with thin or medium, and spray with kicker much less mess Quote Link to comment Share on other sites More sharing options...
jez Posted July 30, 2010 Share Posted July 30, 2010 my blizzard is also fitted with the power set , fab performance , but just watch them slow turns which seem to include a wing drop !!!!! but all said fab performer well chuffed with it jez Quote Link to comment Share on other sites More sharing options...
A.A. Barry Posted July 30, 2010 Share Posted July 30, 2010 When Lookin at this I thought you where going to moved to another country, Blizzard ...UK Blaze.........Africa/Sudan/Alice Springs But , it's a model A.A.Barry Edited By A.A. Barry on 30/07/2010 13:26:03Edited By A.A. Barry on 30/07/2010 13:45:27 Quote Link to comment Share on other sites More sharing options...
Bill_B Posted July 30, 2010 Share Posted July 30, 2010 I've had both the Blizzard and the Blaze and both have their merits and faults. The Blizzard has a slightly tougher airframe and a higher wing loading meaning a faster flight envelope, though beware of aileron flutter at extreme speeds. The Blaze's wings can be made to break down into two halves for transportation along with a removeable tail, and the servos can be easily removed for replacement if neccessary, but beware of soft elevator response at high speeds. IMHO the Blaze is the better looking and sweeter flying of the two, is better value for money, and is easier and quicker to get in the air. Also, if the Blizzard's spinner assembly is fitted to the Blaze, it matches the colour of the decals perfectly and provides additional cooling to the motor. Quote Link to comment Share on other sites More sharing options...
matt mason Posted July 31, 2010 Author Share Posted July 31, 2010 cheers for all the info chaps matt Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted August 1, 2010 Share Posted August 1, 2010 Matt, I had a look at a Blaze in my LMS yesterday. The wing tips are very thin, seemed poorly protected and were damaged in the box I looked inside so do check contents before purchase if you go for the Blaze. Quote Link to comment Share on other sites More sharing options...
James M Posted August 1, 2010 Share Posted August 1, 2010 Hi Have to admit that my tips where slightly warped out of the box, a bit of glass weave tape and white parcel tape and they look good as new - wished I'd used orange tape to see the plane more clearly in flight Also the ESC gets HOT, think it is the BEC side of thing that is causing it - have a spare E-flite 30amp Switched bec, from an old Parkzone plane, that I'll try - well if I can find the soldering iron, need to change the connector to a deans. But it is a great airframe - I have a blizzard that is still in the box awaiting the time to build, ill health and a lack of free time is stopping me, it is why I got the Blaze - Ready built. Quote Link to comment Share on other sites More sharing options...
matt mason Posted August 1, 2010 Author Share Posted August 1, 2010 i think after consideration i will go for the blizzard. i have props, esc's and servo's, just need to sort out a motor .was looking at the motors in airtek . anyone else used these? Quote Link to comment Share on other sites More sharing options...
Delta Whiskey Posted August 1, 2010 Share Posted August 1, 2010 I have flown the blizzard of another club mates, and it is fast enough on the tuning power set, but for an all ready to go option (just add your tx) the Blaze is the one I'm considering, but although it's often called a warmliner rather than a hotliner as is the blizzard, the blaze is capable of going vertical I'm told from an owner whose just got one, from a hand launch which sounds great to me for just over a 100 quid. I have the same manufactures (ST Model's ) MX2 and am pleased with that too ! Quote Link to comment Share on other sites More sharing options...
