Scruffmeister Posted October 29, 2010 Share Posted October 29, 2010 Hi All, Am building a Weston Cougar 2000 and am trying to decide what servos to buy. The manual recommends Hitec kit for control surfaces as follows: Elevator/Ailerons HS 625MG (3x ~£25)Rudder HS645MG (1x ~£25) This is around ~£100 of servos not including throttle control. Can anyone recommend cheaper servos that I could use that will still be sufficient? Thanks, Quote Link to comment Share on other sites More sharing options...
Steve W-O Posted October 30, 2010 Share Posted October 30, 2010 If you look up the size and specs of the ones you have given, then look on HKs site for ones the same size and spec, it could well save you half of that. I bought some metal gear digital servos from them for only about £4 each (9g size) Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted October 30, 2010 Share Posted October 30, 2010 iv'e been flying my cougar 2000 for 5 year's now...using futaba 3001's.....recently i renewed the elevator -- using a hitec BB one........the top notch one's are a bit over the top for club flying.... ken anderson ne...1. Quote Link to comment Share on other sites More sharing options...
Brian Cooper Posted November 4, 2010 Share Posted November 4, 2010 Beware of using tiny servos. A friend of mine had a Cougar with these fitted and he was a bit timid and content to just trundle round the sky doing gentle circuits. But then he handed the thing to me to "see what it could do". I didn't know he had got tiddly servos --- and I stripped the gears in every one of them in five seconds flat. My own Cougar has been flying for the last 9 years without problems. It is fitted with a mini servo on the throttle, but it has got standard Futaba 3001s on the ailerons and rudder. The elevator is moved by a standard size digital jobby, and the response is definitely sharper to stick inputs than with a "normal" servo. All driven by a 6 volt battery pack. If you're planning on pushing a Cougar to its limits, for gawd sake don't use cheap, substandard servos. B.C. Quote Link to comment Share on other sites More sharing options...
Craig Spence Posted November 4, 2010 Share Posted November 4, 2010 As everyone has said above Futaba 3001's will be fine, you dont want to be putting that much money into a fun fly unless your going into competetions in which case you may want digitals. I have a Frantic with a built up wing and this gets hammered around on these servo's quite happily, I always used to over spec my models but for the size of the model there really is no need. If anything I would put higher spec ones in for the rudder and elevator and thats it, these parts will see the most weight for the type of flying you will be doing. I still want a Cougar myself, but with current projects its on the back burner, plus I think ill go with the Fusion first (the new one), love fun fly's. All the best with it. Quote Link to comment Share on other sites More sharing options...
Andy Green Posted November 4, 2010 Share Posted November 4, 2010 You will need good servos for the ailerons, they are big and the flight loads will be high. At first I used JR517's but the ailerons would hunt on defelction, what I mean here is they would overshoot their stop point and then return to desired position. For the last 8 years I've used : Ailerons:HiTec HS645MG Elevator: SuperTec S03/2BB Rudder: Futaba S9001 Throtle: SuperTec S03 Hope this helps. AEdited By Andy Green on 04/11/2010 10:17:07 Quote Link to comment Share on other sites More sharing options...
Richard Wood Posted November 4, 2010 Share Posted November 4, 2010 Giantcod have Towerpro 5010 6Kg standard size servos at £4 a shot. GCod servo Plenty of 5 star reviews on the site for these - the two I have are good. Quote Link to comment Share on other sites More sharing options...
Andy Green Posted November 4, 2010 Share Posted November 4, 2010 You will get what you pay for. This link discusses the Tower Pro MG996 servo. I bought 4 of these from servoshop, they are noisy have very high current drain and I'll never use them again. You pay your money and takes your choice. A Edited By Andy Green on 04/11/2010 10:48:40 Quote Link to comment Share on other sites More sharing options...
Richard Wood Posted November 4, 2010 Share Posted November 4, 2010 I bet TP's marketing department don't use that. Paradoxically, the only radio gear I've had a major problem with recently was a top name - branDX. Quote Link to comment Share on other sites More sharing options...
