r6dan Posted December 1, 2010 Share Posted December 1, 2010 this one,I am building Tims Gonzales,I know its waaaay more power than I need,but I have one and it will save spending money i dont have! So can I use it as a normal motor not in a EDF,and strap it to the front of a plane? Edited By r6Dan on 01/12/2010 22:33:18 Quote Link to comment Share on other sites More sharing options...
Eck Posted December 1, 2010 Share Posted December 1, 2010 You could probably get away with using it in a pusher jet with a 4.75 - 5 inch prop, but it won't turn a big prop without burning out, mate! If you decide to try it, let the wattmeter guide you! (46A max continuous, 55A Max 10-second burst) Probably be nice on a Jamara Roo...... Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted December 1, 2010 Share Posted December 1, 2010 In theory yes, but on 3s battery it will try to run at around 40,000 rpm, so thats a very small prop. Or fit a gear box, but in reality a lower KV outrunner would probably not cost any more than a suitable gearbox. What plane is it for. Quote Link to comment Share on other sites More sharing options...
r6dan Posted December 1, 2010 Author Share Posted December 1, 2010 I was looking at a 5x5 or 5x4.5 prop maybe,how come it won`t turn a larger prop?Can you tell I am an IC engine man!! That motor was/is for my GWSa4 edf jet thingy but I was going to try it out on a pylon racer style plane. Edited By r6Dan on 01/12/2010 22:49:49Edited By r6Dan on 01/12/2010 22:50:35 Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted December 1, 2010 Share Posted December 1, 2010 Dan...have you looked at the leccy newbie threads like this one ? Quote Link to comment Share on other sites More sharing options...
r6dan Posted December 1, 2010 Author Share Posted December 1, 2010 Hi Tim,er yes I have...and I still can`t get my head around it,IC yes its simples but electric baffles me I`m a bit thick me....... Edited By r6Dan on 01/12/2010 23:29:31 Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted December 1, 2010 Share Posted December 1, 2010 I'm sure you're not thick at all Dan - and I fully understand that to the inexperienced electric flight can be a bit difficult to grasp. We have done several articles to try and help people such as yourself, and many of them are published here on the forum, after they have appeared in the mag.Have another read of this one for instance, and see if it might help. Sometimes I find I need to read something several times myself before the penny drops...if at all. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted December 1, 2010 Share Posted December 1, 2010 PS, the reason you cant just stick a big prop on a motor designed for a small prop ( or fan ) is simply that it will overload it, overheat and burn out the windings.Try towing a 6 berth caravan with a high revving 2 stroke racing bike and see what happens. Same idea ...not that hard to grasp is it ? Quote Link to comment Share on other sites More sharing options...
John Privett Posted December 1, 2010 Share Posted December 1, 2010 In a nutshell Dan, an electric motor will always try to run at a certain speed (which varies with the voltage it's running on.) The more you try to slow it down - eg. by putting a bigger prop on - the harder it works to try to reach that natural speed. And it does so by drawing more and more amps until either the motor, the ESC , or possibly the battery go "phut" and let out the magic smoke. It's the Kv rating that tells you what that natural speed is. That figure is the speed per volt. So this 3600 Kv motor with a 3-cell LiPo - call that 11 volts to keep the figures simple - will try to run at a speed of 3600 x 11 = 39,600 rpm. Or "around 40,000 rpm" as Frank said. Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted December 4, 2010 Share Posted December 4, 2010 Hi Dan . You can buy a motor for very little these days for example Giant cod sell cheap bell motors that will turn 8 or 9 inch props . Or swap your motor with someone who flys more EDF , for a suitable motor . Phil Quote Link to comment Share on other sites More sharing options...
