David Gilder Posted February 4, 2011 Share Posted February 4, 2011 I remeber that episode like I had only just watched it. It must have been 20 years ago in reality though!!!! Looking forwards to the build. Dave Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 4, 2011 Author Share Posted February 4, 2011 it flies.knocked this up to check out the idea,glides lovely across the living room. Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted February 4, 2011 Share Posted February 4, 2011 Brilliant! Well done Tony. That Anderson bloke knew a thing or two didn't he? Just the atomic engines to perfect now. I can see your biggest issue being the weight of the EDF's at the back, needing everything else right at the front to get the C/G. But at least you know a good C/G now. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 4, 2011 Author Share Posted February 4, 2011 cog on the chuck glider is just 1/3 of the main wing.so it will be a balancing act with batteries, servo's and the rest to keep it in balance. Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted February 4, 2011 Share Posted February 4, 2011 Where's the elevator control going to be Tony? Conventional at the back? Or Canard using the front winglet. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 4, 2011 Author Share Posted February 4, 2011 canards for the elevator control.ailerons on the main wing.conventional rudder.retracts now if i could build 3 remote control elevator cars like in the thunderbirds episode. Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted February 4, 2011 Share Posted February 4, 2011 Taking off from three cars would be impossible enough. Landing on three - that I would like to see! Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 4, 2011 Author Share Posted February 4, 2011 your not the only one. Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted February 5, 2011 Share Posted February 5, 2011 Two things:- 1. Looks like Thunderbirds might be go for a new series. By Gerry Anderson thank goodness. Thunderbirds new series 2. Here's 8 minutes from the start of the Firefly episode. Careful, don't go getting too nostalgic now The whole long intro is here, I just remember the anticipation of a new episode so well! Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 5, 2011 Author Share Posted February 5, 2011 mk2 test vehicle flown.i altered the rear to be more like the actual plane.bit of weight on the nose and she glides 20 to 30 ft from a hand launch.:clap: Edited By tony bennett on 05/02/2011 15:22:33 Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 6, 2011 Author Share Posted February 6, 2011 The build begins.started on the lower front section of the fuselage today. first 3 formers cut out and glued in place.i have had to design a staggered joint so i can make the fuselage in 2 halves as 3' long balsa is not long enough. he he. Quote Link to comment Share on other sites More sharing options...
Alan Cantwell Posted February 6, 2011 Share Posted February 6, 2011 how about Zero X? that actually was an r/c model, in its comlete form, of coarse, not the lifting body joining up bit wishing you well with the Fireflash project, Tbird 2 has been done, it wallowed and dutch rolled like a drunk at 2 in the morning Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 7, 2011 Author Share Posted February 7, 2011 Bit more done today.cut and made the rear section of the lower fuselage.joined the 2 sections together.138cm long, so not huge.i need to plank the rest tomorrow, then i can turn it over and start on the wings..i plan to fit the wings and then build the top half of the fuselage with the wings in situe.fingers crossed. Quote Link to comment Share on other sites More sharing options...
Wolfie Posted February 8, 2011 Share Posted February 8, 2011 Out of interest, whereabouts did the CG turn out on the chuckie?I guess the fuse must have considerable lifting effect. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 8, 2011 Author Share Posted February 8, 2011 on the chuckie the cog was 1/3 of the width of the main wing..yeah it's partly a lifting body. Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted February 8, 2011 Share Posted February 8, 2011 Looking good Tony. Can't wait to see it finished! BEB Quote Link to comment Share on other sites More sharing options...
Lee Smalley Posted February 8, 2011 Share Posted February 8, 2011 Tony if this works out im having one !!!!! Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 8, 2011 Author Share Posted February 8, 2011 little bit more done today.looks like a boat.i think the mk2 will have to be done differently. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 11, 2011 Author Share Posted February 11, 2011 Quote Link to comment Share on other sites More sharing options...
Eck Posted February 12, 2011 Share Posted February 12, 2011 Wow! that looks stunning! Wouldn't expect it to be a floater, though. Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted February 13, 2011 Share Posted February 13, 2011 The wing loading will be high - that's going to go like the bats out of hell! BEB Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 13, 2011 Author Share Posted February 13, 2011 well it is a hypersonic aircraft. as long as its not an unguided missile, we will be ok. i hope. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 17, 2011 Author Share Posted February 17, 2011 I thought i'd give you all an update . i've not given up on the build yet. Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted February 17, 2011 Share Posted February 17, 2011 It looks great Tony, I really do hope it works. If not from EDF's, I bet it would work from a slope? Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 17, 2011 Author Share Posted February 17, 2011 might end up chucking it from off of a cliff. need to source 2 small edf's next. the hunt is on. Quote Link to comment Share on other sites More sharing options...
