Richard Wood Posted April 21, 2011 Author Share Posted April 21, 2011 There's probably nobody else using Poly C for their Webbit, but for completeness a post on finishing with it won't do any harm to add to the helpful info on PC on other threads. It's a great way to get a good surface for a paint job & is firmly recommended for future builds. 8 thin coats were brushed on the fin & tailplane, with a light fine sanding between coats after the second. The parts were left to fully harden overnight after the last coat. At this stage the surface didn't look very good with brush marks & small bits showing. Painting straight onto this would give a poor result. With 2400 extra fine wet & dry paper used wet around a sanding block a very smooth finish can be achieved with just a little effort. All brush marks,bits and other nasties disappear to give a near-flat surface. Don't use anything coarser or it will sand away too much Poly-C. Keep the wet & dry paper well lubricated with water & occasionally clean off the work with a tissue to check progress. The wood is completely sealed of course so there is no danger of the water swelling or warping it. Spray on a primer if desired & then build up thin coats of spray paint for a near flawless finish. Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted April 21, 2011 Share Posted April 21, 2011 Nicely done Richard, really clear information. CheersDanny Quote Link to comment Share on other sites More sharing options...
Richard Wood Posted April 21, 2011 Author Share Posted April 21, 2011 Thanks Danny mate. Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted April 21, 2011 Share Posted April 21, 2011 Great work Richard. Very clear and step by step. Just what was needed. Thanks. And what's more....she's looking really good! BEB Quote Link to comment Share on other sites More sharing options...
Richard Wood Posted April 21, 2011 Author Share Posted April 21, 2011 Thanks BEB Quote Link to comment Share on other sites More sharing options...
Andy Muckley Posted April 28, 2011 Share Posted April 28, 2011 Hi Richard never covered before, well only repairs and the odd patch, and found this realy good and will be poping back here as i am about to start covering tomorrow. I have been to a demo that Danny put on for a club night and he did a superb job and hope i remember enough of that covering demo and with the help of your great thread to do a half decent job. Thank's again Quote Link to comment Share on other sites More sharing options...
Richard Wood Posted April 28, 2011 Author Share Posted April 28, 2011 Thanks a lot Andy - glad it's helped. I'll try & post some pics of the fuselage covering over the weekend. 4 work- free days coming up, so time to crack on with it. Any questions or comments - just ask & I'll try & help. That lad Danny is always a great help t'boot. Cheers Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted April 28, 2011 Share Posted April 28, 2011 Your wing looks gorgous the way it catches the light in that photo Richard. Thanks for all your effort on this I'm sure that as well as those that have posted many others of the nearly 60 WebBit builders are grateful for an excellent clear demonstration with lots of useful tips. Well done mate. BEB PS Are you planning to get along to Greenacres? Quote Link to comment Share on other sites More sharing options...
Big Bandit Posted April 29, 2011 Share Posted April 29, 2011 Hey, BEB, Rich, Mine catches he light, just before it hits the deck .Chris. Edited By Big Bandit on 29/04/2011 21:23:35 Quote Link to comment Share on other sites More sharing options...
Richard Wood Posted May 2, 2011 Author Share Posted May 2, 2011 Cheers BEB I was really hoping to make the Greenacres day, but it looks like that weekend will be taken over by family duties. I hope it goes well - I'm sure it'll be one to remember. One more post on covering to wrap this up (oops!). I found the concave fuse top & btm a slight problem as the film tends to pull in odd directions. A few slits in the covering made it a little easier here : Fuselage top film going on. Also the inward curve at the nose top can be awkward to cover and it's very easy to dent the balsa with the iron. I carefully used the heat gun here, sealing the film down by pressing with a finger. The fuse was decorated in a simple way with strips of Solartrim.Instead of using the soapy water technique as before I used the method shown in the pictures - by progressively peeling off the backing. The piece applied first (red) was stretched into correct position & this then provided a guide for the orange & yellow. Nothing too fancy here - but it should help visibility. The canopy was cut out with a compass cutter. One thing worth noting - if using the soapy water technique make sure any exposed wood likely to get wet is sealed or it will swell up. A few bits & bobs left to do & it'll be ready for the off! Cheers Edited By Richard Wood on 02/05/2011 17:54:23 Quote Link to comment Share on other sites More sharing options...
Pablo Posted May 6, 2011 Share Posted May 6, 2011 This may be a silly question to all you very experienced builders - but when covering a fuselage, is it better to do bottom first, then sides, then top. Or some other combination? Some guidance needed please. Paul Quote Link to comment Share on other sites More sharing options...
David Davis Posted May 6, 2011 Share Posted May 6, 2011 Yes Quote Link to comment Share on other sites More sharing options...
Big Bandit Posted May 6, 2011 Share Posted May 6, 2011 Posted by Paul Harmer 2 on 06/05/2011 01:16:47:This may be a silly question to all you very experienced builders - but when covering a fuselage, is it better to do bottom first, then sides, then top. Or some other combination? Some guidance needed please. Paul Hi Paul, No it's not a silly question. I tend to do the, bottom, top, sides, but that's just my way and seems logical and the way I've always done it. In saying that I'm not the best at covering with film by a long chalk, but I get by the main problem is trimming the overlap cleanly before finally ironing down. Cheers, Chris.Edited By Big Bandit on 06/05/2011 10:09:45 Quote Link to comment Share on other sites More sharing options...
Richard Wood Posted May 6, 2011 Author Share Posted May 6, 2011 Hi Paul, As Chris says, standard practice is to cover the fuselage top & bottom before the sides for no other reason than it looks better on the finished model. Use a new, sharp blade for cutting film. Trimming film or Solartex with a blunt blade is not a nice way to spend an evening & results in ragged edges - I know this because I've done it too often by trying to re-use old blades. Edited By Richard Wood on 06/05/2011 19:52:17 Quote Link to comment Share on other sites More sharing options...
Pablo Posted May 7, 2011 Share Posted May 7, 2011 Richard, Chris and David Thanks for the help, I feel a bit more confident about what I am about to do now! Regards Paul Quote Link to comment Share on other sites More sharing options...
