Spice Cat Posted July 20, 2011 Share Posted July 20, 2011 Covering irons. I know I have little practice with said item, but it seems quite awkward to use particularly for fine work. The long handle makes for big errors at the other end. I have seen a few photos of modellers using a domestic iron and a smaller version of this suit me. Does anyone have this problem, are there any other designs on the market and apart from practice; any hints or tip. Regards. Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted July 20, 2011 Share Posted July 20, 2011 I find the "traditional" covering iron fine to be honest - although I also know of lots of folks that just use an ordinary clothes iron perfectly sucessfully. Some pointers: Use a medium heat setting to attach the covering, then crank it up to do the shrinking phase. I find its much easier to to it like this in two stages rather than straight off in one go. I also favour the use of a sock - it seems to spread the heat more evenly and protects the underlying wood. BEB Quote Link to comment Share on other sites More sharing options...
Kevin Fairgrieve Posted July 21, 2011 Share Posted July 21, 2011 Posted by Biggles' Elder Brother - Moderator on 20/07/2011 22:47:45: I also favour the use of a sock - it seems to spread the heat more evenly and protects the underlying wood. BEB I find that with a sock I tend to get better adhesion. The only dowside is the glue sometimes attaches itself to the sock. Multicoloured sock anyone? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted July 21, 2011 Share Posted July 21, 2011 I use both, mainly the normal iron but sometimes I use a domestic iron for shrinking as it covers a bigger area. There are small irons available for detail work but I find that they don't hold enough heat. Quote Link to comment Share on other sites More sharing options...
Ben B Posted July 21, 2011 Share Posted July 21, 2011 I use a big domestic one for large areas I use a cheap "travel iron" off Ebay (which is actually tiny- base plate about 10*15cm) for the smaller stuff. Quote Link to comment Share on other sites More sharing options...
Spice Cat Posted July 21, 2011 Author Share Posted July 21, 2011 Like the idea of the travel iron. I believe that the wife may have such. Practice, practice, practice. Quote Link to comment Share on other sites More sharing options...
Russ P Posted July 21, 2011 Share Posted July 21, 2011 For fine detailed work I use an iron with interchangable heads, 1 approx 10 mm wide, + 1 domed head great for getting into those ackward places. I think its made by prolux, but looking at SMS website they do not list one. I did buy it a few years ago. Quote Link to comment Share on other sites More sharing options...
Wiltshire Flyer Posted July 21, 2011 Share Posted July 21, 2011 For years i used a trusty little travel iron but did find sometimes that it would not get into some corners but worked ok for me, then it broke..... so when i covered the hawk.. (twice) i had to use Mrs DF's full sized iron, worked ok but heavy and not as easy to do the fine work. I do find that modeling irons are in my opinion too expensive for what they are, i know it's probably because you don't buy one every year so they have to make their money... but still i can't justify the expense, i'll just struggle on lol Quote Link to comment Share on other sites More sharing options...
i12fly Posted July 22, 2011 Share Posted July 22, 2011 Slightly off from the original question. but do make sure you don't overheat the film otherwise it will sag after a few weeks, then you tighten it up with more heat which only lasts a few weeks again, although polyester types are much better (and more expensive). If you can, check the temperature with a thermometer, ideally an infra red type but allow for the fact that these give a more accurate temp than the crappy contact type so generally aim about 5deg C lower than the temp recommended by the film manufacturer (found after lots of experiments!). If you don't get a thermometer then do some trials on scrap. It is better to under heat than over, you can always increase the temp if necessary, I never use a heat gun now as you invariable overheat the film and I've got some saggy covered models to prove it Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted July 22, 2011 Share Posted July 22, 2011 I use Solarfilm Supershrink Polyester. Never sags and I tend to over heat it. Doesn't even sag in roasting hot sun. So it is safe even on that one day in the year. Quote Link to comment Share on other sites More sharing options...
Spice Cat Posted July 22, 2011 Author Share Posted July 22, 2011 Thanks for taking the time to reply. It just so happens I have an infra red thermometer and never considered using it. I'll let you know how I get on and post a few hopefully wrinkle free photos. Regards Quote Link to comment Share on other sites More sharing options...
