Alula Evo
Devon Flyer
I now have an Alula Evo in my hangar, bought direct from Dreamflight in the States. Cost, including servos, battery and P&P was £71. It took about 2 weeks to arrive.
First impressions? Very nicely packaged kit. Clever design. Quick and easy build.
I've painted it very sparingly with Tamiya acrylics in a quasi black headed gull style - should be interesting on the coastal sites........
Maidened it the other day on a flat field and then flew it on the slope for the first time 2 days later in about an 8mph Southerly.
Took a lot of test glides to get it dialled in on rates/expo & trims. SLGs very easily - straight as a die. Flies in very little lift but does not like being pushed in these conditions.
I can see this one being taken on most sloping trips, just in case the wind decides not to play ball.
How many other guys on the forum have an Alula Evo and what are your thoughts?
You're correct about it being sensitive.
It took me about 20 - 30 test glides on a flat field to get the CoG, the rates and the trims to a workable point.
Another hour on the slope and about 10 seperate flights got it somewhere close to where it should be.
This plane is advertised as being suitable for novice to expert, but I doubt very much whether a novice would be able to get one set up properly before losing patience and/or dinging it!
I used to have a Mini Weasel, which was very similar to set up, but not quite so sensitive.
That said, I'm happy with the set up I'm now running and am looking forwards to many happy hours with it.
I love my Alula, I have set my CofG as per instructions and set my throws to the max with masses of expo. Mine regularly has stick time with the kids in our school club(pic below), as long as they have had a bit of stick time with a chevron they cope well. Mine is still all white, its colour scheme has been on the to do list for a while.
here's mine out of its cage in the house..... i painted it/her with acrylic..paint-gave it/her a coat of clear water based varnish..to proect the feather's!.....the AUW..is now 7oz and it/she fly's like a goodin......the handbook recommends 0-10mph.........last week she was up in 20 mph at our local HTP cliff site.... no prob's.....next day up in 7 mph ....
ken anderson ne...1 alula dept.
this is my 1st post, please be gentle !!
i am Am one of those novices.
I fly hangliders and got the alula to research new sites i might find my self on.
I have a couple of beginners type questions.
1) the right hand servo occasionally sticks in up postion. few stick wiggles and its back in sync again. (flaps are free)
Any thoughts ?
2) how do i set my mixing ratios ? i have futaba skysport ss3. I think its fixed with no manual option
3) In a similar vein how do i restrict the flap movement mentioned above to 3 mm or there abouts ?
any offerings gratefully listened to !:.
graeme
hello graeme....you have to have a radio tx with the facility to make the two servo's work as one for the elevator function....an electronic mix.....both move the elevators up or down...and again you need the facility to restrict the movement as well......allthough you could do it mechanically...from memory i dont think the sky sport tx can do electronic mixing?......hope this is some help for you...fire away with any more Q's......
ken anderson ne..1 ... alula dept..
updated....had a look on S Webbs Servo shop site and they list the TX  and it  has elvon mixing .... so you should be OK...... the sticking servo will need sorting
Edited By ken anderson. on 13/08/2011 20:41:49
.very prompt ! thankyou Ken
.you have to have a radio tx with the facility to make the two servo's work as one for the elevator function....an electronic mix.....both move the elevators up or down.MINE DOES DO THIS IE BOTH UP OR DOWN FOR PITCH OR OPPOSITE FOR ROLL .and again you need the facility to restrict the movement as well...CAN YOU ELABORATE ON THIS PLEASE. WHAT IS THE RESTRICTION ACHIEVING AND WHERE DOES IT OCCUR ?...allthough you could do it mechanically...from memory i dont think the sky sport tx
can do electronic mixing?..IT HAS A LITTLE SWITCH ON FRONT FOR 'VTAIL / ELEVONS...SO I THINKS IT DOES.
THE PLACE I GET REALLY CONFUSEDIS IN THE ALULA GUIDANCE IT SAY...
'SET INDEPENDENT ELEVATOR TROWS TO 20% AND AILERON TO 60%'
i HAVE NO IDEA WHAT THAT MEANS :< ?
IT GOES ON TO SUGGEST ...'GOOD RULE OF THUMB IS SET ELAVATOR RATE TO 1/3RD TOTAL AILERON RATE (IE DEFLECTION)..?
DO YOU THINK I NEED A MORE FANCY TRANSMITTER ?
MANY THANKS
G
Hi Graeme
I think that you need a more sophisticated transmitter to get the best out of the Alula - certainly one where you can adjust the the end points of the servo travel (EPA).
One that provides exponential (EXPO) and dual rates would also be beneficial.
I would think that something along the lines of a Futaba 6EX would be the bare minimum to get an Alula set up somewhere near properly.
Hi Graeme, in your first post you mention that you might find yourself at new sites. The Skysport SS3 you have is a 35MHz. If you're likely to be unfamiliar with the sites I think it would be best if you got a 2.4GHz transmitter in case there are any other model flyers within range that are using 35MHz. This will save any possible inadvertent clash of frequencies.
graeme...my alula has aprox 3mm each way for the elevator movement and aprox 6-8mm for the aileron...i dont use expo...and find this ok.....dont worry too much about exact settings...at the end of the day - use what you are comfortable with..... and as said they like many flying wings are sensitive to the c of g setting---its worth adding/taking bits of lead out to get it set......
ken anderson ne...1 .... alula dept.
UPDATE
what a greta and helpful set of replies. Many thanks. you have saved me a pranged wing I think :>
I just got in from a couple of hours playing around with all the helpful suggestions.
Big thanks to everyone.
She is now flying straight and level from an SAL.
Needed a touch off down elevator and a touch of right turn on the trim settings to not balloon up or peel off left
Re control stops;-
I blue tacked some matches across my TX to limit deflection to 3 mm each way at the trailing edge of the wing
In roll none were required as full side to side gave the suggested 8mm.
I needed to add a ten and 5 p piece right on the nose to get the COG to be where the dimples are.
So thank to you guys I AM GETTING THERE :>
ANY suggestion of nose down from me on the stick and she 'tucks'.
The handbook suggests this indicates more nose weight required.
Current weight is 180gm .
Will get some fishing weights tomorrow and also move control rods one hole closer to the pivot point on the servos to minimise my heavy beginners hand.
Re sticky servo. :- I have noticed this often (but not always) happens after a heavy landing. If ,I flick the offending unit with my nail it squawks and returns to centre.
question- can i put a drop of sewing machine oil on to help it free up ?
They squawk a lot. . is this normal ?
Ah the joys of begginerdom !
g
well done graeme--- i love the matches/blue tack...that wins first prize in my book........you are now an honoury member of the HTP.....the servos squawking suggest they are past their best ... treat it a couple of new ones..they dont need to be expensive ones.....
ken anderson ne.... 1.... alula dept
Thanks ken.
the servos are brand new from dream flight, so maybe i will ask their opinion.
I am not able to fly again till septtember 7 so perhaps they could send some replacements or something during that time.
do you know roughly how long the batteries in the glider will last for betweeb charges?
HTP honourary membership sounds impressive if i could just figure out what it means !? Has Transmitter Problems., Hasnt Tried Properley, Horrendous Takeoff Procedure ?
g
graeme ...... HTP ...means Hill Top Posse ... check out our thread/posts on the forum here....'return of the hill top posse'...your invention..the blue tack/matches entitles you to join us.... one of our foreign members(enrico) is allways looking for way's to save money etc....... he had the chimney pots taken off his roof...because he was giving the smoke away for nothing.... ..
ken anderson ne...1 .. HTP.... PR dept....
thanks for the update ken. usually i am of the
"I would not join any club that would have someone like me for a member."
-- Groucho Marx
school of thought .
However, I think i might have actually bought some of said smoke from a passing Hungarian gypsy, will this enrico chappy be looking for commission ?
I can do him an ace deal on matches and blue tack
i am proud to accept such an honour and shall shortly be embroidering a blazer with the initials. Lets see what they make of that down the golf club.
Is it worth oiling the servos ? have just ordered another pair on e bay anyway
g
Getting back on tack, great little plane and fun to try and sniff out lift either on the flat or on the slope when the wind has died down. But is sensitive to controls and c of g.
I've used mine on the slope when there's no wind to check for lift before launching something that you can't chuck 50ft into the air and do a least two circuits before landing back at you feet.
My favorite trick is catching it rather than having to pick it up off the ground
They don't like too much wind though
http://youtu.be/Jxa1JiBGDXg
Edited By Frank Skilbeck on 14/08/2011 21:53:55
Edited By Frank Skilbeck on 14/08/2011 21:54:51
  • 7 months later...
Do people think an Alula Evo is worth the money? I'm considering getting one since I quite fancy a glider and can only do flat feild flying. I have looked at "real" DLGs, but cheap isn't really the word one might use to describe them. The only model I fly at the moment (to any extent) is my Flying Wings Raven.
I'd like to hear people's opinions, thanks,
Birdy.
Edited By David Ashby on 02/04/2012 07:59:20
orville in the garden
birdy here is mine.......mostly flown off the cliffs and slopes.......i've had a few go's on the flatfield with it--it was ok..... but we are on the coast and allways have n/ne coastal breezes to contend with...if you are inland...it should go well when its calm/warm.....
ken anderson ne..1 .... alula dept.
Edited By David Ashby on 02/04/2012 07:59:33
