Laser-cut kits
Flite08
Is there any point in sanding off (gently) the burnt residue on the wood parts or is it normal to just glue the parts together, I assume if the burnt edge would show through the covering then a gentle sanding would be exceptable, Does the residue affect the strength of the glued joint?
F08
Edited By Flite08 on 04/03/2012 15:08:04
