Taff Posted March 6, 2012 Share Posted March 6, 2012 Hi All No doubt this has been covered before But....what causes lipos to puff up/swell ..and can anything be done to reverse it...is it dangerous to carry on using in this state? I have 2 lipos 2200 not very old ,not many flights ,that have just gone this way,being a bit wary have decided to keep them out doors in a fire proof container !!!! should i disgard them ? or is there life in them yet....all views welcome Regards Taff Quote Link to comment Share on other sites More sharing options...
Andy Green Posted March 6, 2012 Share Posted March 6, 2012 They're wrecked Taff. Use a light load and discharge them completely, and in the bin with them. Andy Quote Link to comment Share on other sites More sharing options...
Former Member Posted March 6, 2012 Share Posted March 6, 2012 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Devon Flyer Posted March 6, 2012 Share Posted March 6, 2012 Posted by Tom Sharp 2 on 06/03/2012 22:24:37: Idealy you should aim to have 20% of capacity left at the end of a flight. I always aim to draw no more than 80% of the theoretical maximum current out of a pack and no more than 80% of the theoretical capacity. ie.2200mAh pack rated at 20C would be approx 35A current drain and approx 1700mAh capacity drain. I've done this for a number of years now and very rarely have any problems with packs dying or puffing up. Edited By Devon Flyer on 06/03/2012 22:32:07 Quote Link to comment Share on other sites More sharing options...
Ben B Posted March 6, 2012 Share Posted March 6, 2012 A little bit of puffing that settles once the battery has cooled (and re-absorbed the gas) is fine. Goes hand in hand with hot cells and high amp discharge. If it's permanently puffed it's a different matter. Ive got some Turnigy Nano's that get well and truly puffed when discharged but give them 10 minutes and they're rock solid. Still going strong approx 50 flights later. So first describe your puff! IF they're still puffed once they've calmed down you're in for some trouble. Quote Link to comment Share on other sites More sharing options...
PatMc Posted March 6, 2012 Share Posted March 6, 2012 Hi Taff, Don't panic, just charge & use as normal. But do be a little more vigilant charging & carefull where they're stored. The performance may be a little below their normal in use (but not necessarily). The attached photos are of ones I got from HK in 2007. They were part of a bad batch distributed world wide at the time & mine were replaced FOC on the strength of the photos. I continued using them together with the replacements. Two of the 2200s became unuseable about 18 months ago the other two have also swollen & noticably lost capacity but are still useable. Both the 1300s are now swollen but are useable though they have never been hard pushed as I've always used them in low current demand vintage models. Edited By PatMc on 06/03/2012 23:02:34 Edited By Biggles' Elder Brother - Moderator on 28/04/2013 12:38:58 Quote Link to comment Share on other sites More sharing options...
Mac Duberia Posted April 28, 2013 Share Posted April 28, 2013 Hi, Can anybody advise, i have a overlander 5000mAh lipo 14.8v 25c, i havent had much use of it say i've charged and balanced it about 4-5 times, but now its showing signs of slight swelling, should i be worried about it. I also have other lipos which i have charged and balanced number of times and they look normal compared to the 5000mAh. I've kept the lipo in a tin at the back of the garden just in case. Thanks Mac Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted April 28, 2013 Share Posted April 28, 2013 SLIGHT swelling is fine. Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted April 28, 2013 Share Posted April 28, 2013 This is the sort of swelling that means the LiPo should not be used. It still charged but one cell had much reduced capacity and was thus likely to be almost fully discharged before the LVC 'kicked in' so harming the weak cell even further if it continued to be used. Quote Link to comment Share on other sites More sharing options...
crispin church Posted April 28, 2013 Share Posted April 28, 2013 if the battery works use it if it dont work bin it do you throw everyone out thats abit swollen around the middle ? Quote Link to comment Share on other sites More sharing options...
Allan Bowker Posted April 28, 2013 Share Posted April 28, 2013 I can't add any more advice than has already been said, other than: Please be careful with Li-Po's, they are more of a fire hazzard in their puffed state. Please consider taking your battery to your local municipal recycling centre (waste tip). Quote Link to comment Share on other sites More sharing options...
Stevo Posted April 28, 2013 Share Posted April 28, 2013 Mine are slightly swollen, they are never over-discharged and always balance charged at 1C. However get it wrong and... http://youtu.be/SwQcgyoNz3s I have tried embedding the video as direceted but it comes up with a blank space on Google Chrome but OK in IE. Edited By Stevo on 28/04/2013 18:00:52 Edited By Stevo on 28/04/2013 18:02:13 Quote Link to comment Share on other sites More sharing options...
