flyeruk Posted May 13, 2012 Share Posted May 13, 2012 I have this os 46 that i was given a while ago. It runs really well but as you can see from the picture,the needle valve mounting is broken. I thought about jb weld but not sure if it could handle the vibration. Any ideas? Quote Link to comment Share on other sites More sharing options...
flyeruk Posted May 13, 2012 Author Share Posted May 13, 2012 I have just seen the cover plate assembly is available for around £22.00. Would rather not have to spend that,but if its not repairable,i will have no option. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted May 13, 2012 Share Posted May 13, 2012 fabricate a mount on the engine bulk head and fasten the remote on with a couple of cable tie's-cost 5p.. ken anderson ne..1... 5p dept. Edited By ken anderson. on 13/05/2012 17:27:35 Quote Link to comment Share on other sites More sharing options...
Alan Cantwell Posted May 13, 2012 Share Posted May 13, 2012 jb weld will handle anything, but i am with ken, remote needles can be put anywhere remote, Quote Link to comment Share on other sites More sharing options...
flyeruk Posted May 13, 2012 Author Share Posted May 13, 2012 I have just found that i dont need the whole back plate assembly,fust the back plate the includes the mount,FOR £6.99. I think i will just buy one. Thsnks for the replies. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted May 13, 2012 Share Posted May 13, 2012 Look on Ebay. Annies dusty attic sell Fox remote needla valves with a mounting bracket. Could mount to the backplate on firewall. Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted May 16, 2012 Share Posted May 16, 2012 You can also fit a rear needle valve assy as fitted to the magnum/SC/ASP engines.You do have to elongate one of the holes by about 1mm. This comes as a seperate item and is held in place with the top two backplate screws, cost about a £5; and the local shop got one very quickly .The genuine OS part is not too expensive but I found in the past getting hold of it was a pain and took ages. The shop said it was down to "waiting for a sizable order" ! On that occasion I fixed the OS type using TechnoWeld and cancelled the order .Its an easy fix takes a few minutes. Edited By Engine Doctor on 16/05/2012 10:23:09 Quote Link to comment Share on other sites More sharing options...
Ben B Posted May 16, 2012 Share Posted May 16, 2012 JB weld would have sorted it. For extra fixage after the initial butt joint I would have coated over the top with more of the stuff to make an I beam type shape. But for £7 it seems simpler to just buy the spare part. A tube of JB is a fiver I seem to recall (although very useful!). Quote Link to comment Share on other sites More sharing options...
