Tom Wright 2 Posted December 17, 2012 Share Posted December 17, 2012 Rich. I used stringers over blue foam on my big DV1 it works well . Your FF Major should be a real floater look forward to seeing the maiden . Watch out for Santa he may want to borrow it for a delivery vehicle .lol. Tom. Quote Link to comment Share on other sites More sharing options...
Richard Harris Posted December 17, 2012 Share Posted December 17, 2012 Tom, What glue do you use, I have tried epoxy and it sticks well until you shock it and it can come away? Gorilla glue so far has been the best as well as PVA but the latter takes for ever to dry? Rich Quote Link to comment Share on other sites More sharing options...
Tom Wright 2 Posted December 17, 2012 Share Posted December 17, 2012 Rich . Hard setting glues don't generally work to well ,and as you say setting time can be a problem . The Tri Plane , Blue monster and the Twin Boom and my other foam balsa hybrids were all done with U por , this allows rapid progress if several parts are prepared for glueing .As I am sure you know both components should be thinly coated and allowed to dry for 10 mins or so before joining.The blue foam has a good strength to weight ratio when the thickness is matched to the structural requirements , but is best cut with a hot wire when curved surfaces are called for , straight cuts are best done with a sharp saw, thick sheet or blocks cut well with a full size wood saw . Sanding is best done in straight lines in the same direction using light pressure ,best to wear a mask as the dust does not break down when inhaled . Using foam for the blade area behind chord max thickness does work well ,in fact I have several sets that are all foam and then sheeted with balsa ....it just leaves sorting out the chord wise cog,but I think the hard wood is needed for big blades .The photo below is the blade set for the Monster Crane Fly . Will wait to see how your project goes though ,as you have had previous experience with "big ones" and walked away with you head in tact lol. Tom. Edited By Tom Wright 2 on 17/12/2012 01:50:20 Quote Link to comment Share on other sites More sharing options...
Foamie Dave Posted December 17, 2012 Share Posted December 17, 2012 This is gonna be awesome ! Are we going to see a Crimbo spectacular video Rich Quote Link to comment Share on other sites More sharing options...
Richard Harris Posted December 17, 2012 Share Posted December 17, 2012 Dave, I don't think so, there is still quite alot to do. Managed to get the mast mount in position, the mast will slide in through the top and will be bolted from the underside (I think). Still need to add mre ply and tri stock. A have a few motors that are about the right size ranging in KV to play with, would like to keep the cell count as low as possible and swing a bigger prop. Also made a start on the mast, basically the same as its smaller brother except it is faced each side in light ply and an added 10mm carbon fibre tube, should be plenty strong enough and nice and light! Rich Quote Link to comment Share on other sites More sharing options...
Foamie Dave Posted December 17, 2012 Share Posted December 17, 2012 As long as its all set for Greenacres then Like Tom said, POR will be ideal for sticking the stringers on. Let it go tacky first and it'll grip like a limpet (especially if used on both surfaces like a contact adhesive - no pinning or taping required ) Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted December 23, 2012 Author Share Posted December 23, 2012 Hi chaps, remiss of me not to drop in recently but I've been away and t'office is mad at this time of year. Wow, very impressive Rich - did you want to start a new thread for it? Let me know Just perusing that motor line-up, would that Power 160 be too much do you think? Well my Firefly has still only had one flight, mainly due to the bad weather and other distractions so I have just added the final decorative touches in the meantime - she's all done bar a pilot Edited By David Ashby - RCME on 23/12/2012 09:55:28 Edited By David Ashby - RCME on 23/12/2012 09:57:01 Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted December 23, 2012 Author Share Posted December 23, 2012 Hugo inspecting....... Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted December 23, 2012 Author Share Posted December 23, 2012 I think it may well just have to be a Panther next for me you know Quote Link to comment Share on other sites More sharing options...
Foamie Dave Posted December 23, 2012 Share Posted December 23, 2012 Posted by David Ashby - RCME on 23/12/2012 09:54:26: I think it may well just have to be a Panther next for me you know I must confess with all the help and guidance from this thread Ive been hooked as well (and Ive not even managed to sneak the maiden in yet ). Huge thanks chaps !! BTW love the faux leather headrest D, it'll look a proper retro racer with the man in the hot seat in situ Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted December 23, 2012 Author Share Posted December 23, 2012 Ta FD, your flight report is awaited, hope it goes well, Boxing day weather isn't looking too bad if you can escape the festivities Quote Link to comment Share on other sites More sharing options...
Richard Harris Posted December 23, 2012 Share Posted December 23, 2012 Dave, Looking nice but it does need a pilot! I can delete the photos of the bigger version if you like? I can post a few photos when I have completed it. Rich Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted December 23, 2012 Author Share Posted December 23, 2012 Hi Rich, no I didn't mean that - it's such a nice project that I didn't want it to disappear in this thread, it seemed deserving of a thread of it's own? I can leave of course or move posts across to a new thread for you. Edited By David Ashby - RCME on 23/12/2012 18:47:57 Quote Link to comment Share on other sites More sharing options...
Foamie Dave Posted December 27, 2012 Share Posted December 27, 2012 Posted by David Ashby - RCME on 23/12/2012 15:50:25: Boxing day weather isn't looking too bad if you can escape the festivities Had planned on a maiden today but unfortunately have to attend a funeral (dont think vicar will be too chuffed if I combine the two ) . Ah well at least its all set to go. BTW the HK Ceirva head sets are just back in stock if anyone is interested. Rich, send me your addy if you want yours replacing EDIT Just seen D's post in the main thread about the HK heads ...duh Edited By Foamie Dave on 27/12/2012 10:29:04 Quote Link to comment Share on other sites More sharing options...
Foamie Dave Posted December 29, 2012 Share Posted December 29, 2012 Dear Santa , **LINK** Quote Link to comment Share on other sites More sharing options...
Baz Lewis Posted March 6, 2013 Share Posted March 6, 2013 Here is my recent build of the Firefly, covered in Yellow / Red Tissue including the Tail. Test flights will resume over the next few weeks, so hopefully a vid will come from it! Quote Link to comment Share on other sites More sharing options...
Richard Harris Posted March 6, 2013 Share Posted March 6, 2013 Factorywriggs, Nice work!..wouldnt happen too be the Shiffnal field? Rich Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted March 7, 2013 Author Share Posted March 7, 2013 Very nice FW, I must get a pilot for mine. Quote Link to comment Share on other sites More sharing options...
Grasshopper Posted March 7, 2013 Share Posted March 7, 2013 Great video (Foamie) Dave! Interesting that as noted in the comments it uses 'Fartwind' to keep it in the air! Der Rotor wird nur vorrotiert und dann vom Fartwind angetrieben. Peter Quote Link to comment Share on other sites More sharing options...
Lazygit Posted May 28, 2013 Share Posted May 28, 2013 First major crash with FF2 this weekend. Right hand spiral into the ground. Don't know why, it was too far away to see properly. The only problem is a broken mast, but as I slotted it in and drilled to take a fixing pin, repairs are going to be easy. I just need to scarf a piece on to replace the broken bit. Quote Link to comment Share on other sites More sharing options...
Foamie Dave Posted June 9, 2013 Share Posted June 9, 2013 Flying field finally dried out.. blue skies, fluffy clouds & ran out of excuses I'll let the pics do the talking Edited By Foamie Dave on 09/06/2013 21:09:54 Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted June 10, 2013 Author Share Posted June 10, 2013 That looks superb Dave, you must be pleased, how did it fly? Quote Link to comment Share on other sites More sharing options...
Richard Harris Posted June 10, 2013 Share Posted June 10, 2013 Dave, Nice one looks like we have a race on our hands in a few weeks, how did it feel in the air? Rich Quote Link to comment Share on other sites More sharing options...
Foamie Dave Posted June 10, 2013 Share Posted June 10, 2013 Cheers Gents ROG's are hands off, level flight is on rails and it virtually lands itself (apart from the 3rd flight which I managed to land in a tree...dont ask ...no really dont ask ) Having never flown one before I find it tucks under slightly during LH turns which is something I need to get used to, I'm presuming its the effect of the main rotor ? Think I'll try using the rudder more in future and keep it level with the "ailerons" perhaps? As you can gather I'm still all fingers and thumbs in the turns so any advice from you old pros most welcome. As you can see from the pic below I think Im cranking over a bit much ?? Apart from that, its an absolute peach, even with my numpty thums . Congrats on a great design and huge thanks to all for the help and advice - much appreciated. A race eh Rich ?, Yer a braver man than me, I think It would be more like combat if my hedge timming escapades are anything to go off - think I need to replace the Breitling logo with Flymo decal! Edited By Foamie Dave on 10/06/2013 17:55:25 Quote Link to comment Share on other sites More sharing options...
