David Rothwell Posted June 8, 2014 Share Posted June 8, 2014 Percy, I can send you my copy you can copy it and then return it, if that helps. David Quote Link to comment Share on other sites More sharing options...
Former Member Posted June 14, 2014 Share Posted June 14, 2014 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
chris bridges Posted June 28, 2014 Share Posted June 28, 2014 Lindsay, Hi, ive built most if the skywriter, but would really like to "I C" it !, am thinking oif a four stroke,maybe 50 size, would like to knbow what you think Thanks, chris bridges. Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted June 29, 2014 Author Share Posted June 29, 2014 52 four stroke would be ideal match I should think, it was on my mind originally to go that way so it would be interesting to hear how she performs. Linds Quote Link to comment Share on other sites More sharing options...
Derek Bradley Posted August 1, 2014 Share Posted August 1, 2014 Hi Lindsay, I am thinking of building the Skywriter and, at the moment, have ordered the motor from Hobbyking. Which ESC did you use? Would putting the same dihedral on the upper wing as the lower wing have any adverse effect. Many thanks for another great design. Derek. Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted August 1, 2014 Author Share Posted August 1, 2014 Hi Derek, from memory I had a 50amp esc, however its all about watts per pound so I would suggest the purchase of a watt meter as I think I was running pretty close to max for my combination so worth checking with various props if you can. Adding dihedral to the top wing should not have real any adverse effects other than increasing stability in role and therefore damping the effect of the ailerons a little. It will of course require a slight mod to the length of the wing struts but other than that should be easy enough. Hope that helps, have fun. Linds Quote Link to comment Share on other sites More sharing options...
Derek Bradley Posted August 1, 2014 Share Posted August 1, 2014 Many thanks, Lindsey - it all helps. Derek. Quote Link to comment Share on other sites More sharing options...
Derek Bradley Posted August 11, 2014 Share Posted August 11, 2014 Has anyone built, or is building, the Skywriter? If so, let us know what stage you have reached, any photos, hints, tips, etc. It's a lovely looking biplane which, apparently, flies well, but none of the postings appear to have got beyond the 'like it', 'thinking about it' stage. Derek. Quote Link to comment Share on other sites More sharing options...
Derek Bradley Posted August 11, 2014 Share Posted August 11, 2014 Wot, no takers???????????????? I don't believe it !!!!!!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
John Walpole Posted August 18, 2014 Share Posted August 18, 2014 Hi Lindsay I have cut all my parts for sky writer and made templates of fuselage and doublers but the drawing seems be incorrect for the fuselage sides, it would appear to be short or the tail end doubler needs to be 6mm.I cut the the templates to the black marker triangles which finish at the rear doubler is this correct.Desperate to get this built. Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted August 18, 2014 Author Share Posted August 18, 2014 John, please see 5th note down on this page, an error was spotted belive now corrected but if you are working off the original issue plan then this should help you out. Linds Quote Link to comment Share on other sites More sharing options...
Former Member Posted August 21, 2014 Share Posted August 21, 2014 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Derek Bradley Posted October 6, 2014 Share Posted October 6, 2014 I am in the process of collecting the bits and pieces to start on the Skywriter but, having tried two local B&Q's, I am unable to find any aluminium strip of 1 x 12mm as mentioned in the original build notes in the magazine for the cabane struts. However, both shops had 10 x 2mm strip and measuring the struts on the original free plan they are 10mm wide. Can someone please confirm that the correct strip is 10 x 2mm. Many thanks. Derek. Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted October 6, 2014 Author Share Posted October 6, 2014 10x2mm should be absolutely fine, if the notes are saying 1 x 12mm I suspect that is a typo as I don't recall ever using 1mm strip. Linds Quote Link to comment Share on other sites More sharing options...
Derek Bradley Posted October 6, 2014 Share Posted October 6, 2014 Many thanks, Linds. Derek. Quote Link to comment Share on other sites More sharing options...
Wayne Guckert Posted November 27, 2014 Share Posted November 27, 2014 First timer. Been thinking about this hobby for a long time now. Then I saw Lindsey's Skywriter and thought this is it I have to build it. Skywriter has been hanging in the garage for seven months now, while I train my self on a foamy, that's been exciting. Think I am almost ready to put Skywriter up. Will down load some photos when I work out how to get them onto the album section from my picture folder in Windows 7. Quote Link to comment Share on other sites More sharing options...
Wayne Guckert Posted December 8, 2014 Share Posted December 8, 2014 Are have worked it out .some photos of Skywrite. All cutting out was done by hand Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted December 8, 2014 Author Share Posted December 8, 2014 Cracking job there Wayne, love the colour scheme and well done on cutting those rear formers by hand! Linds Quote Link to comment Share on other sites More sharing options...
Wayne Guckert Posted December 30, 2014 Share Posted December 30, 2014 Somme more photos of Skywriter Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted November 13, 2016 Share Posted November 13, 2016 Lindsay, Where do the get the pegs you use on page 2 of the build blog? Normal clothes pegs often leaves marks. Regards, Lucas Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted November 13, 2016 Share Posted November 13, 2016 Hi Linds, Studying the plan from the October 2013 issue, anticipation the Skywriter to become the Mass Build 2017 modell. On the plan the fin and stabilizer are covered in 1 mm ply. That feels way over the top strienght wise and the worst place to add weight. In you build blog these are open structures, with feels more appropriate. Please advice, Lucas Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted November 17, 2016 Author Share Posted November 17, 2016 Hi Lucas, I'll need to ask my wife re pegs but probably the local pound shop to be honest. Re the 1mm ply this is purely local reinforcement to horns and wire joiners and not over the entire surfaces. Linds Quote Link to comment Share on other sites More sharing options...
Lucas Hofman Posted November 17, 2016 Share Posted November 17, 2016 Hi Linds, With regard to the ply that is what I thought. With the Ballerina we have also seen the RCM&E draftmen making quite a few "improvements" without consulting the designer. Are you aware of any more changes or downright errors in the free plan? Regards, Lucas ps. what do you think of the Skywriter being so popular in the Mass Build 2017? Quote Link to comment Share on other sites More sharing options...
kc Posted November 17, 2016 Share Posted November 17, 2016 Well the plan clearly states "1mm ply each side of fin" and shows a built up structure underneath the skin, so what is the outer surface of the fin? Balsa? Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted November 17, 2016 Author Share Posted November 17, 2016 The fin is not covered in ply it is an open structure so if the plans states that then it is wrong, I have not had any feedback so looks like most are capable of working such blips out for themselves or just checking against the blog. KC if you check the blog and photos, excellent source of additional information, then this should help. As for Mass Build, its a people choice at the end of the day I guess and nobody is being forced to build the model. I always fancied doing a bigger one actually so who knows maybe a 60cc version? Quote Link to comment Share on other sites More sharing options...
