crispin church Posted April 3, 2013 Share Posted April 3, 2013 got a built up balsa aileron thats bent tried reshinking and iron and clamp it between 2 boards am i chasing a loosing battle ? Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted April 3, 2013 Share Posted April 3, 2013 If its a built up aileron it will probably be easier to make a new straight one than straighten it. Once the skins are glued on both sides an aileron or wing for that matter becomes very stiff. You could try removing one skin and glueing the new skin in place with the aileron straight but its going to require a bit of surgery .just twiting it etc is unlikely to correct the twist. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted April 3, 2013 Share Posted April 3, 2013 hello crispin.......what i've done in the past with built up stuff is set the heat gun on...laid on a worktop....held the bent/warped bit in the hot air and twisted to where i want it......removed it from the heat -still held and when its cooled off it should be un-bent(straight)..... ken anderson ne..1 hot air dept.... Quote Link to comment Share on other sites More sharing options...
Erfolg Posted April 3, 2013 Share Posted April 3, 2013 Crispin. Kens solution will probably work, at least in the short term. Replacement, my type of solution, again will work, again if it is a permanent solution, time only will tell, how permanent is permanent. I have had a wing, where distortion had occurred. In my case, the distortion was so severe only a rebuild was practical, to correct the issue. Which I have done, the work taking some time. At present, I am trying to get my "A" certificate. I am using a 30 year old model, the wing has warped, to some degree. In this instance, I am living with the problem, at least for the present. The model does not fly perfectly, requiring corrections. Yet a re build is a lot easier to talk about than do. So i am living with a less than perfect model, as it is acceptable. I do not think there is one solution. Each case needs careful consideration, as to the work involved, how severe the present problem is and the benefit that you will gain from a partial rebuild. Edited By Erfolg on 03/04/2013 21:06:16 Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted April 3, 2013 Share Posted April 3, 2013 I think you have three options. 1. Do the same as you have already but clamp it up slightly over bent the other way. 2: Seperate some of the glue joints and re-glue whilst clamped. (also slit along the grain) 3: Build a new one. Quote Link to comment Share on other sites More sharing options...
Pat (rActive) Harbord Posted April 3, 2013 Share Posted April 3, 2013 Crispin, is the aileron twisted or bent? A twist could be relatively easy to cure, a bend along its length would be considerably harder. You will need to remove the aileron from the wing and then remove the covering For a twist in a solid surface. You can then mist with water and twist the other way slightly more than straight and hold over a heater/radiator until it is straight when you relax your grip. This can be repeated ad infinitum until perfect. You should then weigh the aileron down on a flat surface and leave for at least 24 hours. a built up structure can often be straightened with use of the covering by applying heat whilst holding in opposite twist, allow to cool before relaxing the twist. Don't over heat the covering as it will lose its tension. You should see wrinkles appear as you hold in the opposite twist, you just need enough heat to smooth these out. I find an extra pair of hands and a covering iron good, but others prefer a heat gun. Quote Link to comment Share on other sites More sharing options...
Pat (rActive) Harbord Posted April 3, 2013 Share Posted April 3, 2013 Ah I see Ken already answered - so what he says should work. Quote Link to comment Share on other sites More sharing options...
Pat (rActive) Harbord Posted April 3, 2013 Share Posted April 3, 2013 If its bent, I would look at stripping the covering off and rebuilding it starting with the leading edge. If you can release the glue joints you you may find its the trailing edge that's bent, so re glue the leading edge and remove the trailing edge and replace with new (straight) wood. Quote Link to comment Share on other sites More sharing options...
ben goodfellow 1 Posted April 3, 2013 Share Posted April 3, 2013 i was told ammonia works well for bending balsa ,not sure how true it is Quote Link to comment Share on other sites More sharing options...
Pat (rActive) Harbord Posted April 3, 2013 Share Posted April 3, 2013 All my old books suggest the same. Can you still get ammonia? I guess it works as a wetting agent helping the water to sink into the wood. Quote Link to comment Share on other sites More sharing options...
Erfolg Posted April 3, 2013 Share Posted April 3, 2013 I do not know about the rest of you guys, I find that these types of jobs have a habit of growing a lot bigger than initially envisaged. Even the simplest solution. That of trying to straighten in position. The first issue is getting the item straight. Or straighter than it was. Then finishing the damaged/removed covering is an issue. The second solution of getting the aileron of. That is often far more involved than ever imagined. Then a new part is to be made. The hinging issue addressed, which can involve some work. The new bit covered, remounted. That is hinged, connected to servo etc. All seem easy, in reality,take time, effort, some skill, if the finished result is not only to be better, but be right. My experience has tended to indicate that quick fixes, seldom last, or work. Indicating, that if the model is to be fixed properly, count on some time and effort. Quote Link to comment Share on other sites More sharing options...
001 Posted April 4, 2013 Share Posted April 4, 2013 Instead of Ammonia spray the structure with window cleaning spray such as Mr. Muscle, let it soak in and the wood will relax, but it will also probably loosen the joints if they are made of PVA or white glue! Quote Link to comment Share on other sites More sharing options...
crispin church Posted April 4, 2013 Author Share Posted April 4, 2013 Many thanks for all replys it bent and a twist in it and does affect flying a lot i am now at the stage that cover is coming off one side so will have more detailed look at it and put your comments in to good use Quote Link to comment Share on other sites More sharing options...
crispin church Posted April 4, 2013 Author Share Posted April 4, 2013 well done it took cover off one side found cross pieces not glued reglue them and rubbed thin CA over then whole piece and clampped it down hour later recovered now straight see over time if it stays many thanks Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted April 4, 2013 Share Posted April 4, 2013 I suspect that the original shrinking was not the same all over which caused the problem bearing in mind that the woodwork was isolated from the environment by the covering .Hope you have rectified it by re glueing Quote Link to comment Share on other sites More sharing options...
Erfolg Posted April 4, 2013 Share Posted April 4, 2013 Congratulations on successfully rectifying the issue. So expeditiously completed too! Quote Link to comment Share on other sites More sharing options...
crispin church Posted April 5, 2013 Author Share Posted April 5, 2013 soaked all joints in CA checked it today and still straight Quote Link to comment Share on other sites More sharing options...
crispin church Posted May 2, 2013 Author Share Posted May 2, 2013 flew today wing still nice and straight cog a bit out need some weight on front but very flyable now many thanks to all Quote Link to comment Share on other sites More sharing options...
