Mike Blandford Posted April 22, 2015 Share Posted April 22, 2015 I test flew with this 'new' module in a Taranis (Plus) yesterday, previously I had been using a 9X with the SKY board upgrade. All worked as well as before. Still using ersky9x firmware. I'm looking at getting the module driver code imported into openTx. Same model, with the Lemon stabiliser receiver. All 8 channels work. On the Taranis I set the left slider up to control the master gain on channel 8, as well as mixing in throttle on channel 8 so the gain reduced as I increased the throttle above half. Mike. Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted April 22, 2015 Author Share Posted April 22, 2015 Sounds perfect Mike thanks for the update. Keep keeping us posted, ta. Quote Link to comment Share on other sites More sharing options...
WolstonFlyer Posted May 31, 2015 Share Posted May 31, 2015 I finally got around to making up my DSMX module... things take time at my house! Here are my photographs With the DX5 module installed, held in place with a couple of layers of thick double sided tape. Finally assembled It is just after midnight so I have only done a quick bind test to an AR400 but it all seemed to work ok, bound instantly and wiggling the sticks made the servo's move. Will do a proper range test tomorrow or Monday but I feeling quite pleased with myself Edited By WolstonFlyer on 31/05/2015 00:16:20 Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted May 31, 2015 Author Share Posted May 31, 2015 Ooh that is a step up from the veroboard isn't it? Nice job WF Quote Link to comment Share on other sites More sharing options...
WolstonFlyer Posted June 3, 2015 Share Posted June 3, 2015 Thanks Chris, the circuit board makes it a very easy project! Quote Link to comment Share on other sites More sharing options...
Phil Green Posted September 25, 2015 Share Posted September 25, 2015 I have an empty Corona JR-style module case, just like the one on Chris's opening post... Its up for grabs if anyone wants it. Cheers Phil PS forgot to say, no charge for it By the way, for those who dislike waste, the guts of Chris's Corona module shown in his 3rd post live on and are in regular use in one of Doug Campbells single-channel sets! Edited By Phil Green on 25/09/2015 19:06:26 Quote Link to comment Share on other sites More sharing options...
Neil R Posted October 1, 2015 Share Posted October 1, 2015 I fancy a go at this! Cheeky request - since these come in minimums of 3 - has anybody got a spare OSH Park circuit board they'd consider selling to me? Happy to pay fair share. Thanks, Neil. Quote Link to comment Share on other sites More sharing options...
Phil Green Posted November 19, 2015 Share Posted November 19, 2015 Posted by Phil Green on 25/09/2015 19:01:56: I have an empty Corona JR-style module case, just like the one on Chris's opening post... Its up for grabs if anyone wants it. Cheers Phil PS forgot to say, no charge for it No takers, so still up for grabs, one empty Corona JR-style case exactly like Chris's in his 3rd post. Free to a good home. Quote Link to comment Share on other sites More sharing options...
Dave Bran Posted November 20, 2015 Share Posted November 20, 2015 Yes, Please Phil!! Quote Link to comment Share on other sites More sharing options...
Phil Green Posted November 20, 2015 Share Posted November 20, 2015 No problem, PM your address Dave [Ah I see you already did ! ] Cheers Phil Edited By Phil Green on 20/11/2015 08:41:08 Quote Link to comment Share on other sites More sharing options...
Gary Lashley Posted April 17, 2016 Share Posted April 17, 2016 Can anyone confirm if this module from a Dx5 is compatible? I cannot get it to bind. Thank you. Quote Link to comment Share on other sites More sharing options...
N Pritchett Posted May 26, 2016 Share Posted May 26, 2016 Hi Gary, Got the same problem. Mine won't bind with any DMX receiver. Have checked the receivers which will bind with a DX8. So the receivers are OK. Trying an AR400 receiver using DSM2 - DSMX setting on the Taranis plus. Anyone know if there has been a change in the TX firmware that could be causing this issue? Quote Link to comment Share on other sites More sharing options...
Kevin Fairgrieve Posted May 27, 2016 Share Posted May 27, 2016 Posted by Gary Lashley on 17/04/2016 23:30:34: Can anyone confirm if this module from a Dx5 is compatible? I cannot get it to bind. Thank you. See my post one page back. I am using the same module, with no issue`s Kev Quote Link to comment Share on other sites More sharing options...
WolstonFlyer Posted May 27, 2016 Share Posted May 27, 2016 I have the sam DX5e module and it works perfectly. Have you set the Internary RF module to off and enabled the external module slot and set it to DSMX ? Quote Link to comment Share on other sites More sharing options...
WolstonFlyer Posted May 27, 2016 Share Posted May 27, 2016 Neil R, I am very sorry I didn't see your request for a circuit board. I have a spare one and components I could sell to you if you didn't already get one. Quote Link to comment Share on other sites More sharing options...
Mike Blandford Posted May 27, 2016 Share Posted May 27, 2016 There has been no sign of the module I tested coming on the market, and I have had not response from the manufacturer for many months, so I've given up on that. Hovever, over on RcGroups there is a DIY project for a "MULTI" module that include DSM2/X, see: **LINK**. What I've done is take the firmware from this and ported it to the Orange DSM module(s). This results in a DSM module that supports telemetry, and the communication to the module is high speed serial not PPM. You also get things like BIND and Range Check in the same way as with a XJT module. The biggest problem is the processor on the Orange module is an Atmel XMEGA device that needs a specific programmer. I've managed to build a suitable programming function into ersky9x, but currently the Taranis hardware isn't suitable to carry out the operation, it does work on the 9XR-PRO, and the 9Xtreme and AR9X upgrade boards for the 9X. I am looking into what might be possible on the Taranis with some extra circuitry, and also looking at using a small Arduino for the operation. The reflashed module is fully working on the Taranis using ersky9x firmware, including teleemtry. Multi protocol support is being added to openTx and I'm asking if the telemetry will also be added. Forther details are here: **LINK**. Mike. Quote Link to comment Share on other sites More sharing options...
N Pritchett Posted May 27, 2016 Share Posted May 27, 2016 Posted by WolstonFlyer on 27/05/2016 08:39:28: I have the sam DX5e module and it works perfectly. Have you set the Internary RF module to off and enabled the external module slot and set it to DSMX ? Yes, Internal off, External set to DSM2 - DSMX Press Bind, = flashing + beeping Receiver powered up with bind jumper No sign of binding. The receiver does bind to my DX8 so the RX is good. Just updated from 2.1.7 to 2.1.8 to see if changed things. Still no go! Any other ideas? Is there a way of checking that there is some RF output from the module? There is a signal on the diode input to it and the 3.3v is Ok. All suggestions gratefully received. Quote Link to comment Share on other sites More sharing options...
N Pritchett Posted May 27, 2016 Share Posted May 27, 2016 The only difference with my setup is that I 3D printed a carrying handle for the TX (replacing the metal one) and used the DX4 TX aerial embedded in it so the TX doesn't look like a porcupine! This did mean drilling a hole for the aerial to pass through the module housing and another near one of the screw holes for the handle fixing. This allowed the aerial wire to go internally, up the handle and along inside the top horizontal portion for the business end (the handle is in two pieces with a front and back which screw together to allow the aerial to be fitted in it). also added a small rectangular LED in the handle so it is visible from the front. If anyone's interested, I can send them the handle design. Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted May 27, 2016 Author Share Posted May 27, 2016 N, it's worth a try trying to bind it with the Tx a metre or more away from the Rx. (This goes for any Spektrum Tx). Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted May 27, 2016 Author Share Posted May 27, 2016 Posted by Mike Blandford on 27/05/2016 10:35:11: There has been no sign of the module I tested coming on the market, and I have had not response from the manufacturer for many months, so I've given up on that. Hovever, over on RcGroups there is a DIY project for a "MULTI" module that include DSM2/X, see: **LINK**. What I've done is take the firmware from this and ported it to the Orange DSM module(s). This results in a DSM module that supports telemetry, and the communication to the module is high speed serial not PPM. You also get things like BIND and Range Check in the same way as with a XJT module. The biggest problem is the processor on the Orange module is an Atmel XMEGA device that needs a specific programmer. I've managed to build a suitable programming function into ersky9x, but currently the Taranis hardware isn't suitable to carry out the operation, it does work on the 9XR-PRO, and the 9Xtreme and AR9X upgrade boards for the 9X. I am looking into what might be possible on the Taranis with some extra circuitry, and also looking at using a small Arduino for the operation. The reflashed module is fully working on the Taranis using ersky9x firmware, including teleemtry. Multi protocol support is being added to openTx and I'm asking if the telemetry will also be added. Forther details are here: **LINK**. Mike. Wow that sounds like a lot of hard work Mike. What a shame about the manufacturer. So, how many channels does the orangeTx module end up with? Quote Link to comment Share on other sites More sharing options...
Mike Blandford Posted May 27, 2016 Share Posted May 27, 2016 Not too much work as I already had code for the Orange DSM telemetry module and this one worked in a similar fashion. I got a couple of modules from them so my time wasn't completely wasted. The Orange Tx module handles up to 14 channels. I've checked it with a 10-channel Lemon DSM2 Rx, a Lemon stabiliser Rx (8 channels) with Lemon Telemetry, and a AR6210. The required mode DSM2/DSMX and number of channels is set in the protocol in the radio and the module automatically changes to match the model selected. Mike. Quote Link to comment Share on other sites More sharing options...
Phil Green Posted June 3, 2016 Share Posted June 3, 2016 I have two more JR-style module cases up for grabs, similar to the Corona one on Chris's opening post... these are from faulty Frsky DJT modules which are BER. Comes with the duff Frsky guts & the aerial lead with RP-SMA connector. Free of charge to the first two to email their addresses: [email protected] Cheers Phil Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted June 6, 2016 Author Share Posted June 6, 2016 Phil I expect these have already gone? If not I have an idea for a wireless trainer module I'd like to try. I'll pop you an email anyway - I've changed home address recently. Cheers Chris Quote Link to comment Share on other sites More sharing options...
Phil Green Posted June 6, 2016 Share Posted June 6, 2016 That both cases claimed now, one for Chris & one for Shaun W. I'll try & post them today if not it will be tomorrow (we're a bit busy today after the half-term hols) Cheers Phil Quote Link to comment Share on other sites More sharing options...
Andy48 Posted June 6, 2016 Share Posted June 6, 2016 There is a very definite problem with the Taranis if it is too close to the receiver. You notice it with the telemetry and binding, but I've also had it on a chuck foamy where one aileron went full lock on takeoff. As soon as the range increased a fraction, it was fine. This problem will also occur, I'm sure if using a wireless buddy system and the master and slave get too close together. Hmmm. Quote Link to comment Share on other sites More sharing options...
