Monz Posted March 27, 2014 Share Posted March 27, 2014 With one of these of course Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted March 27, 2014 Author Share Posted March 27, 2014 say whaaaaaaaaaaaaaaaaaaaaaaaaaaat !!!!! Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted March 27, 2014 Author Share Posted March 27, 2014 well i was told by the nice chaps at coventry that the dustbin is too small. soo i chopped it all up and tried again. now how the heck do i fit all that into the fuselage. eeeeeeeeeeeeeeeeeeeep Quote Link to comment Share on other sites More sharing options...
Plummet Posted March 27, 2014 Share Posted March 27, 2014 Posted by Tony Bennett on 27/03/2014 16:25:07:now how the flup do i make the randome go up and down. hmmmmmmmmmmmmm Compressed air and a balloon?* Plummet *Other inflatable items are available, and some of them are not latex based and are already lubricated. Edited By Plummet on 27/03/2014 19:36:22 Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted March 27, 2014 Author Share Posted March 27, 2014 ????? explain Quote Link to comment Share on other sites More sharing options...
Phil Winks Posted March 27, 2014 Share Posted March 27, 2014 Posted by Tony Bennett on 27/03/2014 19:36:56: ????? explain I think he'd best not on here Tony This an interesting issue was the original really deeper than the fuse ? If so it has to be telescopic, obviously, and the rack and pinion linked to a midi sail winch driven by a servo speed controller on a switched channel strikes me as a way to go. it would take a little working out as to size of pinion/turns on the drive to equal the correct amount of movement though, obviously all that can be fine tuned in the epa setting of the tx, the real challenge is making the collapsing dome slide smoothly enough, but I'm sure your up to that. Would you like a sketch of all the above Tony ? my CAD skils are basic but they worked well enough for others to copy my wing mod for the tucano Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted March 27, 2014 Author Share Posted March 27, 2014 it is telescopic sir. if you could sir, cos electrics and stuff confuses the hell out of me. needs to be linked with the u/c. Quote Link to comment Share on other sites More sharing options...
Phil Winks Posted March 27, 2014 Share Posted March 27, 2014 I'll scribble (I mean CAD ) something up over the next few days Tony I will need some dimensions 1 the deployed length and 2 the available space for the stowed dome and drive unit, Linking to the U/C is simple if you have mixing options on your TX, making it come up when U/C is lowered and and still be retractable/deployable in flight regardless of the U/C position Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted March 27, 2014 Author Share Posted March 27, 2014 deployed length is 20 cm. closed length is 15cm fuselage depth is 21cm. so not a lot of room is there. thanks sir Quote Link to comment Share on other sites More sharing options...
Phil Winks Posted March 27, 2014 Share Posted March 27, 2014 right Cap'n and the diameter ? looks to be elliptical, if so the major and minor axis Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted March 27, 2014 Author Share Posted March 27, 2014 90mm by 130mm. ta. going to be fun cutting into the fuselage and strengthening it all. Quote Link to comment Share on other sites More sharing options...
Plummet Posted March 28, 2014 Share Posted March 28, 2014 Posted by Tony Bennett on 27/03/2014 19:36:56: ????? explain One tube is a loose sliding fit inside another. Springs keep the two together. The upper end of the outer tube is capped. The lower end of the inner tube is capped. Put a balloon inside. Allow compressed air to enter the balloon via tube and valve and the tubes will separate. Release the pressure and they will compress again due to the springs. It is like a hydraulic ram, but without the precise engineering. OK? Plummet Quote Link to comment Share on other sites More sharing options...
Phil Winks Posted March 28, 2014 Share Posted March 28, 2014 Working on the raydome mechanics Tony think I've found a solution that will fit totally inside the stowed raydome and will fix to the top keel it will require you to have a spare switched channel to operate it with adjustable end points, guess thats not a problem Looking at your sizes the stowed length is 150mm (15cm) and fuse depth is 210mm so assuming you have 60mm between the top of the stowed dome and the top of the fuse, what is the depth of the top keel from the top of the fuse Phil Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted March 30, 2014 Author Share Posted March 30, 2014 i will check in the morning phil, been away all weekend and only just got in. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted April 12, 2014 Author Share Posted April 12, 2014 well time for an update. dylan and me have been working out the wing construction for a while now and the final laser cut parts turned up on friday. sooooooooooo second wing is on the board now. Quote Link to comment Share on other sites More sharing options...
Phil Winks Posted April 12, 2014 Share Posted April 12, 2014 Thats nice Tony very business looking I must get on with your raydome mechanism Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted April 12, 2014 Share Posted April 12, 2014 Looking good, two piece wing I am assuming from the photos. Really shows off that wing shape. Linds Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted April 12, 2014 Share Posted April 12, 2014 Taking shape nicely Tony. Edited By Colin Leighfield on 12/04/2014 20:39:00 Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted April 13, 2014 Author Share Posted April 13, 2014 got the second wing frame knocked up. sooooooooooooooo. then i started the sheer webbing. will more tomorrow in between Lanc and Nemesis builds. Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted April 13, 2014 Share Posted April 13, 2014 looking good sir. Linds Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted April 13, 2014 Author Share Posted April 13, 2014 thank you sir. much appreciated. Quote Link to comment Share on other sites More sharing options...
reg shaw Posted April 13, 2014 Share Posted April 13, 2014 This creature seems to be coming together in good fashion. The shape has been captured very well. Is that an old horse drawn caravan in the background? That looks a bit splendid too! Ian. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted April 13, 2014 Author Share Posted April 13, 2014 ahh the gypsy caravan, fully restored by my lovely wife. Quote Link to comment Share on other sites More sharing options...
reg shaw Posted April 13, 2014 Share Posted April 13, 2014 Now that, is a thing of beauty! Any more pics, though probably not in here as they'd distract from the Shackleton? Ian. Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted April 13, 2014 Share Posted April 13, 2014 Did she really do that? Amazing, clever lady. Quote Link to comment Share on other sites More sharing options...
