Biggles' Elder Brother - Moderator Posted April 13, 2014 Share Posted April 13, 2014 Very nice - Shack and caravan! BEB Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted April 14, 2014 Author Share Posted April 14, 2014 doing the sheer webbing on and off today. takes ages with big wings don't it. Quote Link to comment Share on other sites More sharing options...
Martian Posted April 15, 2014 Share Posted April 15, 2014 lovely work Tony and your good lady's work is superb, oh by the way Tony mind you don't get sheer exhaustion from doing them there wings Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted April 15, 2014 Author Share Posted April 15, 2014 H a H a ha back on it again later today. Quote Link to comment Share on other sites More sharing options...
Keith Simmons Posted April 15, 2014 Share Posted April 15, 2014 Wow Tony. You do models and your wife full size. Don't let her build any aircraft, let alone a 120 ft span shack ! Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted April 15, 2014 Author Share Posted April 15, 2014 now there is an idea. hmmmmmmm full size shack. naaaaaaaaaaaa 1/4 scale maybe. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted April 16, 2014 Author Share Posted April 16, 2014 well i have sheeted the underside of one wing panel and cut of the build tabs. can start on the second wing tomorrow. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted April 23, 2014 Author Share Posted April 23, 2014 well after some issues we have a pair of wings that fit. Need to sort the wing bolts and nose mounts tomorrow, i hope. waiting for the tail and nacelle parts to turn up now. Quote Link to comment Share on other sites More sharing options...
Phil Winks Posted April 23, 2014 Share Posted April 23, 2014 Looking good Tony, I see you've left the sheeting of above where the raydome fits, I must get on with that mechanism though be warned it may take till June before I have a working example for you, however I'm now totally convinced it will fit and work provided the servo I have chosen is strong enough, should be though, nearly 2kg/cm of torque. Phil Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted April 23, 2014 Author Share Posted April 23, 2014 wow sounds good sir. need to order a steerable retract for the tail wheel next. Quote Link to comment Share on other sites More sharing options...
Martian Posted April 23, 2014 Share Posted April 23, 2014 love your Work Tony ,it looks as tho she has just come back from a sortie Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted April 23, 2014 Share Posted April 23, 2014 It's very encouraging Tony, this is going to be really impressive. Did you finish off the Nihuis 72" Lancaster? I was wondering if you'd finalised the electrics on that one. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted April 23, 2014 Author Share Posted April 23, 2014 fitting the electrics in the lanc at the moment. got everything, its just raising the enthusiasm to tackle it. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted April 24, 2014 Author Share Posted April 24, 2014 access holes in the bomb bay floor. bomb bay doors cut in half now. Phenolic tubes glued into the nose section ready for fixing into the fuselage. and now fixed into the fuselage. when they have all set i can cut the nose off tomorrow and fit the ally tubes and make up the bolt mounts to enable the whole nose to be removed for storage and transport. Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted April 24, 2014 Share Posted April 24, 2014 Rapid progess on this one Tony, looks as if it should be practical as well as realistic. Quote Link to comment Share on other sites More sharing options...
Monz Posted April 24, 2014 Share Posted April 24, 2014 Luverly Tony! What is that brown tubing that you're using? Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted April 25, 2014 Author Share Posted April 25, 2014 well i have glued the ally tube into the phenolic tubes and now the nose slides on easy as pie. need to to the bolts next. Then i tackled the bomb doors, cut off most of the formers to give a nice internal shape and sanded them to fit the hole. fitted some simple hinges. got some space in there. got to work out the opening mechanism next and maybe a depth charge drop system as well. fin cores have been cut by dylan. Edited By Tony Bennett on 25/04/2014 19:25:28 Quote Link to comment Share on other sites More sharing options...
Phil 9 Posted April 25, 2014 Share Posted April 25, 2014 Tony why does the nose come off? is it just to make it smaller to transport? Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted April 25, 2014 Author Share Posted April 25, 2014 yes Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted April 25, 2014 Share Posted April 25, 2014 Some ideas I might be pinching there Tony. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted April 25, 2014 Author Share Posted April 25, 2014 feel free sir. pinch away Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted April 25, 2014 Share Posted April 25, 2014 Good stuff Tony, will be pinching a few ideas also. Linds Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted April 25, 2014 Author Share Posted April 25, 2014 i doubt there is much there for you to pinch Linds, i tend to steal ideas from your builds. Quote Link to comment Share on other sites More sharing options...
Lindsay Todd Posted April 25, 2014 Share Posted April 25, 2014 Not a bi of it, I've been doing a Danny Fenton tonight with the old blue foam to make moulds for the front glazing, never used the stuff before but pretty impressed but I'll leave that for an update tomorrow on my build blog. Linds Edited By Lindsay Todd on 25/04/2014 22:48:19 Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted April 26, 2014 Author Share Posted April 26, 2014 spent a couple of hours sorting the nose mounts. all bolts on now with two bolts and the two tubes. Quote Link to comment Share on other sites More sharing options...
