Cyclicscooby Posted May 6, 2014 Share Posted May 6, 2014 If you didn't manage to get one, like me, then there are a couple of alternatives available, albiet more money... Check out my 'Another Maplin Tx case' post if you're interested.. Luv Chrisie.. xx Quote Link to comment Share on other sites More sharing options...
IanR Posted May 6, 2014 Share Posted May 6, 2014 Found this after a quick google - various types of foam packaging. **LINK** Not massively expensive. Ian Quote Link to comment Share on other sites More sharing options...
John Miller 4 Posted May 7, 2014 Share Posted May 7, 2014 You can also try fleabay under Egg Crate Foam. I got mine, just in the nick of time so it seems. Quote Link to comment Share on other sites More sharing options...
John F Posted May 7, 2014 Share Posted May 7, 2014 Ian, Instead of buying new foam to glue into the bottom why not glue in the strips you have just taken out of the case? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted May 9, 2014 Share Posted May 9, 2014 Within a few minutes I had removed a piece that fits my Tx. Then separated a layer of two squares thick to fill the bottom of the case. I had planned to use impact adhesive but they stuck in so wel I won't bother. I think the case is really big enough for two trannies. I may use it to store all the other bits for my Hitec stuff and use my other case to take which ever tranny I am using to the field. Edited By Peter Miller on 09/05/2014 08:49:10 Quote Link to comment Share on other sites More sharing options...
Erfolg Posted May 9, 2014 Share Posted May 9, 2014 Peter It seems that not all the foam blocks are the same. In the case of the block in the case I purchased, the blocks were not square. They were long rectangles from the top of the block to the base of the block, although each pillar was a square in cross section. Not a cube as yours appears to have been. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted May 9, 2014 Share Posted May 9, 2014 Erfolg No, Mine are the same. But if you peel off sections two pillars thick from the block that you have removed from the main foam and lay them down on their sides in the cut out they work well. I packed them so that they gripped at the sides. Quote Link to comment Share on other sites More sharing options...
Stevo Posted May 10, 2014 Share Posted May 10, 2014 Soapbox time. The standard Tx cases that are available are always too small and NOT padded enough for my liking. Extend the sticks a little bit, and they stick into the lid. So, closing the case snug gives the false impression that its held snugly in there, when in reality its jammed against the sticks. Given that my Tx is over £300, putting up with a crap Tx box is not on. Like you guys, I went to Maplin, and measured one before I bought it. I machined out the foam for a tight Tx fit, and it holds spare binding plugs, charger and the Phoenix cable. Great job. The one you have pictured here is also my tool case... A bit of advice - once everything is in place, lay some foam over the top and when you close the lid make sure it gently compresses everything. Nothing rattles around.. job done. Don't make it too tight - the lid will fall apart!! Edited By Stevo on 10/05/2014 14:59:40 Quote Link to comment Share on other sites More sharing options...
John Sharpe Posted May 28, 2014 Share Posted May 28, 2014 Hello, Maplin are at it again £14.99 for a flight case, different case to the last offer more of a technicians box but very handy looking, I think i will have to pop in town a lunch time. Hope this is of use to someone. Item code GL34M. John. Quote Link to comment Share on other sites More sharing options...
