Nigel Day Posted January 22, 2015 Share Posted January 22, 2015 Looks strong enough to store your tools in John. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 30, 2015 Author Share Posted January 30, 2015 I used dowels on the front of my wing so I have angled the fairings and rear of the wing, so it'll fit in. Not very clear on the picture John Quote Link to comment Share on other sites More sharing options...
Nev Posted January 30, 2015 Share Posted January 30, 2015 I'm just doing my wing fairing bit now and am trying incorporate the same thing. I've shaped / sanded the hardwood block to angle back about 8 degrees, I think it will be enough. Not done the fus yet though so am doing it a bit blind. I am assuming I can fit the mating plate in the fus to suit the wing as I build it, looks like that's how you have done it. Good timing. Nev. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 30, 2015 Author Share Posted January 30, 2015 I just kept fitting n fiddling till I got the wing to fit Nev, nothing wrong with two bolts I prefer this is all. You could move the fuzz former back slightly and shape some balsa glued to it maybe. John Quote Link to comment Share on other sites More sharing options...
Nev Posted January 30, 2015 Share Posted January 30, 2015 I'm expecting a bit of fettling later Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 1, 2015 Author Share Posted February 1, 2015 Bit more done, seems like we are struggling with our mojos a bit The rear of my wing is sorted, I put two dowels at front and a wing bolt at the rear and I can fit it and have a small gap. John Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 1, 2015 Author Share Posted February 1, 2015 And here we have it, bit of fettling to do when flaps and fairing are fitted. John Edited By john stones 1 on 01/02/2015 19:28:41 Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted February 1, 2015 Share Posted February 1, 2015 nice Quote Link to comment Share on other sites More sharing options...
Nev Posted February 1, 2015 Share Posted February 1, 2015 Nice one John, looks like it's going to workout well. That must be most of the big stuff done now, you should soon be able to crack on with the rivets. I'm not flagging, just a bit slower than most. It has its advantages though, you ca see how everybody else have done it first. Nev. Quote Link to comment Share on other sites More sharing options...
A.A. Barry Posted February 1, 2015 Share Posted February 1, 2015 good work John Barry Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 1, 2015 Author Share Posted February 1, 2015 Thanks lads, fairings next, so best read through some blogs John Quote Link to comment Share on other sites More sharing options...
A.A. Barry Posted February 1, 2015 Share Posted February 1, 2015 John, I found it easier to fix the wing to the Fuz and build accordingly, following the wing profile Barry Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 1, 2015 Author Share Posted February 1, 2015 That's my plan Barry, i'll be back John Quote Link to comment Share on other sites More sharing options...
Nigel Day Posted February 2, 2015 Share Posted February 2, 2015 Nice one John. You'll enjoy the fairings.... Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 3, 2015 Author Share Posted February 3, 2015 Planed and sanded flaps/ailerons up and cut hinge slots, apart from G3 the rest of plan cut bits are rubbish on the fairings, tomorrows the big day John Quote Link to comment Share on other sites More sharing options...
A.A. Barry Posted February 4, 2015 Share Posted February 4, 2015 Yes John I had much the same opinion, after several attempts of using them,.....I laid a template up to the Fuz and fashioned my own Barry Edited By A.A. Barry on 04/02/2015 00:29:35 Quote Link to comment Share on other sites More sharing options...
Andy Muckley Posted February 4, 2015 Share Posted February 4, 2015 Same here John i just basically made them to suit the flaps and profiled them back to the fus, lokking good may i add Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 5, 2015 Author Share Posted February 5, 2015 I viewed the Silver fullsize photo then went with what I thought it showed, so I did the ply rear piece straightish Here's my bits. John Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 5, 2015 Author Share Posted February 5, 2015 Here's what it looks like before sanding John Quote Link to comment Share on other sites More sharing options...
A.A. Barry Posted February 5, 2015 Share Posted February 5, 2015 Yep looks good to me If I had thought of it earlier, I would have concaved the fairing T/E, rather than convexed, it would look a lot better Barry Edited By A.A. Barry on 05/02/2015 20:13:24 Quote Link to comment Share on other sites More sharing options...
Nev Posted February 5, 2015 Share Posted February 5, 2015 I think thats how it should be too. It just looks curved from certain angles. Yours looks very straight though, looking from the tail is the top bit of sheet curved in the same way as the bottom, that would make it look curved. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 5, 2015 Author Share Posted February 5, 2015 I slotted the ply into the fuzz, but never glued it until I clamped the sheeting on, now it has taken on the curve (not glued in pic) that make sense to you ? And there's a bit of sanding to do yet John Edited By john stones 1 on 05/02/2015 20:23:29 Quote Link to comment Share on other sites More sharing options...
Nev Posted February 5, 2015 Share Posted February 5, 2015 Rubbish drawing but this is what i was trying to say. The curve of fuselage to wing filet, continuing into the fairing will make it "look" as if the rear edge has a curve and not just a straight 45 deg angle still not making sense, sorry. but when you get it sanded into a nice curved filet i think it will look the part. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted February 5, 2015 Author Share Posted February 5, 2015 Yes that's how it looks Nev, I should have used my green card John Quote Link to comment Share on other sites More sharing options...
Nev Posted February 5, 2015 Share Posted February 5, 2015 should look great. I noticed some blue card creeping in on your gunfighter build too Quote Link to comment Share on other sites More sharing options...
