Steve McLaren Posted April 1, 2015 Author Share Posted April 1, 2015 That's a very good question Phil! I have done some trials with solar film direct on to depron and although it sticks OK it produces a textured surface with a lot of little holes. I'm going to try a light skim of filler to see if that improves things. Will let you know. . not started on the real covering yet. Had to go away on business. Quote Link to comment Share on other sites More sharing options...
Phil Cooke Posted April 2, 2015 Share Posted April 2, 2015 I haven't tried this product yet, but have noticed it in the mags over the past few months and need to get a bottle - FOAM ARMOUR from Deluxematerials - have you seen this? Might be the simplest solution?? **LINK** Quote Link to comment Share on other sites More sharing options...
Peter Garsden Posted April 2, 2015 Share Posted April 2, 2015 Ah yes foam armour - it is actually water based resin which I have got a bottle of. On my second actually. I was told you could save money by using varnish but it is not the same. I use it for coating light glass fibre. I am going to coat the tailplane in .25gram cloth and the water based resing which is brilliant stuff as indeed is anything Deluxe do. I am sure that it weighs less than epoxy resin, and dries in 20mins! Quote Link to comment Share on other sites More sharing options...
Steve McLaren Posted April 3, 2015 Author Share Posted April 3, 2015 Thanks for the tip Phil. I will order some for future use, but there's no way it's going to be here in time to help with this one! I tried the skim of lightweight filler today and it does seem to improve the finish. I also tried just putting a 2nd layer of film over the first and that helps too. So I'm going to go with these options. I did the tailplanes, fin and ailerons today. The fuselage and wing have to happen tomorrow. Quote Link to comment Share on other sites More sharing options...
Steve McLaren Posted April 10, 2015 Author Share Posted April 10, 2015 Mine is not finished either. But there's enough of it there that it should be able to manage a test flight. It weighs in at 42oz, which is way heavier than I was expecting. but with probably too much lead in the nose at the moment. Quote Link to comment Share on other sites More sharing options...
Mark Kettle 1 Posted April 10, 2015 Share Posted April 10, 2015 Nice Steve cu2moro Quote Link to comment Share on other sites More sharing options...
Andy Meade Posted April 10, 2015 Share Posted April 10, 2015 Some nice looking aircraft there gents. I had a good fly this afternoon to make sure the lift was all ok for you had a few flights with the Pike in gorgeous weather, and a couple with the JP too. Met up with Tim and Mark, so now the scene is all set for the morning! See you guys soon! Quote Link to comment Share on other sites More sharing options...
Phil Cooke Posted April 10, 2015 Share Posted April 10, 2015 42 oz is a good weight Steve - mine is 50 if I can trust my scales - maybe they need re-calibrating?? Your model looks superb - I'm glad we are getting to see a camo one tomorrow - excellent! See you in the morning. Quote Link to comment Share on other sites More sharing options...
Steve Houghton Posted April 10, 2015 Share Posted April 10, 2015 This promises to be a weekend of good looking models, and a fantastic squadron of Tornados. I hope you've all practised your formation flying for the cameras? Steve, I love your finished model. Congratulations on another fine result, to sit proudly alongside the Gnat and JP. Edited By Steve Houghton on 10/04/2015 23:22:30 Quote Link to comment Share on other sites More sharing options...
Phil Cooke Posted April 10, 2015 Share Posted April 10, 2015 Yes there's certainly going to be a number of new models and maiden flights tomorrow you can tell it's the start of a new season Quote Link to comment Share on other sites More sharing options...
Mark Kettle 1 Posted November 10, 2016 Share Posted November 10, 2016 A nice model Steve, I've got a little bit of footage of it flying so here's a edited video of it flying at Anne's Place Saturday 13th August 2016. Edited By Mark Kettle 1 on 10/11/2016 13:51:03 Quote Link to comment Share on other sites More sharing options...
