Ian Mat Posted September 30, 2015 Author Share Posted September 30, 2015 The first two photos are from the good side, as you can see the retract mount rail is flush with the curvature of the rib and will be covered by the skin. However, the other side protrudes by about 3mm: I can't believe I didn't spot it while I was gluing it all together... I think I can probable take the edge off the retract unit and chamfer the mount rail to suit the wing profile. I will be able to make the undercarriage legs the correct length so the model sits parallel to the ground and I'm not sure anyone will notice one leg being 2 - 3 mm longer than the other! Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted September 30, 2015 Share Posted September 30, 2015 Could you not shave the bearer down with a tapered Dremel bit sharp chisel ? John Quote Link to comment Share on other sites More sharing options...
Ian Mat Posted September 30, 2015 Author Share Posted September 30, 2015 John, the wood part if the bearer shouldn't be a problem, it's the metal part of the retract I'm more concerned with... I don't think removing the visible metal corner will cause to much of an issue. Quote Link to comment Share on other sites More sharing options...
Rosco Posted September 30, 2015 Share Posted September 30, 2015 Why not add 3mm to the lowest bearer so they both protrude symetrically? Quote Link to comment Share on other sites More sharing options...
Ian Mat Posted September 30, 2015 Author Share Posted September 30, 2015 Rosco, that's a great idea! I didn't think of that... I will try that if I can successfully make the protruding side fit within the skin. Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted September 30, 2015 Share Posted September 30, 2015 Hi Ian, I had a similar issue with my TF P40, I chamfered the metal edge down and it went OK. Otherwise it's coming on a treat your doing a great job. Regards Robert Quote Link to comment Share on other sites More sharing options...
Ian Mat Posted October 1, 2015 Author Share Posted October 1, 2015 Yesterday evening I built other two parts the the wing, I'm pleased to say that this went much more smoothly then the central section. The only real issue I had was the the jig pieces were missing from a number of the ribs and I had to spend a while trying to find them in the mixture of discarded wood in the box. This was the end result: Left them to dry overnight and then this morning joined the whole lot together, which was a time consuming job, but well worth doing properly. I think I've even ended up with a non twisted wing! So that lot will have to dry overnight, then I'll start shaping the leading and trailing edges, assuming it's not raining tomorrow... I can't really do that much sanding in the dining room or garage. Does anyone have any tips on how to achieve a uniform shape over that length, or is it just trial and error? Quote Link to comment Share on other sites More sharing options...
Ian Mat Posted October 3, 2015 Author Share Posted October 3, 2015 OK so I shouldn't have been worried about the retracts protruding too much from the bottom of the wing... I've now discovered that both retracts protrude from the top of the wing!!! in fact from my measurements the retracts don't actually fit within the depth of the wing!!! Only by about 4mm but I'm starting to understand where the experience is needed in a model like this... Quote Link to comment Share on other sites More sharing options...
Mr.B. Posted December 3, 2015 Share Posted December 3, 2015 Hello chaps. Ian has badly hurt his back following an accident at home. I'm sure you'll join me in saying "get well soon" and "get back to work on the Corsair!" Mr B Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted December 3, 2015 Share Posted December 3, 2015 Hi Ian, Sorry to hear about your accident. Get well soon, the Corsair will still be there waiting for you. I was wondering what had happened to you, your build rate is tremendous, wished I could build that fast. Regards Robert Quote Link to comment Share on other sites More sharing options...
Ian Mat Posted December 6, 2015 Author Share Posted December 6, 2015 Thanks for the support guys! I've managed to get off lightly, from what could have been a very serious accident. I slipped on the stairs at home and managed to break a vertebra in my back... fortunately there is no nerve damage and I will make a full recovery in a few months. Unfortunately the Corsair has had to move to the back burner, however I will start back on it as soon as I can. Quote Link to comment Share on other sites More sharing options...
jim longbon Posted December 28, 2015 Share Posted December 28, 2015 HI Ian. I wouldn't worry to much, I started a build on this same top flite kit some 14 years ago, I ordered up some twist and turn air operated retracts from Unitracts. The time and trouble it took me to install them put a real damper on doing any more to the kit and it was put up on a shelf in the workshop. It hung over me and points an accusing finger. I took it back off the shelf a couple of months back with Bit of renewed enthusiasm and started again this time doing bit of retro fitting of the pilots cockpit and now have decided to convert it over to electric. If anybody out there has already done this how did you make the battery hatch. While putting in the retracts did you have to cut away a rather alarming amount of the wing formers to accommodate the main body of the retract unit (another reason it went up on the shelf). my confidence in the wing strength has been compromised. Still is that why we build just to get around problems. Like all the rest hope you better feel soon. Jim Longbon. Quote Link to comment Share on other sites More sharing options...
G-JIMG Posted April 20, 2016 Share Posted April 20, 2016 For what it's worth, I put Lado retracts with Robart Struts in my TF Corsair. Easy to install and they work a treat. As for the engine, I installed an RCV 120-SP. A bit overpowered but I figure if you need weight in the nose it might as well be useful weight, and it swings a 16" 4 bladed prop beautifully. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted April 20, 2016 Share Posted April 20, 2016 Just for future reference (as I have the TF Corsair 'Gold' kit and Lados waiting in the queue) how is the ground handling with the 90 degree retracts? Any nasty pecking tendencies on accelerating or landing? Edited By Bob Cotsford on 20/04/2016 14:22:57 Quote Link to comment Share on other sites More sharing options...
G-JIMG Posted April 26, 2016 Share Posted April 26, 2016 Bob, I angled mine slightly forward during the build to reduce the "pecking tendency". It's trial and error between getting the wheels as far forward as possible when they're down and being able to close the doors when they're retracted. Quote Link to comment Share on other sites More sharing options...
Ian Mat Posted April 26, 2016 Author Share Posted April 26, 2016 I have angled the struts forward, as you suggest and seeing as I don't plan on adding any sort of doors, the angle can be changed as necessary. I am hoping to restart the build fairly soon, however I am now working a fair commute from home, so my building time is severely limited! Quote Link to comment Share on other sites More sharing options...
DelRay Posted April 26, 2016 Share Posted April 26, 2016 Gents, If I may interject a suggestion regarding the rudder and tailwheel linkage. I bought this model already built a couple of years ago, complete with the Robart, rotating retracts, and the fella did a fine job, but I spent considerable time redoing several things on the plane before first flight. My suggestion is to run a separate control rod to the rudder and another to the tail wheel, this eliminates the alignment troubles between the two, and the adjustment capabilities at the servo end make it capable of having different throws on each part. Just another note of caution, don't use a plastic clevise on the elevator control horn link, I also modified this area with a metal clevise. I cut an access panel in the bottom of my fuselage to gain entry to elevator and rudder/tailwheel controls. I would definitely install individual aileron servos in each wing. Just some thoughts, maybe they might help. The plane flies awesome, mine has a Saito 1.00 four stroke in it, changed from a Super Tiger .90. Good luck on the building Take care, chat later, Jim Edited By DelRay on 26/04/2016 13:19:39 Quote Link to comment Share on other sites More sharing options...
DelRay Posted April 26, 2016 Share Posted April 26, 2016 Quote Link to comment Share on other sites More sharing options...
DelRay Posted April 26, 2016 Share Posted April 26, 2016 Sorry, I forgot the pic post process, been awhile. Jim Quote Link to comment Share on other sites More sharing options...
G-JIMG Posted May 17, 2016 Share Posted May 17, 2016 Just another thought regarding the Main Wheels and how to reduce the 'pecking tendency'. The TF Corsair has the Wing and Stab incidence angles set at zero, unlike the real Corsair which has them at 2 and 1.25 degrees respectively. Changing them both by 1 degree has numerous benefits: 1. The Main Wheels are automatically moved further forward. 2. It effectively introduces down thrust, making the model easier to fly. 3. The model's attitude in level flight is closer to that of the real aircraft. Note that both incidence angles have to be changed by the same amount if the model is to remain flyable. Quote Link to comment Share on other sites More sharing options...
marc.stamant Posted January 20, 2023 Share Posted January 20, 2023 I guys, is this build for the Corsair gold edition or the other one from Top Flite known as the red box Corsair as the box for it was red...thanks. Marc. Quote Link to comment Share on other sites More sharing options...
