Jack Banner Posted November 3, 2015 Share Posted November 3, 2015 Now I have your attention... Can anyone help me source some longer screws for fixing these control horns to a thick Aileron? **LINK** The supplied screws are 9mm long but I need at least 14mm of threaded screw. I am sure i bought some of these before but just cannot remember where from. Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted November 3, 2015 Share Posted November 3, 2015 Jack, try Modelfixings - I've found them pretty good when you are looking for anything a bit different in the screws/bolts/nuts/clips line. BEB Quote Link to comment Share on other sites More sharing options...
Former Member Posted November 3, 2015 Share Posted November 3, 2015 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted November 3, 2015 Share Posted November 3, 2015 I'd take a guess at those being M2?? Those fine chaps at Modelfixings should short you out OK..... Quote Link to comment Share on other sites More sharing options...
Jack Banner Posted November 3, 2015 Author Share Posted November 3, 2015 thanks guys, I had a look on model fixings but couldn't see anything that matched exactly. I will have another butchers. Quote Link to comment Share on other sites More sharing options...
Old Geezer Posted November 3, 2015 Share Posted November 3, 2015 You could also have a look at Airtek - he's starting to get quite a few odds and ends lately - looked as if he might have what you're looking for. Agree M.F. do an excellent job, but unless things have changed, there's a minimum transaction value to consider - just a thought. Quote Link to comment Share on other sites More sharing options...
David Ovenden Posted November 3, 2015 Share Posted November 3, 2015 On Ebay there are m2 x 14 screws see item no 360660198608 Any use? Quote Link to comment Share on other sites More sharing options...
Geoff S Posted November 4, 2015 Share Posted November 4, 2015 Posted by Gurth Scriven 2 on 03/11/2015 22:42:14: You could also have a look at Airtek - he's starting to get quite a few odds and ends lately - looked as if he might have what you're looking for. Agree M.F. do an excellent job, but unless things have changed, there's a minimum transaction value to consider - just a thought. I can't say I ever have any problem finding enough bits and pieces from Modelfixings to make up any minimum order charge. I like to keep my stock of metric nuts, bolts ready for most eventualities There's not much that I need that Ian at MF doesn't stock in the fixings line and postage is always very prompt. Geoff Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted November 4, 2015 Share Posted November 4, 2015 My problem with modelfixings is to stop finding things to add to my list be cause "It will be useful!!" Anyone who does not use their caphead servo screws just doesn't know how much time and effort they are wasting, same with engine mounting screws. I needed some longer than average 6mm nylon bolts for my toilet cistern lid. THE ONLY PLACE that I cold find ones that were long enough was model fixings. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted November 4, 2015 Share Posted November 4, 2015 If by some miracle you can't find them on Modelfixings or don't want to make up the minimum order then Ebay is a good source of odds and ends in small quantities - for example M2 * 20mm stainless ps - I find it best to use slightly longer screws than necessary as it gives more wiggle room when locating them in the backing plate. Once tightened cut them down with side cutters then take the burr off with a needle file. Edited By Bob Cotsford on 04/11/2015 08:30:07 Quote Link to comment Share on other sites More sharing options...
GONZO Posted November 4, 2015 Share Posted November 4, 2015 This thread title reminds me of a very very old joke. Its not at all PC and the mods may wish to remove it. "A long time inmate of a mental institution escaped and whilst on the run broke into a local laundry. Whilst there he sexually assulted a female worker and then run off. Next day the headlines in the local paper read, Nut Screws Washer - Bolts. " Quote Link to comment Share on other sites More sharing options...
