Gary Vinten 1 Posted December 9, 2015 Share Posted December 9, 2015 Hi all i am just building my first edf jet as this build has a lot of ply parts i have opted for cut parts !!!!! so her is my start please feel free to comment Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted December 9, 2015 Share Posted December 9, 2015 Only three things really..............weight, weight and weight! Good luck with it though. Quote Link to comment Share on other sites More sharing options...
Gary Vinten 1 Posted December 9, 2015 Author Share Posted December 9, 2015 not sure on the weigh t but it has a 2300watt 12blade edf running a 6s 5000mhr lipo Quote Link to comment Share on other sites More sharing options...
AVC Posted December 9, 2015 Share Posted December 9, 2015 Hi Gary It looks nice so far... Is it a Northrop F-5? It's difficult to know at this stage. Where did you get the plan? Thanks! Edited By AVC on 09/12/2015 11:37:58 Quote Link to comment Share on other sites More sharing options...
Rosco Posted December 9, 2015 Share Posted December 9, 2015 Great stuff Gary I'll be watching. I have found that there does not seem to be much interest in EDF models on here so it will be a change to Spitfires and petrol powered model builds. I fly a few EDF foamies and building a balsa/ply Jet has crossed my mind a few times so you've got my interest Rosco Quote Link to comment Share on other sites More sharing options...
Martyn Johnston Posted December 9, 2015 Share Posted December 9, 2015 Hi Gary. Do you know what model it is? Or is it just a randon, generic 'EDF Jet ? Quote Link to comment Share on other sites More sharing options...
Martyn Johnston Posted December 9, 2015 Share Posted December 9, 2015 My little, foam EDF Vampire from HobbyKing is the best fun/£ plane that I've got. So It'll be nice seeing a 'proper' wooden EDF jet go together. Quote Link to comment Share on other sites More sharing options...
Gary Vinten 1 Posted December 9, 2015 Author Share Posted December 9, 2015 Hi AVC It is a sports jet my build was the inspiration from David Ashby in his editorial, i have the pleasure of flying with David at our local club, and he's been flying some foam edfs which look very impressive and sound quite good !!!! As i am a balsa basher mine will be in balsa and ply then finished in the normal way Quote Link to comment Share on other sites More sharing options...
Gary Vinten 1 Posted December 9, 2015 Author Share Posted December 9, 2015 Hi Rosco Good to have you on board Quote Link to comment Share on other sites More sharing options...
AVC Posted December 9, 2015 Share Posted December 9, 2015 Thanks Gary for the info, I'll be following this with interest Quote Link to comment Share on other sites More sharing options...
Steve Adams Posted December 9, 2015 Share Posted December 9, 2015 Is this of your own design Gary? Looks very neat so far,as I've seen from a lot of your builds mainly plan ones you certainly build in that no expense spared quality with all your models! A plan for a sports jet would be great in the mag and would go down a treat I'm sure Kind Regards Steve Quote Link to comment Share on other sites More sharing options...
Gary Vinten 1 Posted December 9, 2015 Author Share Posted December 9, 2015 motor installed 2300 watt on 6s Quote Link to comment Share on other sites More sharing options...
Gary Vinten 1 Posted December 9, 2015 Author Share Posted December 9, 2015 Hi Steve No this is a plane build i may change it a little but not sure until i am into the build Quote Link to comment Share on other sites More sharing options...
AVC Posted December 9, 2015 Share Posted December 9, 2015 Hi gain Gary? Where did you get the plan from? And what is the size of the bird? Thanks! Quote Link to comment Share on other sites More sharing options...
Gary Vinten 1 Posted December 9, 2015 Author Share Posted December 9, 2015 ok some specs wingspan 50" fuselage 54" AUW Should be no more than 3.4kg 80mm edf static thrust 2.6kg watts 2300 /2100 lipo 6s 5000 45/90c ESC 120amp timing high Quote Link to comment Share on other sites More sharing options...
Gary Vinten 1 Posted December 12, 2015 Author Share Posted December 12, 2015 ok done a little more still have the bottom and intake ducts to do I will coat in poly c and light weight nylon under coat and top coat anyway thats for later Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted December 12, 2015 Share Posted December 12, 2015 Looking very nice Gary, can we have a look at the wing and tail/fin please on the plan ? John Quote Link to comment Share on other sites More sharing options...
Daniel Bird Posted December 13, 2015 Share Posted December 13, 2015 I think I recognise your build, its Shane Hardings Razor 90 from Traplet isn't it? I also have the plan and parts ready to start, going to crack on with this over Christmas. Please keep posting updates, I would like to follow your progress. Dan Quote Link to comment Share on other sites More sharing options...
Rosco Posted December 13, 2015 Share Posted December 13, 2015 Whatever it is, it's looking good!I thought it looked a bit 'Hawk'ish at first but it dosen't matter, like I say, it's looking good Gary. Keep up the good work mate. Quote Link to comment Share on other sites More sharing options...
Gary Vinten 1 Posted December 14, 2015 Author Share Posted December 14, 2015 Thanks rosco dan are you going to do a build thread what motor lipo esc have you chosen Quote Link to comment Share on other sites More sharing options...
Daniel Bird Posted December 15, 2015 Share Posted December 15, 2015 Hi, Yes I may well take some photos as I go through the build - this is my first build from a laser cut set of parts, I feel spoiled! I have just finished (well not quite but test flown) a Tony Nijhuis vampire which I built for EDF. The test flight was excellent! I have a 90mm jetfan with Het 700 1200Kv motor and it had plenty of power on 12s and good enough on 10s. The model weighed in at 16.25lb AUW. For this build I have a Wemotec midi evo with 650 68 1340 motor which I intend to use on 8s batteries (well two 4s in series). Maybe an odd choice but I picked it up second hand new on the BMFA for a good price. On 8s it should be around 1700Watts which I thought would be plenty of power. Haven't decided what im going to cover this model with, either film of glass cloth. Really looking forward to starting this one, the design is really nice and the plans well drawn. I had a good chat with Shane at Weston, very nice chap and I'm sure willing to offer advise when required. I also bought the wood set for his Hunter . Dan Quote Link to comment Share on other sites More sharing options...
Gary Vinten 1 Posted December 15, 2015 Author Share Posted December 15, 2015 is Shane on this site to advise as i would like to know his setup and auw etc Quote Link to comment Share on other sites More sharing options...
Gary Vinten 1 Posted December 15, 2015 Author Share Posted December 15, 2015 Quote Link to comment Share on other sites More sharing options...
Daniel Bird Posted December 17, 2015 Share Posted December 17, 2015 Hi, I can see a Shane Harding on the members list so hopefully he will notice this thread. Have you looked at the wing yet? I'm unsure about the trailing edge arrangement, it appears to be made of solid balsa but at the wing centre this would be a big chunk. The wing could have really used a cross section view on the plan. The other thing that's not 100% clear is the 1/4" sq spars - they appear to be balsa from the grain pattern drawn but it cant see where this is confirmed. Have you choosen retracts? The bearers appear to be the correct size for eflite 25-40 set. Dan Quote Link to comment Share on other sites More sharing options...
