Peter Etherington 1 Posted January 3, 2016 Share Posted January 3, 2016 Just sent off for the David Boddington 60 inch Bleriot XI plans for 0.30 glow engines but I was thinking of putting a 4 stroke in it. Ive narrowed the field down to the APS 30 FS or the ASP 52 FS. Many years ago I seem to remember someone saying to me that when using 4 strokes go up in cc because they dont have the poke of a 2 stroke. Is this still the case? Would appreciate any information please. Just done some research and found that the PAW 29 which is on the plans weighs in at 300g and the ASP 30 FS weighs in at 275g and the ASP 52 FS is 455g. Many thanks, Peter Edited By Peter Etherington 1 on 03/01/2016 18:59:12 Quote Link to comment Share on other sites More sharing options...
J D 8 Posted January 3, 2016 Share Posted January 3, 2016 I have an old Boddington Bleriot XI I am restoring and thought about fitting a 4 stroke for a better sound. However there was just not enough length in the cowl to fit one without the prop shaft sticking out to far or having to butcher the bulkhead which I did not want to do so two stroke it stays. However as a new build you can no doubt modify yours to make room. The difference between modern two and four strokes is not as much as with early four strokes but it is still normal to fit a bit larger capacity. John. Quote Link to comment Share on other sites More sharing options...
Former Member Posted January 3, 2016 Share Posted January 3, 2016 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Jimbo565 Posted January 3, 2016 Share Posted January 3, 2016 Peter This is my model inspired by Lyndsay Todd's Dawn Flyer,similar type of model originally for 30 2st. I have OS26 fs and although it has not flown yet it skeets around the garden like a wild thing,a 52 would be totally OTT. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 3, 2016 Share Posted January 3, 2016 How about this John Quote Link to comment Share on other sites More sharing options...
Peter Etherington 1 Posted January 3, 2016 Author Share Posted January 3, 2016 Thanks very much gents for all the info. I will go for the 30 size, Regards, Peter Quote Link to comment Share on other sites More sharing options...
Peter Etherington 1 Posted January 6, 2016 Author Share Posted January 6, 2016 We will have to see Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted January 13, 2016 Share Posted January 13, 2016 Posted by Peter Etherington 1 on 03/01/2016 18:43:11: Just sent off for the David Boddington 60 inch Bleriot XI plans for 0.30 glow engines but I was thinking of putting a 4 stroke in it. Ive narrowed the field down to the APS 30 FS or the ASP 52 FS. Many years ago I seem to remember someone saying to me that when using 4 strokes go up in cc because they dont have the poke of a 2 stroke. Is this still the case? Would appreciate any information please. Just done some research and found that the PAW 29 which is on the plans weighs in at 300g and the ASP 30 FS weighs in at 275g and the ASP 52 FS is 455g. Many thanks, Peter Edited By Peter Etherington 1 on 03/01/2016 18:59:12 Hi Pete, The ASP 30 has flown similar models for me on both a 9 x 5 and 9 x 6 props, importantly using 10% Nitro mix. These small motors take about an hour to run in and to achieve the 9000 - 10000 revs claimed, as 8000 is more like it when new. Also the tick over when new is far too high around 3000, you cannot land as it flys by you. when run in, your motor should tick over around 2300 for landings It does run adequately on straight fuel, but I have found with modern synthetic fuels with 10%, have all my 4 strokes running well. As you discovered, the 4 strokes are bigger but well worth the modifications, simply moving the bulkhead back Quote Link to comment Share on other sites More sharing options...
Birgir Posted January 21, 2016 Share Posted January 21, 2016 Hi Peter Did you get the PAW 29? B. Quote Link to comment Share on other sites More sharing options...
Mike Etheridge 1 Posted January 21, 2016 Share Posted January 21, 2016 Now there's a coincidence, a few years ago I bid and won on E-bay for a PAW 29 RC motor which to date I have not used. I was surprised to discover that the seller was Dave Boddington and of course it may well have been the engine he used in the Bleriot ? Quote Link to comment Share on other sites More sharing options...
Birgir Posted January 21, 2016 Share Posted January 21, 2016 WOW! Quote Link to comment Share on other sites More sharing options...
