Phil Cooke Posted March 3, 2016 Share Posted March 3, 2016 Hiya John, great to see you on here with your own A-4 build thread! Is the day-glo A-4A your chosen subject? It looks great in those colours you wont be losing that one! It will be good to see a UK PSS design being put through its paces at one of the ISS events I look forward to that! Quote Link to comment Share on other sites More sharing options...
John H. Rood Posted March 3, 2016 Share Posted March 3, 2016 Yeah, Phil! Really I am torn between that bird and that foxy astrophysicist CHARLIE's imaginary Aggressor A-4E out on the flightline at NAS Miramar. My first thought is to keep it simple and follow the build plan for an A-4E or A-4F; I absolutely LOVE the Aggressor colour schemes, and their overall clean lines. But as a youngster in the 1960s I grew up seeing sometimes the bright red & white colors on jets out in the Mojave and Inyokern deserts --- and nowadays at age 61 (almost) I can DEFINITELY benefit from a bright dayglo scheme. Here is that same particular aircraft (Bu.139934) with a different unit a bit later, circa 1961-63... some hi-viz panels are there, but they are hard to see clearly in the photo: And below now again is my first attempt at an A4D / A-4A nose profile fitted to your 1/12th scale design. Mainly it is just shorter, a higher C/L, and the air intake is unswept and a tad further aft. Everything else looks roughly the same, and the A4D-1 had no refueling probe. As always, my main focus is to get the pilot relief tube operating properly. Last but most importantly, if all goes to plan, the Mark I Eyeball and the K.I.S.S. principle will be in heavy rotation throughout this little project. Quote Link to comment Share on other sites More sharing options...
John H. Rood Posted March 3, 2016 Share Posted March 3, 2016 "Call-sign Charlie, Lady, git outa the way! You're blocking our view of Jester's Top Gun Tinker Toy!" Edited By John_Rood on 03/03/2016 20:51:07 Quote Link to comment Share on other sites More sharing options...
Andy Meade Posted March 4, 2016 Share Posted March 4, 2016 That looks like a great nose profile John - I think it's great that you're going to the trouble to model this extra variant. Will you / can you share a PDF of the changes once complete, so that others could follow? Git 'er done! Quote Link to comment Share on other sites More sharing options...
John H. Rood Posted March 16, 2016 Share Posted March 16, 2016 Posted by Andy Meade on 04/03/2016 12:24:43: ...Will you / can you share a PDF of the changes once complete, so that others could follow? Andy: YES -- I will do! Edited By John_Rood on 16/03/2016 16:50:16 Quote Link to comment Share on other sites More sharing options...
John H. Rood Posted March 16, 2016 Share Posted March 16, 2016 Humiliatingly, it's been literally YEARS since I've had a workshop up and running, and so this project is a major reentry for me. My first real task has been to reestablish a workspace. Neglect is COSTLY! This has been a REAL battle, but I am now seeing light at the end of the tunnel... My building board is a flat, heavy piece of 3/4" hardwood with a pin-friendly flip-side of Masonite sheet attached to the board with Gorilla Glue. Reference lines are helpful for me as I'm a nut about geometry and so forth. I'm building from Traplet's laser-cut kit and it incorporates the minor fine-tuning bits discussed thus far on the Mass Build thread. Helpful --and totally unlike my natural "chaos unravelling" project mismanagement style -- the cool list of other needed stock items! And here's a good bit of my10+ year old stash of medium soft through medium-hard balsa, spruce, and ply. I'm dumb and unwise, but over the intervening years I actually WAS wise enuff to keep this stash well-ensconced under the bed and away from high heat, cold, humidity extremes. And lastly here's Clancy The Douglas Tech Rep --- with The Supreme Allied Commander (a drunk feral frog) listing at times overhead with a watchful, wandering eye or two... Quote Link to comment Share on other sites More sharing options...
John H. Rood Posted March 16, 2016 Share Posted March 16, 2016 And yes, that cat up there is inside his exact-scale mockup of a 1/15th scale C-17 transport's cargo bay. Some crazed gent in the PSSA UK has one underway, and my cat has been enlisted as a stress-tester. Quote Link to comment Share on other sites More sharing options...
John H. Rood Posted March 16, 2016 Share Posted March 16, 2016 Titebond II Gone Bad, and its Partners in Aeromodelling Crime: I'm trying SUPER-PHATIC for the first time, on the advice of friends. I hear nothing but GOOD things about the stuff. For USA modelers: http://www.horizonhobby.com/super-phatic%21-dlmad21 I bought these four from Horizon Hobby and service was VERY fast from Illinois to here in Boston. They get special air treatment, these Mass Build participants... 2 Quote Link to comment Share on other sites More sharing options...
John H. Rood Posted March 18, 2016 Share Posted March 18, 2016 The shorter nose profile of the A4D-1 is penciled-in... ...and happily the new nose profile will allow the battery box design to go in pretty much as-is... It makes it, just! Quote Link to comment Share on other sites More sharing options...
John H. Rood Posted March 18, 2016 Share Posted March 18, 2016 Heavy 90 degree angle stock to keep things more or less right. Quote Link to comment Share on other sites More sharing options...
John H. Rood Posted March 19, 2016 Share Posted March 19, 2016 Stiffening fuselage structure for wing attach fittings: Laminating balsa with ply, and epoxying-in the lock washer for the wing TE attach point. Quote Link to comment Share on other sites More sharing options...
John H. Rood Posted March 19, 2016 Share Posted March 19, 2016 OOPS -- I didn't think to mark the lines for F2 and F3 ahead of time... so I had to back into it... AND IT SHOWZ Because of this tardiness on my part, it proved to be a bit of a hassle to get these lines correct; in fact, from Phil's build thread I see that, to some degree, the fuselage alignment DEPENDS on them to be true. The lines on the sides are intended to slope a bit, as the box is at an angle to the fuselage reference line -- but the lines on top and bottom must be at 90 degrees. And hey yes my lines kinda LOOK a mess -- but I will be careful as this fuselage build proceeds because we really MUST have things straight and true. Quote Link to comment Share on other sites More sharing options...
John H. Rood Posted March 19, 2016 Share Posted March 19, 2016 Dry fitting the avionics box to former F2 and the balsa/ply F3. The balsa base is 1/8" medium-hard that I found in my stash. Lying down up front is former F1, which will be modified to accommodate the A4D's shorter nose profile. The box, too may need to be shortened a bit -- we'll see as things come together. On the plans I've now shaded in a preliminary side profile for the A4D's shorter nose, including a centerline (C/L) that runs below but parallel to the existing datum line. Edited By John_Rood on 19/03/2016 04:08:37 1 Quote Link to comment Share on other sites More sharing options...
John H. Rood Posted March 19, 2016 Share Posted March 19, 2016 A4D Nose Profile: Now drawing in a TOP VIEW. I don't know why the photo is flipped sideways! Some kind of forum website software quirk? No matter -- see that line marked "DOUGLAS REF LINE"? I incorporated it here because, to my eye, that appears to be the place -- a structural firewall, if you will -- where, forward of there, Douglas designers made future modifications to the nose profile. So I can use it as a reference point for "backdating" Phil's A-4E plan profiles to the earlier A4D configuration. Quote Link to comment Share on other sites More sharing options...
John H. Rood Posted March 19, 2016 Share Posted March 19, 2016 And so here is a top view, with the nose shape shaded in... and the dry-fit of the radio box and formers F2 and F3. All this fuss helps me see where I will in fact need to crop the nose end of the radio box -- in order to achieve the proper A4D nose profile AND build in the structural strength needed there. Phil and I were writing about this earlier today; it looks like it needs some trimming in order to get sandable blocks etc for a proper nose taper. Edited By John_Rood on 19/03/2016 18:43:56 Quote Link to comment Share on other sites More sharing options...
John H. Rood Posted March 19, 2016 Share Posted March 19, 2016 The Douglas Tech Rep has some concerns, too... 1 1 Quote Link to comment Share on other sites More sharing options...
Phil Cooke Posted March 19, 2016 Author Share Posted March 19, 2016 Good job John, the plan view profiles you've shaded look spot on, don't worry about shortening the battery box and nose by an inch or so, the prototype came out nose heavy with the battery as far forward as it would go on the plan as drawn, so you should still be about on the money for balance without the need for ballast. Its pleasing to see the shorter nose variant being modelled as well as the longer nosed 2-seater. Great stuff! Don't get any PVA on the cat Quote Link to comment Share on other sites More sharing options...
John H. Rood Posted March 19, 2016 Share Posted March 19, 2016 All GREAT to hear, thanks, Sir! Now here's just three quick things: 1.5" removed from the radio box, centerlines added to the box, and laminating sheets of 1/16th" x 4" medium balsa for the 1/4" sheet fuselage floor, here with the help of Super-Phatic and a heavy book of of proper British excellence from William Green and Gordon Swanborough. Why laminate? Because I am shocked and ashamed to discover that I have no decent 1/4th sheet balsa! WHAT kind of modeller lacks this most basic of life requirements? The cost, again, of not keeping at the hobby with proper rigor. Edited By John_Rood on 19/03/2016 21:42:39 Quote Link to comment Share on other sites More sharing options...
John H. Rood Posted March 20, 2016 Share Posted March 20, 2016 In hopes of getting things straight and true: Identifying reference lines and using them to secure alignment of this (important) forward fuselage module. I'm sorry again about some images flipping sidewise when I upload them to the website ... I don't understand why this is happening. Quote Link to comment Share on other sites More sharing options...
John H. Rood Posted March 20, 2016 Share Posted March 20, 2016 Each joint is glued now with Super-Phatic and all looks straight and true so far, as in, the lines all meet up centered and square as I'd hoped they would! Overnight I shall keep the weights on and pins in so things will hopefully stay in place as the moisture in the glue evaporates... things pull, twist, breathe... Edited By John_Rood on 20/03/2016 01:09:46 Quote Link to comment Share on other sites More sharing options...
John H. Rood Posted March 20, 2016 Share Posted March 20, 2016 So now to get further clarity on how the A4D configuration will play out here... Some skull-scratching yielded a basic plan, beginning with setting up reference lines (yet more!) and then making a simple template to see how it will look. I have no expertise whatsoever in digital design/drawing, so this is all magically ANALOG ... Quote Link to comment Share on other sites More sharing options...
John H. Rood Posted March 20, 2016 Share Posted March 20, 2016 Template fits the centerline perfectly. So this template serves as a model for me to visualize world peace oops I mean where to proceed with the nose construction! 1 Quote Link to comment Share on other sites More sharing options...
John H. Rood Posted April 5, 2016 Share Posted April 5, 2016 OK, so the REAL reason I am building a Skyhawk is that they were uniquely equipped with a special propulsion system for slope-soaring enthusiasts. Whaaaa??? That's right... FOR JUST IN CASE THE WIND DIES... Edited By John_Rood on 05/04/2016 14:22:09 Quote Link to comment Share on other sites More sharing options...
Pete B Posted April 27, 2016 Share Posted April 27, 2016 Hi John, Unfortunately we're not able to rotate images by editing the post. It may be that you're using an iPad or similar to take the photos? If so, there can be an issue of the orientation within the camera so it may be a matter of taking the pics with the camera in the same orientation that gives you a satisfactory result. You might find an explanation and some help in this thread. Pete Quote Link to comment Share on other sites More sharing options...
John H. Rood Posted April 27, 2016 Share Posted April 27, 2016 Thanks, Pete. I understand you there, and I'll check out that link. In any case, it's not a big deal --- and what I really need to focus on is the build itself! Cheers, thanks again. Edited By John_Rood on 27/04/2016 21:07:15 Quote Link to comment Share on other sites More sharing options...
