Andy48 Posted January 8, 2017 Share Posted January 8, 2017 I suggest if you look at the "How To" section of my documentation you will find out about the different firmwares and how to update your transmitter and receivers. Certainly you will not have the latest versions. However, first you will need to update OpenTX to the latest version, 2.1.9. **LINK** Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted January 8, 2017 Share Posted January 8, 2017 Graham I just checked one. It is normal for the D8R-II to have a Red LED on when working correctly. Have you tried a servo with it? Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted January 8, 2017 Share Posted January 8, 2017 So you have most of your receivers working, just not the X6R? My guess is, and it is only a guess, is that your Tx and older X8Rs are all using the Non EU RFsystem and the X6R was supplied on EU-LBT. If so, then your path of least effort would be to change the New Rx to Non EU. There's no real need to update OpenTx on your Tx. But that would give you the option of changing Rx firmware directly from the Tx. Otherwise just do it from a PC. If you want to take everything to EU-LBT. My guess is that you'll have to update both the Tx RF firmware and all your X8R receivers firmware. The advantage of doing so would be that any further new receivers would work straight away. Edited By Chris Bott - Moderator on 08/01/2017 15:37:43 Quote Link to comment Share on other sites More sharing options...
Andy48 Posted January 8, 2017 Share Posted January 8, 2017 Sorry, I beg to differ. Far better to update OpenTX now and have the latest telemetry setup, even if you only use RSSI and receiver battery voltage. If you stay with an older version of OpenTX, then every model will have to be individually changed should you later update. You will also find a plethora of conflicting information about how to use OpenTX on the internet if using an older version which will be confusing. Updating OpenTX is very easy indeed. It makes sense to update everything, once Tx and all X series Rx are all on EU LBT firmware then everything is more straightforward, and as Chris says, new Rx will be compatible. Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted January 8, 2017 Share Posted January 8, 2017 But Mike's issue, and the question in his opening post was about binding receivers to his transmitter. All this advice about OpenTx has not helped his understanding. If you actually read the sentence in my post, I say he doesn't need to, which is 100% true, but that it would give him more options if he did. Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted January 8, 2017 Share Posted January 8, 2017 I'm with Chris here. One of the criticisms levelled at Taranis is the complexity. OK, we know that actually it isn't that conplex - but it can seem that way to newcomers. Heaping conflicting advice on the OP simply plays into that false image of the complexity. Let the guy get his basic system working. At present things are so bad that he can't actually use the Tx for heavens sake! To him its an expensive paperweight, he can't even bind a damn Rx!! So let's give him a reason to like Taranis - to do that all he needs to do is to get the Tx and the Rx on the same version of the RF software. What version of OpenTx he has is completely irrelevant just at the moment - because whatever it is it will work, as long as he gets the RF systems compatible. Once he has a stable system that actually works, then we can worry about getting him to the latest versions and updating both the RF and OpenTx software. 35 years working in education tells me that it is always best to take folks forward one step at a time - build the knowledge with them. That way they understand. If you just come in as "the expert" and say "change this, this and that", OK, it'll probably work - but they will never know why or how and the next time there is a protocol change they will right back at square one - stuck. But, do it one step at a time, build it up alongside them, take them with you, then you give them understanding; then they can eventually stand on their own two feet. What's the old saying?,....give a man a fish and you give him a meal, teach him how to fish and you give him a livelihood! Well that's my version anyway BEB Quote Link to comment Share on other sites More sharing options...
Graham R Posted January 8, 2017 Author Share Posted January 8, 2017 Sorry, but I am beginning to get confused as to what I should do. It seems to me that I need to bite the bullet and just bring it all up to date (EU-LBT), that way its job done starting I presume with the Tx and OpenTx . Will you still be able to help me go down this route? If I do this, will I still be able to use all my old receivers?with the relevant updates Thanks to Chris and Andy for your continued help. Graham Quote Link to comment Share on other sites More sharing options...
Andy48 Posted January 8, 2017 Share Posted January 8, 2017 Sorry I still disagree. The version of OpenTX is very relevant due to the enhancements made in version 2.1 to update firmware in both the Tx and Rx. If he updates OpenTX, which is a simple, almost automatic process, he then greatly simplifies the job of updating his firmware. I too have 35 years in education, rising to a very senior level teaching both children and teachers, but I think you are wrong, why teach somebody something which they later will have to unlearn? Schools don't teach the Earth is flat only later to tell pupils it is round. Perhaps you are saying everyone should learn ICT by using DOS and then working through the various versions of Windows? Working his way up from 2.0 to 2.1 will build little or no knowledge, but just add a layer of unnecessary complexity and confusion. For me, update OpenTX to 2.1, then use the features in 2.1 to easily update the FrSky firmware to EU LBT on the Tx and each of his X series receivers. Then he will have an up-to-date system and be able to buy extra EU receivers without any further fiddling. It is very much more difficult to update the firmware and the receivers using OpenTX 2.0 and he will need extra hardware. Neither that hardware nor that updating procedure will be needed again. Quote Link to comment Share on other sites More sharing options...
PatMc Posted January 8, 2017 Share Posted January 8, 2017 IMO Graham would be best to decide who's advice he want's to follow then arrange to communicate via PM. Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted January 8, 2017 Share Posted January 8, 2017 Well it does seem that Graham is keen to bite the bullet and update everything. So Graham, I suggest that you follow Andy's link to the instructions that you are looking for. Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted January 8, 2017 Share Posted January 8, 2017 Posted by Andy48 on 08/01/2017 20:08:14: Sorry I still disagree. The version of OpenTX is very relevant due to the enhancements made in version 2.1 to update firmware in both the Tx and Rx. If he updates OpenTX, which is a simple, almost automatic process, he then greatly simplifies the job of updating his firmware. I too have 35 years in education, rising to a very senior level teaching both children and teachers, but I think you are wrong, why teach somebody something which they later will have to unlearn? Schools don't teach the Earth is flat only later to tell pupils it is round. Perhaps you are saying everyone should learn ICT by using DOS and then working through the various versions of Windows? Working his way up from 2.0 to 2.1 will build little or no knowledge, but just add a layer of unnecessary complexity and confusion. For me, update OpenTX to 2.1, then use the features in 2.1 to easily update the FrSky firmware to EU LBT on the Tx and each of his X series receivers. Then he will have an up-to-date system and be able to buy extra EU receivers without any further fiddling. It is very much more difficult to update the firmware and the receivers using OpenTX 2.0 and he will need extra hardware. Neither that hardware nor that updating procedure will be needed again. One can but try BEB Quote Link to comment Share on other sites More sharing options...
Graham R Posted January 9, 2017 Author Share Posted January 9, 2017 Tale of Woe Hi Guys, I thought I would go the route of updating Tx then receivers. Something has gone wrong. When I switch on the Tx I get the audio message "welcome to etc", the backlight flashes on then off and that it. Ah well, back to the drawing board. Graham Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted January 9, 2017 Share Posted January 9, 2017 I've not been involved directly in educating others but I think I have been educated to some extent and I have to say that under normal circumstances I'd agree with BEB. It's easier top absorb knowledge one step at a time. However - in this case I think Andy's last paragraph is the key - updating to 2.1 sidesteps the now redundant process of upgrading through the PC using the USB adaptor. Get the system to bind, learn OpenTX then if the OP is interested he can look into the background and development of the RF side. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted January 9, 2017 Share Posted January 9, 2017 Posted by Graham Russell on 09/01/2017 10:06:57: Tale of Woe Hi Guys, I thought I would go the route of updating Tx then receivers. Something has gone wrong. When I switch on the Tx I get the audio message "welcome to etc", the backlight flashes on then off and that it. Ah well, back to the drawing board. Graham One trap for the unwary is selecting the wrong transmitter model in Companion - settings - radio profile - radio type before downloading OpenTX - selecting Taranis Plus instead of the vanilla Taranis or vice verce. Quote Link to comment Share on other sites More sharing options...
Andy48 Posted January 9, 2017 Share Posted January 9, 2017 Graham You need to explain what you have done so far, otherwise everyone is just guessing. Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted January 9, 2017 Share Posted January 9, 2017 Whereabouts are you Graham? I wonder if there's a kindly forumite nearby who might be able to help if you could meet? Quote Link to comment Share on other sites More sharing options...
jim longbon Posted January 9, 2017 Share Posted January 9, 2017 Hi Grahame l hope you are getting your Tx/Rx problems sorted. What a great bunch of people who are willing to help. The giving a man a fish and teaching a man to fish anecdote is perfect. Thank you for leaving a light on in a dark place. From the questions you have posed, several issues have been resolved for me. Quote Link to comment Share on other sites More sharing options...
Graham R Posted January 9, 2017 Author Share Posted January 9, 2017 d itPosted by Andy48 on 09/01/2017 15:57:38: Graham You need to explain what you have done so far, otherwise everyone is just guessing. I downloaded the latest companion from a link that someone gave me, saved it on the mac went into opentx , connect up my taranisto the Mac pressed the 'write firmware to radio button . The file it wrote was taranisplus-en.bin I guess this was the wrong. file. Hope this helps Quote Link to comment Share on other sites More sharing options...
Graham R Posted January 9, 2017 Author Share Posted January 9, 2017 Posted by Chris Bott - Moderator on 09/01/2017 17:54:12: Whereabouts are you Graham? I wonder if there's a kindly forumite nearby who might be able to help if you could meet? Hi Chris, West Sussex Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted January 9, 2017 Share Posted January 9, 2017 I downloaded the latest companion from a link that someone gave me, saved it on the mac went into opentx , connect up my taranisto the Mac pressed the 'write firmware to radio button . The file it wrote was taranisplus-en.bin I guess this was the wrong. file. Hope this helps OK, can you tell us which version of Companion you have now? It usually tells you right at the top. If not then click Help then About. What you needed to do was to set up companion so it matches your particular Taranis exactly. That's in Settings - Settings - Radio Type. ONLY AFTER you've done that, should you download the firmware for the Taranis. That's by File - Download, and save it somewhere you can remember. Once dowloaded, it needs to be written to the Taranis. At this stage you need to ensure that you're writing the version (filename) that you just downloaded. Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted January 9, 2017 Share Posted January 9, 2017 PS - West Sussex is a very long way for me, but you never know, someone may be close. Quote Link to comment Share on other sites More sharing options...
Graham R Posted January 9, 2017 Author Share Posted January 9, 2017 Posted by Chris Bott - Moderator on 09/01/2017 21:59:04: I downloaded the latest companion from a link that someone gave me, saved it on the mac went into opentx , connect up my taranisto the Mac pressed the 'write firmware to radio button . The file it wrote was taranisplus-en.bin I guess this was the wrong. file. Hope this helps OK, can you tell us which version of Companion you have now? It usually tells you right at the top. If not then click Help then About. What you needed to do was to set up companion so it matches your particular Taranis exactly. That's in Settings - Settings - Radio Type. ONLY AFTER you've done that, should you download the firmware for the Taranis. That's by File - Download, and save it somewhere you can remember. Once dowloaded, it needs to be written to the Taranis. At this stage you need to ensure that you're writing the version (filename) that you just downloaded. companion s/w = 2.1.9 i have tried installing both eu and _en after writing to Tx err message - new f/w not compatible with one currently installed. Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted January 9, 2017 Share Posted January 9, 2017 OK 2.1.9 is good. A message saying this is not compatible with your hardware is intended to stop you trying to write it to your Taranis, because it will trash it. So, what do you see on Taranis screen if you hold the horizontal trims inwards and then switch on? Quote Link to comment Share on other sites More sharing options...
Graham R Posted January 9, 2017 Author Share Posted January 9, 2017 Taranis BootLoader - 2.0.12 Write Firmware Restore EEPRM Exit Quote Link to comment Share on other sites More sharing options...
Chris Bott - Moderator Posted January 9, 2017 Share Posted January 9, 2017 Excellent. We can get this working again. It's bed time for me, but we can carry on with this tomorrow. We'll do it step by step. Would you be able to copy a file to the Taranis SD card? Once we establish the correct file to use, that might be the easiest way to update OpenTx/ Quote Link to comment Share on other sites More sharing options...
