fly boy3 Posted October 10, 2016 Share Posted October 10, 2016 I am fitting a servo to my elevator at rear of the fuz. on a 40 size model. I usually use a Futaba 148, just wondered in these modern time if there an alternative, perhaps smaller, lighter with same torque. Thanks Quote Link to comment Share on other sites More sharing options...
flight1 Posted October 10, 2016 Share Posted October 10, 2016 The 148 is a tried and tested Standard Precision Servo and stands up to more abuse than its replacements s3003/4 which are afew grams lighter 44.4/37g. there are loads of servos out there now and i would go with a Hitec HS-225 BB Mighty Mini HT at 27grams so a lot lighter and with a bit more torque , there are smaller one out there but i would go for metal geared ones if you choose to go smaller Edited By flight1 on 10/10/2016 19:42:14 Quote Link to comment Share on other sites More sharing options...
Former Member Posted October 10, 2016 Share Posted October 10, 2016 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
flight1 Posted October 10, 2016 Share Posted October 10, 2016 i quote hitec own words about the 225 a good little sevo in my opinion Product Description The analog HS-225BB represents a good value with performance that rivals other larger and more expensive servos. Ideal for applications that call for a small, lightweight, high speed, high torque servo, the HS-225BB high performance mini servo features a top ball bearing and is built with state-of-the-art SMT technology. Features Full Size Performance in a Mini Package Durable Nylon Gears Top Ball Bearings Perfect for Applications Requiring a Small, Lightweight, High Speed, High Torque Servo Quote Link to comment Share on other sites More sharing options...
Geoff S Posted October 10, 2016 Share Posted October 10, 2016 Have a look at the Kpower range at Airtek (advertised on this page). There are ball bearing metal geared minis with the same or higher torque than the bushed plastic geared 148s. I've had a few and had no problems. They centre well, too. Geoff Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted October 10, 2016 Share Posted October 10, 2016 Get the MG version, they're good reliable servos Quote Link to comment Share on other sites More sharing options...
Richard Wood Posted October 11, 2016 Share Posted October 11, 2016 The Airtek & Electricwingman websites are both showing stock of the metal geared HS225MG. Very good servos. Quote Link to comment Share on other sites More sharing options...
fly boy3 Posted October 11, 2016 Author Share Posted October 11, 2016 Thanks re servo alternative, got a bit of research to do. Thank you. Quote Link to comment Share on other sites More sharing options...
Don Fry Posted October 11, 2016 Share Posted October 11, 2016 There are high voltage servos available. At 2s lipo voltage, match a 148 at about 25 grammes. Quote Link to comment Share on other sites More sharing options...
Phil Green Posted March 5, 2017 Share Posted March 5, 2017 Tower Pro SG5010 is an excellent 148 replacement. Superb build quality, tight gear sets, excellent resolution, like Futaba 148, but more powerful . Cheers Phil Quote Link to comment Share on other sites More sharing options...
Former Member Posted March 5, 2017 Share Posted March 5, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
