rcaddict Posted October 30, 2016 Share Posted October 30, 2016 getting a phoenix 5.5 flight sim for xmas but the laptop I want use does not have a cd rom, can I copy cd onto flash pen or similar and load software this way - I have an older PC with a cg rom Edited By oldgit on 30/10/2016 07:21:11 Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted October 30, 2016 Share Posted October 30, 2016 I may be wrong, but I think you can download it from here and then use the interface dongle that comes with the retail package and it should work OK. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted October 30, 2016 Share Posted October 30, 2016 Frank is right OG. Have your chosen TX and your bought dongle connected before startup on your laptop, then do the download as Frank suggests and Phoenix set up will do the rest. Also, do not have your Tx switched on. Quote Link to comment Share on other sites More sharing options...
John F Posted October 30, 2016 Share Posted October 30, 2016 Frank, you can download updates but still need the original installation via CD first. You realistically need a computer with a recommended minimum of 1Ghz Pentium 3, which is arcane in computer terms (2002), but will always struggle to run it so need something a little bit more recent, (2006) with a graphics card. Shared graphics on an old machine would struggle. You would not be able to copy to a USB stick as most companies would apply DRM (Digital Rights Management) to protect their products from illegal copying. Dependant upon how old your machine is would determine whether buying a USB CD drive is worth the cost (£15 - 25) or whether you need a new machine. What are the specs of your machine? Edited By John F on 30/10/2016 08:01:48 Edited By John F on 30/10/2016 08:02:40 Quote Link to comment Share on other sites More sharing options...
rcaddict Posted October 30, 2016 Author Share Posted October 30, 2016 the laptop is pretty new & high end (lenova) and like many new laptops dont come with cd drive, however my pc is windows 7, 2.3 ghz, intel core 2 duo, 4.0 gb ram, ati radeon HD 5450, 24 gb free storage, Quote Link to comment Share on other sites More sharing options...
rcaddict Posted October 30, 2016 Author Share Posted October 30, 2016 the reason I wanted to use the laptop was to mirror screen to the big tv !! Quote Link to comment Share on other sites More sharing options...
John F Posted October 30, 2016 Share Posted October 30, 2016 In that case you'll be absolutely fine, you just need an external CD drive. £15 - 25 and you're sorted. Quote Link to comment Share on other sites More sharing options...
rcaddict Posted October 30, 2016 Author Share Posted October 30, 2016 thanks - Im happy now Quote Link to comment Share on other sites More sharing options...
John Privett Posted October 30, 2016 Share Posted October 30, 2016 If the laptop and PC are on the same network (which if you're using them both at home, connected to your router, they almost certainly are) then you should be able to share the CD drive on the PC and access it from the laptop. If you're not sure how to do this have a look here (or many other places on the 'net.) Quote Link to comment Share on other sites More sharing options...
