Doug Ireland Posted July 23, 2008 Share Posted July 23, 2008 Hi Guys,Does anyone know if Australian spec 2.4 gig sets are ok for the UK? Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted July 23, 2008 Share Posted July 23, 2008 Not sure...but even if they are not it will only be due to having too much output power and this is fixable by HH UK . Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted July 23, 2008 Share Posted July 23, 2008 If it's a DX6i they have a setting for US or EU in the programming, not sure about the DX7. Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted July 25, 2008 Author Share Posted July 25, 2008 Thanks for that guys, i think I may just treat myself to one! Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted July 25, 2008 Author Share Posted July 25, 2008 Just checked the prices in a model shop in Perth WA and I would be better off buying it from Al's! Question is do I go for the DX7 or the new JR 9 channel job! Oh problems problems!!! Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted July 25, 2008 Share Posted July 25, 2008 well its only money, there is no problem........the 9 channel is for you Mr Ireland - luvverly bit of kit.#Have they found oil out there then ! Quote Link to comment Share on other sites More sharing options...
Always broke Posted July 25, 2008 Share Posted July 25, 2008 Get The JR set. I started with the specy set and upgraded this year to the 9x . Fantastic TX . Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted July 26, 2008 Author Share Posted July 26, 2008 Hi Timbo, they're only playing at over here but they have found some oil off the north west coast. I should be back in blighty next week.the new JR it is then!!! Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted July 26, 2008 Share Posted July 26, 2008 I hate you again now Doug...... Oz in "work" and getting the new JR 2.4Ghz Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted August 4, 2008 Author Share Posted August 4, 2008 A quick question gents regarding orientation of the two rx parst of the 2.4 set-up. The RD921 main part (with the servo sockets in it) has two short aerials, one out of the top of the case and another at 90 degrees to it. The other bit has two aerials opposite each other. My question is, how do I mount these in the airframe?I was a bit apprehensive about the "binding" process as described in the supplemental instructions but it seems to have worked ok.Another thing, the manual states that a 3S LiPo SHOULD NOT be used in the tx as 12.6v is a bit OTT!A very toughy-feely piece of kit is the new DSX9!!! Quote Link to comment Share on other sites More sharing options...
Always broke Posted August 4, 2008 Share Posted August 4, 2008 I have the main RX mounted flat with the servo connections facing the engine . The second RX is mounted on the Fuz side with the antenas running along the length of the model. This is in a 110" 45cc powered Bipe. In a different model the main RX is mounted on top of the fuel tank and the second one on the side. Works perfectly. I am sure there is two much hype about where to place the RXs. Just get them 90* to each other and it works for me.Why would you want to fit a lipo in the TX. I get a full days flying from the supplied battery ,thats probably close to 20 flights on a good day and it is still no where near flat. Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted August 4, 2008 Author Share Posted August 4, 2008 I was just jumping on the bandwagon Quote Link to comment Share on other sites More sharing options...
Mike Johnson Posted August 5, 2008 Share Posted August 5, 2008 As f Doug Ireland wrote (see)Hi Guys,Does anyone know if Australian spec 2.4 gig sets are ok for the UKAs far as I understand the legislation if the unit does not have the CE mark on it then it is illegal in the UK unless a letter is obtained stating that the unit complies with the UK legislation. If you go to the GBRCAA site there is a very informative thread there on compliance.Mike Quote Link to comment Share on other sites More sharing options...
Tony Heaton Posted August 9, 2008 Share Posted August 9, 2008 Mike, can you be more specific as to the URL ? I've looked but cannot find an article on CE compliance. Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted August 11, 2008 Author Share Posted August 11, 2008 A quick thank you to Graham Ashby for his review of the DSX9. I wasn't aware that you could plug the remote rx (or use two for that matter) into either side of the main rx, will make installation a lot easier! Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted August 11, 2008 Author Share Posted August 11, 2008 Got a bit of a head-scratcher with the Fail-Safe on the DSX9 that I could do with some help on?I had to reverse the throttle servo in my latest creation and as a consequence it moves to full open when the tx power is removed instead of closed. I'm sure it has something to do with the "binding" as the fail-safe is part of the process. Any idea guys? Quote Link to comment Share on other sites More sharing options...
Mike Johnson Posted August 11, 2008 Share Posted August 11, 2008 Once you have set up your servo's etc: you must re-bind to ensure the fail safe works in the correct direction, its that simple. Mike Quote Link to comment Share on other sites More sharing options...
Doug Ireland Posted August 11, 2008 Author Share Posted August 11, 2008 Thanks Mike, thought it was something like that but wasn't too sure.Thanks again... Doug Quote Link to comment Share on other sites More sharing options...
