CARPERFECT Posted January 30, 2017 Share Posted January 30, 2017 Need some new wing bolts for the Acro wot. Anyone know what size they are. and they are not 6mm. Quote Link to comment Share on other sites More sharing options...
Richard Wills 2 Posted January 30, 2017 Share Posted January 30, 2017 If it is the ARTF. They are imperial 1/4-20. Model fixings do some good ones. Quote Link to comment Share on other sites More sharing options...
CARPERFECT Posted January 31, 2017 Author Share Posted January 31, 2017 Thanks Richard Wills 2 Quote Link to comment Share on other sites More sharing options...
Jonathan M Posted February 3, 2017 Share Posted February 3, 2017 On the other hand - if its the ARTF - then you'll find the captive nuts are very shallow (i.e. very little thread) and poorly-made (the nylon bolts supplied with my Acro Wot just spun when they were even lightly tightened and then vibrated loose when the model was still on the ground!). Is an easy and quick mod to carefully tap the crap ones out and fit decent 6mm ones with longer necks in their place. **LINK** Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted February 3, 2017 Share Posted February 3, 2017 These threaded rivets are really good replacements, available in all metric sizes from the auction site, and bonded into the hole with epoxy Quote Link to comment Share on other sites More sharing options...
kc Posted February 3, 2017 Share Posted February 3, 2017 Richard said "They are imperial 1/4-20. " and Imperial means Whitworth or BSF. However an ARTF is surely more likely to have American threads such as UNC which also has a 1/4 by 20 size but it's not the same thread as Whitworth! UNC and UNF have a 60 degree angle of thread while Whitworth and BSF have 55 degrees, so they are not interchangeable but a nylon bolt might work OK.. Edited By kc on 03/02/2017 11:38:32 Quote Link to comment Share on other sites More sharing options...
kc Posted February 3, 2017 Share Posted February 3, 2017 Threaded insert nuts can also be obtained from Screwfix and they are threaded into the wood ( unlike those shown by Denis which are splined) using an allen key. M6 cost £2.35 for 50. They also do T nuts at £1.49 for 10. Toolstation sell M6 T nuts at £1.13 for 10. Edited By kc on 03/02/2017 11:38:57 Quote Link to comment Share on other sites More sharing options...
CARPERFECT Posted February 3, 2017 Author Share Posted February 3, 2017 I lost a nylon bold from my Seagull Cessna 337. and have borrowed the bolts from my Acro Wot. So the are from an ARTF. and they are 1/4 unf Quote Link to comment Share on other sites More sharing options...
John Davies 4 Posted February 3, 2017 Share Posted February 3, 2017 The splined type shown by Dennis are for inserting with a pop rivet gun , and the slines are to stop them rotating in the host material , usually sheet metal too thin to tap. Quote Link to comment Share on other sites More sharing options...
kc Posted February 3, 2017 Share Posted February 3, 2017 Carperfect- did you really mean UNF ? I would have thought it was UNC as that is 1/4 by 20 ( UNF is 1/4 by 28 ) Quote Link to comment Share on other sites More sharing options...
CARPERFECT Posted February 4, 2017 Author Share Posted February 4, 2017 Sorry typing error they are UNC Quote Link to comment Share on other sites More sharing options...
