balance point
HI, can any one please help me to find the Cof G for an old biplane I am converting from diesel to electric, the top wing is 48" X 8" , the fuse length is 35". I have no drawing to help. plus no name for it to help.
Would it be 3. 3/4" from the leading edge. the electric motor will be lighter than the
engine, so I will have to add weight to balance it. Any info will be most appreciated
Thanks in advance Mike.
Hi Denis, thanks for the info as soon as I can fit the wings I will do as you suggest, I am still in the proses of rebuilding the front end around the motor, I am replacing an ENYA 15-IV. with an out runner GT2815--07, a 9X6 prop this is the one that was on the original engine, the plane was a gift and soaked in fuel so had to replace right back past the tank bay, still keep me busy for a while.
I hope this is not going to be too powerful.
Thanks again & will let you know how it goes.
Mike.
The forum posts on the Skywriter are a similar size to your model Michael
Lindsay Todd's 48” sport scale bipe will lend fluency and extra flourish to your flying.
Datafile
Model type: Sport-scale biplane
Designed by: Lindsay Todd
Wingspan: 48”
Fuselage length: 39.5”
Wing area: 803 sq. in.
All-up weight: 5 lb 4oz
Wing loading: 16oz / sq. ft.
Functions (servos): Aileron (2); rudder (1); elevator (1); throttle (via ESC)
Power system: Turnigy 3548 1100Kv motor; 60A ESC; 3s 5000mAh Li-Po
