Tony j Posted July 23, 2017 Share Posted July 23, 2017 Hi all does anyone know where I could obtain a replacement O ring for the main needle valve on a Sc 46 engine Many thanks in advance Kind regards Tony Quote Link to comment Share on other sites More sharing options...
Peter Christy Posted July 23, 2017 Share Posted July 23, 2017 I would suggest Just Engines: **LINK** I think the Sc and ASP engines all come out of the same factory (a bit like Austin and Morris used to be!), so I would imagine the ASP bits would fit. -- Pete Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted July 23, 2017 Share Posted July 23, 2017 JE have a £6 minimum order charge (why?) , so you might as well buy a complete needle assembly from them. Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted July 23, 2017 Share Posted July 23, 2017 By the time someone picks the item, posts it, it takes time. Doing it for £3 is not worth it, as the cost of wages for that would be more than what it's worth. JE is a business after all... Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted July 23, 2017 Share Posted July 23, 2017 Posted by Cuban8 on 23/07/2017 18:45:24: JE have a £6 minimum order charge (why?) , so you might as well buy a complete needle assembly from them. or a couple of glow plugs as well. I'v never managed to spend less that £6 Quote Link to comment Share on other sites More sharing options...
will -0 Posted July 23, 2017 Share Posted July 23, 2017 Hi I've tried and tried to source the right size o ring for needle valves. The shouldn't cost more than a few pence but seem to be an odd size not available from normal o ring suppli3rs Quote Link to comment Share on other sites More sharing options...
