Neville Hill Posted October 26, 2017 Share Posted October 26, 2017 Setting my 14SG for throttle cut presents me with a problem. Setting everything as per manual using switch SH and position to 25%, (pre-set is 17%) with throttle at minimum position and on operation of switch the servo increases engine revs and not reduces. ie operates the cut in the opposite way. I have tried reversing switch SH from OFF to ON but this then seems to stop the throttle working full stop. No good reversing the stick for obvious reasons. I have the Malcolm Holt programming manual but is not much help giving the same instructions as the Futaba manual? I need help Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted October 26, 2017 Share Posted October 26, 2017 Not got Futaba, go to - % ? Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted October 26, 2017 Share Posted October 26, 2017 Switch SH is a momentary switch Neville, and the only suitable stop switch It is long, and goes back to original position when let go There are other switches in that corner Make sure you select the correct one. 17% will stop any motor where that endpoint is idle Woops, meant to add, SH is a 2 position switch, it is already OFF, when in the correct Pushed back position It is ON in the forward position The switch only has the ability to pass current in the forward position. Reversing this particular on/off switch will result in off/off Edited By Denis Watkins on 26/10/2017 14:48:49 Quote Link to comment Share on other sites More sharing options...
iqon Posted October 26, 2017 Share Posted October 26, 2017 try - 25% not + 25% , and put switch back as you had it. Quote Link to comment Share on other sites More sharing options...
Former Member Posted October 26, 2017 Share Posted October 26, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Tim Flyer Posted October 27, 2017 Share Posted October 27, 2017 I believe how throttle cut works is it gives you a percentage of the “ bottom “ range between the “limit “ and “end point”. Make sure you have a decent difference between the limit and end point.e.g 60% and 100%. For instance if they were both at 100% throttle cut would do nothing. As said the throttle cut percent do not need to be big if there is s decent difference between limit and end point. Alter the plus and minus as said above according to direction you need. 😊happy Flying Edited By Timothy Harris 1 on 27/10/2017 06:09:28 Quote Link to comment Share on other sites More sharing options...
