GrumpyGnome Posted February 25, 2018 Share Posted February 25, 2018 Hi everyone, hope you can help. Just bought an engine off eBay - I know, I know.... Anyway, it looks ok, decent compression, starts ok, throttles ok, but smokes like someone on 60 a day! It is an SC 70. Any ideas ? Valves/tappets ? Thanks in advance, GG Quote Link to comment Share on other sites More sharing options...
ASH. Posted February 25, 2018 Share Posted February 25, 2018 Too rich on the needles, too much oil in fuel or gunge in the exhaust system. Quote Link to comment Share on other sites More sharing options...
Jon H Posted February 25, 2018 Share Posted February 25, 2018 yup. what fuel are you running? Its also quite possible its previous owner filled it with castor and that is likely to take a while to burn off. Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted February 25, 2018 Author Share Posted February 25, 2018 Don't think too rich - leaned it out quite a way but only for a few mins.. Running on brand new Model Technics 10% nitro. Exhaust seems clear but will have a closer look. Will run it some more and see if it gets better. Thanks for suggestions Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted February 25, 2018 Share Posted February 25, 2018 Which Model Technics 10% nitro fuel GG...there are a few....if it's GX or GN10 these are castor based & will smoke a lot.... All glow engines smoke & it can take a while for the smoke to die down after you first start them.....run it at full throttle for a couple of minutes or so & see if it reduces. If not it's probably too rich..... Quote Link to comment Share on other sites More sharing options...
will -0 Posted February 26, 2018 Share Posted February 26, 2018 I bought an OS52fs off ebay ages ago. I popped the head off and it had what looked like mayonaise inside. Cleaned it out and it ran/runs a treat. So never assume with an ebay special! Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted February 26, 2018 Author Share Posted February 26, 2018 It is Contest 10 fuel..... Quote Link to comment Share on other sites More sharing options...
ASH. Posted February 26, 2018 Share Posted February 26, 2018 In cold weather you have to run richer which give out more white smoke. Quote Link to comment Share on other sites More sharing options...
Jon H Posted February 26, 2018 Share Posted February 26, 2018 Posted by GrumpyGnome on 26/02/2018 07:25:01: It is Contest 10 fuel..... there's your problem. I forgot how filthy that fuel was until a customer brought his model in for some tuning help. Compared to the fuels i normally use its really messy. Once you have used it up give Model Technics Laser 5 or Techpower 5 a go. They are cleaner and cheaper. You dont need 10% nitro either, the sc will be fine on 5% Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted February 26, 2018 Share Posted February 26, 2018 Posted by Jon - Laser Engines on 26/02/2018 09:08:02: Posted by GrumpyGnome on 26/02/2018 07:25:01: It is Contest 10 fuel..... there's your problem. I forgot how filthy that fuel was until a customer brought his model in for some tuning help. Compared to the fuels i normally use its really messy. Once you have used it up give Model Technics Laser 5 or Techpower 5 a go. They are cleaner and cheaper. You dont need 10% nitro either, the sc will be fine on 5% I wondered when you'd pop up with that sage advice, Jon. Doing my best to spread the word amongst a few 'die hards' that I know, but even the evidence of their own eyes when they see my engines running fine on Laser 5 doesn't seem to be enough to convince them...................need a campaign like......."Castor? ....just say no". Quote Link to comment Share on other sites More sharing options...
Jon H Posted February 26, 2018 Share Posted February 26, 2018 Posted by Cuban8 on 26/02/2018 10:12:26: ...................need a campaign like......."Castor? ....just say no". Pretty much. 18% oil is also really excessive these days and castor serves no real purpose at this point. Most of my club have converted to Laser 5 with some also using techpower in 5 and 10% flavours. All the engines we run on these fuels run faultlessly and between us all we use ASP, OS, Saito, Laser, Enya, and irvine in both two and 4 stroke forms. The big Enya 4 strokes really love the Laser 5 fuel as do thr ASP 52 4 strokes used in some of our trainers. Contest 10 is not a bad fuel by any means, its just very messy. Quote Link to comment Share on other sites More sharing options...
